Like Tree2Likes
Old 03-09-2006, 11:01 AM   #3406
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by izzyracer
Hmm, I smell something fishy!
take a shower!
sherm... can i run with you and eeyan with a stock motor? i dont wanna beat up my TA05 with a 19T
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-09-2006, 12:06 PM   #3407
OSherman's Avatar
Thumbs up
Originally Posted by Hebiki
...sherm... can i run with you and eeyan with a stock motor? i dont wanna beat up my TA05 with a 19T ..
actually... last time i was running with Eeyan at Tamiya, i had an old YOK 'silver' 19t geared waaayy down while Eeyan was running a stocker.. we were about the same down the straight.. I felt i had a tad more punch though..
If you have the stock bearings in the TA05, you need to put a lil power through them to break/loosen them up..
don't matter to me though.. throw that GRAPH tub on and have some fun...
I love mine..
still got thos bridge blocks for me??..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-09-2006, 12:17 PM   #3408
Hebiki's Avatar
I love mine..
yup, sure do..... but i wont be at OC Circuit this month. if you need them for sunday, lmk..i can give them to CB. otherwise i can get them to you in april?
Hebiki Design Works
Old 03-09-2006, 12:28 PM   #3409
OSherman's Avatar
will probably run the LOSI at LaMirada. Will you be practicing at TAMIYA anytime soon??. That is really the only place that i run the TA05..
•KO Propo America
•EXOTEK
Old 03-10-2006, 01:09 AM   #3410
hi guys..any idea whats happening when the car keeps over-steering?
erric_13 is offline   Reply With Quote
Old 03-10-2006, 06:24 AM   #3411
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I have what I think is a good set up for asphalt with take off 32 rubber tires.........Go Here and click on the image for super sized to read it...........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 03-10-2006, 08:44 AM   #3412
Regional Moderator
Darkseid's Avatar
This car has a LOT of steering. So over-steer is likely what your going to be dealing with while trying to set it up to your liking. Before I started messing with the car, the first thing I did was dial back some of my dual rate. I often find myself running around 72%-78% on the dual rate, depending on how tight the track is.
So maybe you could dial back your dual rate a few clicks, to see if that calms down the over-steer, before you start changing the actual set up on the car.
If that doesn't work, you could try a couple other things to take away front steering and/or add rear traction. Adding a sway bar up front, adding droop to the rear, taking away droop up front, stiffer springs up front, softer springs in the rear, are just the beginning of what can be done.
Just remember, one change at a time.
TLR 22...Tamiya F104...
Old 03-10-2006, 08:54 AM   #3413
OSherman's Avatar
You may also want to play with the rear toe.. 1 degree is stock..
•KO Propo America
•EXOTEK
Old 03-10-2006, 09:02 AM   #3414
TRF415boy's Avatar
Swap your front hubs round, meaning put the C2 front hub on the left side and the C1 on the right. don't forget to re-set ride height, droop and to add 2mm spacers under the steering links ball joints on the steering rack's side.
I can GUARANTEE your car will have a lot less steering and will be a lot more consistant.
TRF415boy is offline   Reply With Quote
Old 03-10-2006, 09:39 AM   #3415
My stock rear hubs say 2 on them.................
Old 03-10-2006, 09:59 AM   #3416
OSherman's Avatar
hmm.. i wonder if my buddy sabotaged me.. .. got mine used, but never run..supposed to be stock..
or i could just me mistaken all together.. gett'n old..
•KO Propo America
•EXOTEK
Old 03-10-2006, 10:02 AM   #3417
OSherman's Avatar
Default I see you peeking...
SpeedTech..- I see you watching this board but rarely post.. what you got up your sleeve??..
Will you be getting those blue belts anytime soon??... I would love to have those.. as well as a few other goodies on my next order..
-O
•KO Propo America
•EXOTEK
Old 03-10-2006, 12:20 PM   #3418
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
The car comes stock with 2 degree rear hubs.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 03-11-2006, 09:44 AM   #3419
Here's my TA05, almost ready to race tonight.
It has the setup I mentioned in my previous post:
All box stock, except:
Hex screws replaced most of the stock screws (I had some blue aluminum and the rest are rcscrewz).
Shock oil is 70 front, 50 rear (1-hole pistons)
Novak GT7
BlueBird 621MG servo
Nomadio Sensor V2 transceiver (A bit big, but I don't mind it on the servo)
Purple foams rear, plaid front
Spacers for the tires so they don't rub the ballcups
Robinson super machined 104t spur with Robinson lightweight 31t pinion
Epic binary 27t stock motor
It'll have an old alpha body that I used on my TC3
The wires aren't pretty, but I usually have my cars like this - function over form for me
The suspension is more springy than I like, even with the thicker oil. We'll see how it goes.
Batfish is offline   Reply With Quote
Old 03-11-2006, 11:00 AM   #3420
Thats because the holes in the pistons for the plastic shocks are far bigger than the holes in the TRF pistons, so a cheap but effective upgrade would be a set of TRF white shock pistons.
DA_cookie_monst is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
