Like Tree2Likes
Old 04-07-2006, 04:05 PM   #3721
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Viat
MikeR,
I thought you said 3-4mm
I guess this is relative and depends on who's pushing on the belt . For myself I'm talking light pressure with 1 finger like writing with a pencil....
I think unless you have the build wrong you just need to run the box set up and run the car and make your adjustments from there. With experience you'll understand where the right belt tension is for you. If you built the car right the belt won't be too loose.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-07-2006, 06:09 PM   #3722
Viat's Avatar
Trader Rating: 24 (100%+)
I may be wrong, but I don't see how else it could be built.
With the adjustment of tension on the rear belt it has exactly 3-4mm play
and the front one is still at the exact adjustment point as it is shown in the instruction.
Viat is offline   Reply With Quote
Old 04-07-2006, 07:02 PM   #3723
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note we have some TA05 hop-ups back in stock including some new hop-ups:
Graphite Center Plate
Aluminum side motor guard
Also the low friction blue belts are back in stock as well
Have a great weekend
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-08-2006, 01:04 AM   #3724
Ghostfit's Avatar
What do you guys think about the ?
MC230CR ESC
This is actually a low end ESC, but if you are really on a budget, I would suggest to get the MC330CR instead which is a much better ESC.
Ghostfit is offline   Reply With Quote
Old 04-08-2006, 09:52 AM   #3725
Regional Moderator
Darkseid's Avatar
With the adjustment of tension on the rear belt it has exactly 3-4mm play and the front one is still at the exact adjustment point as it is shown in the instruction.
Trying to figure out mm of belt push over the internet is....sketchy at best. Thats why I said just go with the stock(instruction) settings first. Its the only way to be sure that your starting from the same point as we all were.
The stock setting is two notches toward the center of the car at both the front and rear. If you feel they are too tight, rotate them counter clockwise, so that they are only one notch toward the center of the car.
Now, unless your reading the instructions wrong, OR there is some kind of defect with your kit, then one notch toward the center should be as loose as you need to go until the belts stretch some.
Don't know what else to tell you...
TLR 22...Tamiya F104...
Old 04-08-2006, 12:01 PM   #3726
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Here's something I just figured out and I can't figure out why I am just now noticing this. Tamiya's 70 tooth spur is bigger than a regular 78 tooth spur.
I knew they were different but never realized the numbers were so far apart
Royal Rumble Racing
minicooper is offline   Reply With Quote
Old 04-08-2006, 02:13 PM   #3727
Viat's Avatar
Cool
All right I hear you Darkseid.
I assembled it exactly as it shown. Yesterday after tightening the rear one I pull the trigger about 1/4 of the way while holding it in another hand and looked at the belts. The rear one was spinning with out moving left and right in the diff. pulley and the center pulley, but the front one (which was assembled as shown in the instruction) did move from side to side on the pulleys so after trying it on the parking lot and adjusted front belt by one click less tight, then the rear one.
Old 04-08-2006, 05:49 PM   #3728
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Which of the 2 aftermarket motor mounts is better? (Xenon or 3 Racing) I find the stock motor mount doesnt absorb heat alot, so I thinking of upgrading to either one of them.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-08-2006, 07:35 PM   #3729
JimmyMac's Avatar
My Xenon motor mount is of very nice quality. Only thing I won't like is if/when Tamiya decides to come out with one!! hehe... Xenon is pretty good with their products. However their rear hubs for the 415/EvoIV is bad. They are suppose to be 0 degrees with less slop than the Tamiya units. But mine have like 3 degrees on one side and 0 or less on the other. So they aren't really drilled right. So I went back to my aluminum units...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-08-2006, 08:09 PM   #3730
justin lessard's Avatar
Send a message via AIM to justin lessard
jimmy,check you e-mail
justin lessard is offline   Reply With Quote
Old 04-08-2006, 08:53 PM   #3731
Slotmachine's Avatar
Send a message via MSN to Slotmachine
O/K Tamiya guru`s here's one for you..........I am looking for 2 deg C Hubs that will work with the TA05............. I need a part # please
Paul
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-08-2006, 09:07 PM   #3732
JimmyMac's Avatar
You mean 2degree for the old style suspension right? Any brand I take it.. hmmmm
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-08-2006, 09:15 PM   #3733
big al's Avatar
Hey guys, Ijust bought a ta05 and was wondering what the pound rating on tamiya springs are. Also, I plan on running it pretty much bone stock and was hoping for a setup. Thanks in advance--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 04-08-2006, 09:17 PM   #3734
Yes 2 deg. that will fit the stock arms.............
Old 04-08-2006, 09:35 PM   #3735
JimmyMac's Avatar
I'll let you know if I find any. I thought I saw some 3degree ones somewhere... But I can't remember. Also Tamiya has some un-confirmed caster blocks that are not 4 degree. They may be 6 degree. I had some at one time. But I thought they may of had 2 degree as well. But I'm very unsure of this. Anyways... I'll let ya know in my searches....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
