Like Tree2Likes
Old 04-06-2006, 02:31 PM   #3706
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
I like
http://www2.towerhobbies.com/cgi-bin...I=LXCHA7**&P=0
You can find them for $99 I bought a new one off of ebay (transmitter only) for $47 EBAY Link
minicooper is offline   Reply With Quote
Old 04-06-2006, 02:36 PM   #3707
Regional Moderator
Darkseid's Avatar
Originally Posted by Viat
What do you think Darkseid, about
"Futaba 2PL 2-Channel AM/1 S3003/MC230CR ESC"
http://www2.towerhobbies.com/cgi-bin...I=LXENN1**&P=7
I mean everything that is included?
Well if your planning on doing a big race like a TCS event, I would HIGHLY recommend a FM radio system. They are so low priced these days that I honestly don't see why they still make the AM units.
The FM will provide much better protection from interference. The FM units from Futaba are excellent, as are the ones such as the one in the link minicooper gave. They are also very affoardable.
TLR 22...Tamiya F104...
Old 04-06-2006, 02:50 PM   #3708
Viat's Avatar
Trader Rating: 24 (100%+)
What do you guys think about the
MC230CR ESC
Viat is offline   Reply With Quote
Old 04-06-2006, 03:43 PM   #3709
*mini*racer*'s Avatar
Save your money and buy a Spektrum DX2. You will save money in the long run. It is DSM so no crystals to deal with. So when those big races come around and the is racing going on and you need to test something on the car. you need not worry about your radio messing things up.
Plus you can find this radio cheap. in the $150 range.
http://www.spektrumrc.com/Products/D...ProdID=SPM2020
*mini*racer* is offline   Reply With Quote
Old 04-06-2006, 08:09 PM   #3710
Viat's Avatar
I hate to ask another "Rookie question",
I assembled the chassis it was shown in the instruction but one thing is bothering me.
It is the tension of the belts.
Can somebody tell me how much play should they have (up and down)?
Old 04-06-2006, 10:52 PM   #3711
Regional Moderator
Darkseid's Avatar
Well first, double check that you have the diff mounts in the proper position. I believe that stock, both the front and rear should be two notches toward the center of the car.
After you are sure that that is correct, run the car and the belts will stretch slightly after about a dozen runs or so.
But if you're really worried that the belts are too tight, you can adjust them to loosen them. You do this by moving the little dot counter clockwise. One notch should be enough.
Old 04-07-2006, 01:24 AM   #3712
Dongskie's Avatar
Trader Rating: 44 (100%+)
[QUOTE=m i g v e a]
Originally Posted by akuhon
Cool, ... I plan to get this pulley then.
Have you tried with stock belt ? 'Cause I'm going to use those blue aramid tamiya option belt.
Migvea: Hey man I heard you've been winning club races at the Speedzone?? You won againts some PRO4s and Cyclones there in the past 3 weeks dude??
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 04-07-2006, 02:27 AM   #3713
sup
sup's Avatar
yep! migvea is on a roll (and to think its almost stock, its like barely hopped-up). i should be copying the migvea setup instead of the dongskie setup. hehehe! kidding dong. hope to race with you soon. we're still waiting for your comeback.
sup is offline   Reply With Quote
Old 04-07-2006, 09:55 AM   #3714
MikeR's Avatar
Trader Rating: 15 (100%+)
It depends on your application;
Low wind mod- medium tight (maybe box set up) 2mm of up and down play
19turn- a click or two looser than box set up. 3mm of up and down play
stock- 3-4mm of up and down play
Most belts slip under heavy braking- not acceleration. Also never run a belt too tight- you'll toast your motor. Too loose you'll just wear the pulleys or the belt will slide off in a crash. I always run mine loose on my 415 for 19turn. After a year I'm still using the original belts and pulleys with no probs.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-07-2006, 11:00 AM   #3715
in 19t I run the front belt slightly looser than the rear, as under acceleration, the rear axle takes most of the laoding.
DA_cookie_monst is offline   Reply With Quote
Old 04-07-2006, 11:12 AM   #3716
Viat's Avatar
All right,
what about running 27T?
I usually run on the track in Frederick MD "Hobby Town USA" and here is this year TCS race photo reportage on RC ClubMD
I ran TT-01 my first rc-car. It is red Enzo.
Old 04-07-2006, 11:47 AM   #3717
MikeR's Avatar
All right,
27 is 'stock' in my post
Old 04-07-2006, 12:23 PM   #3718
Viat's Avatar
I just tightened my read to the max and the belt naw has a play of 4mm up and down.
Old 04-07-2006, 12:42 PM   #3719
MikeR's Avatar
Try turning the adjusters the other way now.
Old 04-07-2006, 12:52 PM   #3720
Viat's Avatar
MikeR,
I thought you said 3-4mm
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
