Like Tree2Likes
Old 04-01-2006, 12:07 AM   #3631
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Thanks Slotmachine & Kilruf
minicooper is offline   Reply With Quote
Old 04-01-2006, 11:05 AM   #3632
akuhon's Avatar
Originally Posted by KilRuf
I'll have to post pics of my TA05 later one. But I just got in my TechRacing direct 18t pulley set. This changes the internal ratio from 2.25:1 to 2.0:1.... Only down side I see from this unit is the weight of the pulley vs the stock plastic pulleys (which it seems the 415 guys are switching to). However the center shaft is friggin light as hell! It also appears that the white belts are of the same make as the 415 white belts.. and all the other white belts on japanese market cars.. Team Bomber BD.. etc etc...
I dunno how it will perform. I just saw it and ordered it just for the hell of it... Bling Bling!
Kilruf,
Does this part come with 2 pulleys ? or just 1 ?
I think it should be 2 cause there are 2 belts, right ?
akuhon is offline   Reply With Quote
Old 04-01-2006, 11:11 AM   #3633
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Default Must have options
Got a TA05 on the way, any recommendations for upgrade options? Looking for enhancement, rather than blinging it up.
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 04-01-2006, 11:29 AM   #3634
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Scarab
Now that I have most of the parts I need, i'm starting my build on my new TA-05. Anything I need to know about the build process?
Scarab
If you are putting machine screws in all of that plastic a 3mm tap is highly recommended
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-01-2006, 01:17 PM   #3635
Send a message via AIM to A-Ko
Alum shocks, swaybars, front universals and double 1-ways (if you have driven with them before/if not you can be fast without them).
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 04-01-2006, 01:45 PM   #3636
MikeR's Avatar
Yep- and 2 each color of the short shock tuning springs.
Old 04-01-2006, 07:11 PM   #3637
Regional Moderator
Darkseid's Avatar
If your looking for enhancement and not bling, I've got the perfect answer for this question.
Start with the true essentials:
-swaybar kit
-tamiya tuned spring kit (short)
-the right tires for your track
Then drive the car first! Thats right, drive it nearly bone stock. Then see what you feel you need. For example, if you drive the car and say to yourself "man, alloy shocks will make my lap times lower", then go for them.
I think you'll find that there are very few things you need to really make this car the best you've ever driven.
TLR 22...Tamiya F104...
Old 04-01-2006, 08:14 PM   #3638
tony q's Avatar
-swaybar kit
you are right, because that's what i did. i run the car bone stock and from there i bought hop-ups that i really need, the trf shocks,sway bar, and front and center oneway. after that i'm happy w/ the car.
tony q is offline   Reply With Quote
Old 04-01-2006, 09:07 PM   #3639
JimmyMac's Avatar
Originally Posted by akuhon
Kilruf,
One pulley. It's just like the direct pulley for the 415. It's one long pulley that fits both belts. I'll post pictures maybe tomorrow or Monday sometime.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-02-2006, 05:02 AM   #3640
badboy's Avatar
Trader Rating: 14 (100%+)
with all the hopups coming out for the TA05, can the TA05 be as competitive as the 415 MSX?
slow is fast . . .
badboy is offline   Reply With Quote
Old 04-02-2006, 05:06 AM   #3641
bomberman's Avatar
based from the talking here in US before. yes it can be close to the MSX
well i like to meet some tamiya guys in the Philippines right now.
bomberman is offline   Reply With Quote
Old 04-02-2006, 09:05 AM   #3642
akuhon's Avatar
OK thanks.... I'll wait... just curious ....
Old 04-02-2006, 10:33 AM   #3643
Regional Moderator
Darkseid's Avatar
Like I said, I haven't seen whats so special about the 415. At least not on the local level. I have no doubt that the Tamiya team drivers could do just as well/if not better, with a nicely equiped TA05 as they do with their 415.
But considering Tamiya sells one for $130 and the other for $400 plus, I doubt there will ever be a chance to see that theory proven.
Old 04-02-2006, 12:02 PM   #3644
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Can anyone verify if both part #53867 (1 way pulley) and the part #51212 diff pulley are the same??? They look the same in the photos I see, and no one has the diff (51212) in stock. Actually I think they are slightly different.
Does anyone know where they are in stock? Or, does someone have a spare I can buy???
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-02-2006, 04:19 PM   #3645
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Try RC-Champ
Does anyone know the weight difference in grams between the stock steel universal axles and the 53681 Titanium Axles?
Also regarding the carbon components, do you actually need to buy all 3 or just the chassis will do the job<
Anyway, ran the car for the first time yesterday and qualified 2nd and finish 1st in the final. My race weight was just 1530 grams Looks like my Cyclone will be going soon
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
