Like Tree2Likes
Old 03-26-2006, 10:53 PM   #3541
akuhon's Avatar
Hi all,
I plan to buy the new Lt weight reversible 53899. Is this option part, different from the ltwt reversible for TA04/TB02 ?
I mean the bearing size, etc..
I heard also that I need to buy the swing shaft separately for this new lt weight rev. unit ? Is it true ?
Thanks for the info.
akuhon is offline   Reply With Quote
Old 03-27-2006, 06:41 AM   #3542
Send a message via AIM to Bane
I beleive you will need the 48mm swingshafts with the Lt Wt Susp. Set. If you are running the stock arms then 46mm swingshafts. Others can confirm but I am pretty sure this is correct.
Bane is offline   Reply With Quote
Old 03-27-2006, 06:46 AM   #3543
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by Bane
I believe you will need the 48mm swing shafts with the Lt Wt Susp. Set. If you are running the stock arms then 46mm swing shafts. Others can confirm but I am pretty sure this is correct.
Bane:
I think I forgot to mention that you need to buy universals for your car also...............
I just weighed my TA05 with the stock suspension and the Graphite chassis and the car is only 5g. over R.O.A.R. legal weight .............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 03-27-2006, 09:38 AM   #3544
MikeR's Avatar
Trader Rating: 15 (100%+)
I think it depends on what blocks you use. I'm using some X blocks and the 46mm shafts are perfect with the lighweights. If you use D blocks you may need 48mm's.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-27-2006, 11:29 AM   #3545
Thanks Slot. Ordered them from Speedtech on Friday night and just waiting for confirmation. Ordered the precision diff joints, the uni's and the center diff bushings this go round. As soon as I get the "RC Budget" replenished I will get the rest that you suggested.
Old 03-27-2006, 11:32 AM   #3546
Hebiki's Avatar
Trader Rating: 26 (100%+)
mike... what happened saturday? i was looking forward to seeing your car run.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-27-2006, 12:33 PM   #3547
Scarab's Avatar
Thumbs up
This is what I've bought so far for my TA-05 that I plan on racing at TCS in GT2:
49360 Tamiya Ti Screw Kit
53526 Tamiya 3x23mm Titanium Turnbuckle Shafts
53571 Tamiya Florine Coated Threaded Shock Set
53601 Tamiya Low Friction 5mm turnbuckle ends
53845 Tamiya Carbon shock tower (front)
53846 Tamiya Carbon shock tower (rear)
53847 Tamiya 46mm Universal drive shaft (front or rear)
53848 Tamiya Aluminum Racing Steering Set
53882 Tamiya Carbon Mount Spacer for Damper Stay
53883 Tamiya Carbon Steering Plate (w/bearing & hardware)
53893 Tamiya Light Weight Carbon Chassis
Anything else you'd recommend?
Scarab
Scarab is offline   Reply With Quote
Old 03-27-2006, 02:02 PM   #3548
MikeR's Avatar
Yeah, had to baby sit Livin the good life
Old 03-27-2006, 07:17 PM   #3549
akuhon's Avatar
Thanks Bane, MikeR and Slotmachine.
I've found this Tamiya Univ 48mm :
53871 RC 48mm LW Rear Swing Shaft alum - blue (for rear)
53836 RC 48mm Swing Shafts - For Assembly Universal Shaft (for front)
Do you mean those 48mm parts ?
MikeR : I have some questions about X block and D block,
1. Is it part of TRF415 ..
2. I plan to use the graphite tube lower deck, do these block fit ?
3. Do you have any Tamiya part number for these blocks ?
4.
Any other blocks avalaible and can be used ? and what degree 'cause I also plan to buy
53807 RC TB-Evo4 Alu Right Upright - 0deg.
or
53784 RC TB-Evo4 Alu Right Upright - 1deg.
5. And are these for both front and rear suspension ?
Old 03-27-2006, 09:21 PM   #3550
MikeR's Avatar
Default You're welcome
4.
or
1. Yes, my blocks are all from the 415. Right now I'm using x, xc,xc,c from front to back with the 46mm bones.
2. Yes, but if you use all really narrow like xd, xc together it seems the arms hits up against the bulkheads- too narrow I guess. This goes for both tub chassis.
3 Speedtech- most are here in stock http://www.speedtechrc.com/store/ebp...?catmainid=269
4. I have been sticking w/ Tamiya only because of rules.
5 Ditto.
Looks like I can go up to A blocks but then I would be exceding the diffs...
Old 03-27-2006, 09:32 PM   #3551
TFR
TFR's Avatar
How about a picture of your whole car? Looks clean!
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 03-27-2006, 10:55 PM   #3552
MikeR's Avatar
The pics are about a page back but i think i sized them a little too small
Old 03-28-2006, 12:01 AM   #3553
teabag's Avatar
what 415 blocks would you use if you wanted to have the same setup as the plastic blocks the kit comes with?
teabag is offline   Reply With Quote
Old 03-28-2006, 02:08 AM   #3554
Can anyone tell me the part numbers of all the parts that make up a TA05 center layshaft?
Rick Draper is offline   Reply With Quote
Old 03-28-2006, 04:47 AM   #3555
zax
zax's Avatar
use 1A block from the 415...it is the same as the plastic block..
zax is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
