Like Tree2Likes
Old 02-18-2006, 11:00 PM   #3121
Regional Moderator
Darkseid's Avatar
Originally Posted by kgonder1969
anyone know of good shocks for the tamiya Calsonic Skyline GT-R 03 RTR that are adjustable and will mount right up to car without modifications? I need to lower the car to the ground, or so I was told. . Seems like if I run certain foams on it, then it rolls over in the turns and that is not good for winning any races. Just looking for suggestions so I can get it handling like I want it to.
Yes, the car does roll quite a bit, even with stiff springs. You might want to consider purchasing the swaybar kit.
TLR 22...Tamiya F104...
Old 02-19-2006, 06:18 AM   #3122
TRF415boy's Avatar
Originally Posted by westerdude42
It should just be big enough to provide stiffness and structural integerity.
What for ? the bulkheads does not need keying on the chassis, they are keyed by the countersink screws. The bulkheads will never move unless the screws are loose, this is not a place where tweak can occur, PERIOD. Not to mention your idea would be very costly (and unless I was going to make the C/F myself, impossible to do).
TRF415boy is offline   Reply With Quote
Old 02-19-2006, 08:04 AM   #3123
kufman's Avatar
this is the problem that I am seeing with the 3-racing chassis. The screws do come loose. Not enough to be seen, but if you try to tighten them with a wrench, they can be tightened. After I go through the whole car and tighten the screws, it is noticably stiffer. I am hoping that the hardened A-parts will help this problem. I hate to buy aluminum bulkheads for a $125 car (especially since they are $50 per). Maybe your chassis will not have this problem, but the 3-racing one does.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 02-19-2006, 08:10 AM   #3124
I realy do think leaving them plastic chassis braces in is pointless and just asking to flex and cause tweak. As for the screws coming loose, then thats the joy of the soft(ish) plastic of the bulkheads, you could always use a little low grip thread lock on the, though.
DA_cookie_monst is offline   Reply With Quote
Old 02-19-2006, 08:27 AM   #3125
TRF415boy's Avatar
I see your point, but then if you want a top end car with alloy bulkheads and everything, it'd be much cheaper to get one that comes with them, like an MSX... On the hardened plastic ones, if the plastic is like the one they usually have for all their TRF cars, it'll be very stiff. Also using regular M3 screws instead of the plastic screws will help keep them tight.
Old 02-19-2006, 02:45 PM   #3126
beerbarron's Avatar
I have some TA05 questions that I hope have'nt been answered too many times already. Sorry to just but in.
1. Do IB38's/42's fit the tub chassis correctly?
2. How does the box stock car do with foam tires on carpet ?
beerbarron is offline   Reply With Quote
Old 02-19-2006, 02:47 PM   #3127
GP37's fit in correctly, and as the GP43 uses the same basic case, they should fit to.
Foams... not got a clue.
Old 02-19-2006, 02:58 PM   #3128
beerbarron's Avatar
Thanks, I believe IB 38's and GP 37's were the same cell diameter.
Has anyone run this car on carpet with foams?
Old 02-19-2006, 03:08 PM   #3129
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Yep, it's awesome on the fuzz. Do yourself a favor though, if you are gonna run 19t or mod get the TECH RACING upper deck...it's like $20 and stiffens the car up just enough. It makes a big difference, but the car is still awesome stock.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 02-19-2006, 03:11 PM   #3130
Where can you get the TECH Racing stuff in the US? Thanks for your help by the way!
RCevolution is offline   Reply With Quote
Old 02-19-2006, 03:15 PM   #3131
beerbarron's Avatar
RCevolution Quote:
Yeah Thanks!
Old 02-19-2006, 04:45 PM   #3132
kufman's Avatar
here is a picture of my ta05.
3-racing chassis
tamiya front and rear shock towers
tamiya trf shocks
They fit, but it can be tight by the right side of the bulkhead that hold the spur gear shaft. Just make sure you don't have any extra solder sticking out on that battery joint.
Old 02-19-2006, 04:50 PM   #3133
Do a search on ebay for " TECH RACING TA05"...there is a guy that sells Tech stuff there...I think it's overseas, but I had no problems with him.
Old 02-19-2006, 07:24 PM   #3134
Formula1fan's Avatar
Do I need short or regular springs for my TA05?
Formula1fan is offline   Reply With Quote
Old 02-19-2006, 09:44 PM   #3135
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I run the super short mini cooper springs with much success..............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
