Like Tree2Likes
Old 04-02-2006, 04:21 PM   #3646
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I don't know if I can get it by Saturday. I can try.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-02-2006, 05:11 PM   #3647
Regional Moderator
Darkseid's Avatar
Originally Posted by danjoy25
Also regarding the carbon components, do you actually need to buy all 3 or just the chassis will do the job<
Depends on what your goal is. If your trying to dump weight, the of course all three sets will be nice. But if your simply trying to add stiffness, then the chassis will get the job done in that area.
TLR 22...Tamiya F104...
Old 04-02-2006, 05:25 PM   #3648
GreaseMonkey's Avatar
Hi everyone.
I just got my TA05 up and running, it's basically stock except for trf special bue dampers (with yellow springs) and a 19 turn motor.
I took it out for the first time this morning and found that no matter what speed the car is doing, if I turn right and give it any throttle, the rear end steps out. It's controlable at lower speeds but at higher speeds it's a bit of an issue. The biggest concern though is that it doesn't do it when turning left.
In fact I can't even get the car to swing doughnuts when turning left, it will understeers unless I on throttle/off throttle/on throttle again.
GreaseMonkey is offline   Reply With Quote
Old 04-02-2006, 05:30 PM   #3649
volracer's Avatar
Send a message via ICQ to volracer
Check the alignment of your wheels, toe, camber, etc. Also check the weight on all corners.
volracer is offline   Reply With Quote
Old 04-02-2006, 05:40 PM   #3650
I set up all my control arms/ tie rods as per the manual. I used vernier calipers to measure the arms so I know they are all almost exactly the same length as the other side (within .04mm).
Edit: I didn't check weight distribution. I thought maybe the weight of the battery could be causing it.
Old 04-02-2006, 05:41 PM   #3651
I'd bet it's the droop settings.
I've gone away from using droop guages and just use my ride height guage. So if you want 2 mm of droop, check the setting ride height, then lift on the chassis right at the point the wheels come off the ground and then recheck the ride height holding the car with the wheels just touching still. Whatever the amount subtract your static ride height and thats your droop setting.
Old 04-02-2006, 05:44 PM   #3652
droop?
Old 04-02-2006, 05:46 PM   #3653
When you lift on the chassis and the suspension droops down...this amount is called the DROOP. Make sure it's even left to right.
Old 04-02-2006, 05:47 PM   #3654
Slotmachine's Avatar
Send a message via MSN to Slotmachine
When it comes to chassis balance you need to invest in a tweak board or 4 digital pocket scales. I know from experience you will not get all 4 corners the same but if you get the rear weights the same the car will drive very equal in both directions.
Paul............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-02-2006, 05:50 PM   #3655
ah, thanks. It seems i have less droop on the right than the left. At least at the rear anyway.
hm.. significantly so.
Old 04-02-2006, 06:48 PM   #3656
that's the problem for sure then.
Old 04-02-2006, 06:51 PM   #3657
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Can someone with the carbon parts please weight them before using them:
Im mainly interested in the chassis, f&r stiffeners and bulkheads only as the other parts included wont be used due to other options used already.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-02-2006, 08:23 PM   #3658
Regional Moderator
Darkseid's Avatar
Your probably a bit too late with this request. Most of the people who got the carbon parts have installed them already.
Old 04-02-2006, 08:32 PM   #3659
rayman's Avatar
The carbon chassis is a third the price of a new tao5 kit. Why is it so expensive? Its not even significantly lighter.
rayman is offline   Reply With Quote
Old 04-02-2006, 08:36 PM   #3660
Regional Moderator
Darkseid's Avatar
This isn't that unusual. Optional chassis aren't cheap. If you look to a place like RC Champ, the price of the chassis is quite reasonable.
Besides that, most people aren't getting the chassis just for the weight loss, its also to stiffen the car up.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
