Like Tree2Likes
Old 03-30-2006, 12:14 PM   #3601
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by Bane
Was checking out the aluminum clamp hex hubs and see they have 4mm,5mm, and 6mm. Which ones should I pick up? I will be running mostly at The Colliseum @ Frederick Hobbytown. Thanks.
I run my ta05 with 4`s in the front and 6`s in the rear with take off 32`s on the car.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 03-30-2006, 12:44 PM   #3602
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Here pics of my new ride. Got it 2nd Hand with pretty much all the bling (Thanks Black-Knight). I just need to find out abit more about the toe blocks. Car is fitted from the front 1x, 1xd - 1xc 1a rear w/-1 deg rear hubs. Can anyone tell me what this equates.
Tamiya TA05 Touring Sedan-img_0950.jpg   Tamiya TA05 Touring Sedan-img_0951.jpg   Tamiya TA05 Touring Sedan-img_0952.jpg
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-30-2006, 01:35 PM   #3603
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by danjoy25
Here pics of my new ride. Got it 2nd Hand with pretty much all the bling (Thanks Black-Knight). I just need to find out abit more about the toe blocks. Car is fitted from the front 1x, 1xd - 1xc 1a & rear w/-1 deg rear hubs. Can anyone tell me what this equates.
To get really accurate toe numbers you have to use these;http://integy.automated-shops.com/cg...38106413077.f6
Looks nice!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-30-2006, 03:03 PM   #3604
rayhuang's Avatar
Any chance any of you have the stock servo mounts you can sell/ship me? I bought a car from a guy who shipped it to me in the Tamiya box and it arrived with a hole in the box and he claims all the small parts were in there.
Just sock-em in a padded mailer so they dont get lost again.
I tried to buy them at speedtech, but they are sold out of the parts tree I think they are in.
Thanks,
Ray
[email protected]
Old 03-30-2006, 05:09 PM   #3605
C_O_jones's Avatar
hi Ray, I got one of those same used kits too.
ended up using the TB02 mounts, work just fine.
Fred Forg
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 03-30-2006, 05:51 PM   #3606
JimmyMac's Avatar
I'll have to post pics of my TA05 later one. But I just got in my TechRacing direct 18t pulley set. This changes the internal ratio from 2.25:1 to 2.0:1.... Only down side I see from this unit is the weight of the pulley vs the stock plastic pulleys (which it seems the 415 guys are switching to). However the center shaft is friggin light as hell! It also appears that the white belts are of the same make as the 415 white belts.. and all the other white belts on japanese market cars.. Team Bomber BD.. etc etc...
I dunno how it will perform. I just saw it and ordered it just for the hell of it... Bling Bling!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-30-2006, 07:09 PM   #3607
Going from a 2.25 to a 2.0 seems like the wrong thing to do to me. You will make it harder on the motor to pull out of the corner............
Old 03-30-2006, 08:01 PM   #3608
Korey Harbke's Avatar
Think about this, the pulleys are bigger, bending and pinching the belt less. This generally results in a freer and more efficient drivetrain. Xray did it, and hasnt gone back. Their internal drive on the original T1 was 2.25. They changed the pulleys to increase drivetrain efficiency, and it made the internal raito of the car a 1.77. You should be able to gear the car so the overall final drive is the same. So your overall acceleration feel should be almost the same as well.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-30-2006, 08:19 PM   #3609
rayhuang's Avatar
Fred Forg
Fred-lol I could go on and on about this trade...ummm, but I wont.... Thanks-i'll check and see about availability of tb02 mounts tomorrow.
Old 03-30-2006, 09:15 PM   #3610
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Well, from the front you're looking at 2 degrees inboard toe-out, although your steering links will determine the actual toe..
In the rear, you have 2-deg inboard toe-in, plus the 1 degree block, making 3 degrees total toe in.
For every letter difference, it's a half-degree, XD the shortest block, X is in the middle, and 1E the largest. 1X-1XD is 4 steps of .5, as is XC-1A.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 03-30-2006, 09:40 PM   #3611
danjoy25's Avatar
Thanks Jam-ehz.
Are the stock toe blocks equivalent to 1A. Can anyone confirm this. What is also the reason with having inboard toe upfront when the steering links actual determines the toe adjustments.
Old 03-30-2006, 09:58 PM   #3612
Thanks Jam-ehz.
If you use the hinge pin carriers to put toe in the front what you are doing is giving the arm what they call a sweeping motion under compression......
Old 03-30-2006, 10:31 PM   #3613
MikeR's Avatar
=More aggressive mid corner steering.
Old 03-30-2006, 10:41 PM   #3614
Somthing I find the TA05 does not need..............
Old 03-30-2006, 11:14 PM   #3615
Regional Moderator
Darkseid's Avatar
I agree, I haven't found a need for anymore steering that the TA05 already delivers. This is while running foams on carpet though.
TLR 22...Tamiya F104...
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
