Like Tree2Likes
Old 03-20-2006, 07:25 AM   #3466
StoneMan's Avatar
Originally Posted by CIVIC91
Just run some shims in the front. The axles on the 05 are extra long, so you can put 1.5mm worth of shims on each side and then it should just clear the foams. I also shave just a hair off the outside ball cup for an extra 1/2 mm or so of clearance. I personally don't like cutting down 28mm foams to 26 or 27 to clear it. I run the 6mm aluminum hexes with a 0.5mm shim. The stock plastic hexes are 5mm.
The EVO IV upper ball studs are slightly lower and then cut off the top of the ball cap. You can use foams without the spacers
StoneMan is offline   Reply With Quote
Old 03-20-2006, 07:47 AM   #3467
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
I went a little crazy on my 415 suspension to skinny up the wheel track. the foams were slowly chewing through the ball cups, so i got out the trusty dremel, and cut off the top of the ballcup, and shaved the top off the ball stud itself. The link hasnt popped off at all, and i had a few incidents, and theres no rubbing on the foams at all. Plus it hasnt effected the movement of the suspension either.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-20-2006, 08:38 AM   #3468
Send a message via AIM to Bane
I'm considering picking up a TA05 and was wondering if some of you could tell me what are considered the "MUST HAVE" hop-ups. Part numbers if you know/have them readily availabel would be great but not necessary. I can do the homework.
Bane is offline   Reply With Quote
Old 03-20-2006, 11:41 AM   #3469
Regional Moderator
Darkseid's Avatar
Originally Posted by DA_cookie_monst
It will be fine, anything that makes it slippery, I have even used a little spit down the top of the tube at times, lol.
Man, that just does NOT sound right!
TLR 22...Tamiya F104...
Old 03-20-2006, 11:46 AM   #3470
OSherman's Avatar
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-20-2006, 11:47 AM   #3471
Regional Moderator
Darkseid's Avatar
Originally Posted by Seatbelt
Awesome darkseid. I thought about that, but is there any chance that the shock oil could interfere with the radio reception?
Nope, you'll be all good.
Also, an old school trick I forgot to mention is to run a line of sewing thread down the tube, then tie it(with as small a knot as possible) to the antenna, feed the antenna into the tube a little, the pull it through with the thread.
Either way works, but simply making the antenna slippery is much easier.
Old 03-20-2006, 11:52 AM   #3472
rayhuang's Avatar
Associated green slime or stealth lube has always been my choice for sticky antennae tubes.
Old 03-20-2006, 02:05 PM   #3473
That could just go SOOO wrong off-topic....
DA_cookie_monst is offline   Reply With Quote
Old 03-20-2006, 02:31 PM   #3474
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default TA05 gone wrong..
Also, an old school trick I forgot to mention is to run a line of sewing thread down the tube, then tie it (with as small a knot as possible)feed into the tube a little, the pull it through with the thread.
Either way works, but slippery is much easier.
go wrong like this quote above?
just messin with you Darkseid.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-20-2006, 10:42 PM   #3475
Regional Moderator
Darkseid's Avatar
Old 03-20-2006, 11:32 PM   #3476
I finished building my TA05 today (yay), but am in some trouble. I have found that the car doesnt really acclerate much, and also when the cars on an incline, the drivetrain will move, but the wheels do not. What's wrong with it? This is my first car.
Seatbelt is offline   Reply With Quote
Old 03-21-2006, 12:23 AM   #3477
m i g v e a's Avatar
well seatbelt, congrats on the build!!! first time building a kit? first of all , what motor , esc , rx , did you use? this way, the gurus will have a clearer picture. my first guess is you built the diffs too loose / tight. take em out and have a check. they should be tightened just right.
m i g v e a is offline   Reply With Quote
Old 03-21-2006, 06:08 AM   #3478
Ordered my TA05 last night and would like some info on the necessary hop-ups in your opinions PLEASE. Thanks!!!!
Old 03-21-2006, 06:29 AM   #3479
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Graphite shock towers, sway bars, Florine coated shocks, a selection of all of the really short mini cooper springs, front one way, center one way, spool and universals................You can wait till later to get the graphite chassis parts
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is online now   Reply With Quote
Old 03-21-2006, 07:39 AM   #3480
Thanks Slot!!!!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
