Like Tree2Likes
Old 02-17-2006, 09:57 AM   #3091
Problem is, if you don't mill out the material where the motor will sit, then the motor will sit on the chassis and possibly cause interference, I agree the endbell protector would be better, but this is the first chassis and do appreciate the input guys.
DA_cookie_monst is offline   Reply With Quote
Old 02-17-2006, 10:00 AM   #3092
cheehtae's Avatar
Trader Rating: 15 (100%+)
keep us updated, will there be a thicker chassis and top deck too? that would be great.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 02-17-2006, 10:04 AM   #3093
That all depends on the guy making them and whether there is enough interest. This is made from high grade Carbon Fibre, 2.5mm thick, and with the topdeck fitted, there is very little flex in the chassis at all, most of which comes from the diff bulkheads.
Only reason I done this, is as much as I like the one from Speedtech, I am not a fan of keeping the stock plastic chassis braces, I think they will be an inducer for tweak if anything.
The topdeck, I intend having the cutouts made smaller to leave a little more beef in thee. The Chassis is also designed to accept the Yokomo BD cell trays, so when new cells come out, they can be swapped over.
Old 02-17-2006, 10:58 AM   #3094
kufman's Avatar
The chassis looks pretty cool. The one thing that i thought of for the flat carbon chassis is what if you did some milling where the bulkheads bolt onto the chassis? That way they are keyed into the chassis like the stock setup. keep us informed with your progress.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 02-17-2006, 11:05 AM   #3095
If the chassis was made from thicker material, yes, but as it is, that would not leave much material UNDER the bulkheads to form the countersink etc..
Old 02-17-2006, 12:20 PM   #3096
westerdude42's Avatar
What about double or trippling the thickness in the areas by adding extra layers, then milling through that.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 02-17-2006, 01:02 PM   #3097
What would that gain and how would you 'make' the extra thickness.
Old 02-17-2006, 02:07 PM   #3098
moshmike's Avatar
Hey every one! I recently acquired a TA 05 to use for our TCS race in less than 3 weeks and was wondering if any one had a good starting point setup for a nearly box stock car on rubber and Fasttrack carpet. I will have the carbon shock towers and maybe a front one way? I usually ran the TA04R and have done very well with it in the past. I still have it and wonder if it's possible to get the 05 going better than the 04R. Any input will be helpfull!
Thanks!
Mike
Hope to see new faces at the Trackside TCS race this year! March 4+5!
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 02-17-2006, 03:09 PM   #3099
Steven Key's Avatar
moshmike Hey every one! I recently acquired a TA 05 to use for our TCS race in less than 3 weeks
Mike, I would be happy to share my vast knowledge of TA05 set up with you.
Steven Key is offline   Reply With Quote
Old 02-17-2006, 03:38 PM   #3100
TRF415boy's Avatar
I'm not going to do that for simple reasons : 1st the bulkheads are fixed on the chassis by countersunk screws, unlike with the plastic chassis, so there would be a conflict if i was to key them, 2nd is it would add to the cost, 3rd is it would change the drivetrain's height (and subsequently the part where the top deck fixes onto the bulkhead won't be at proper height anymore).
TRF415boy is offline   Reply With Quote
Old 02-17-2006, 03:40 PM   #3101
TRF415boy's Avatar
I don't get what you mean, but I see no reason of doing so, and no way of doing it in a financially efficient manner.
Old 02-17-2006, 05:36 PM   #3102
If you just thicken under the bulkeds then you could mill down and brace without giving up structural integerity.
Hedgehogs rule!!!
Old 02-17-2006, 05:47 PM   #3103
How do you do that though, machine a second peice of material to sit on the chassis, then you got to fixe that peice of meterial to or you have a thicker chassis and machine the whole lot.
It just isn't practical to be honest.
Old 02-17-2006, 06:14 PM   #3104
Laminate a second smaller peice to the deck.
Hedgehogs rule!!!
Old 02-17-2006, 06:16 PM   #3105
It should just be big enough to provide stiffness and structural integerity.
Hedgehogs rule!!!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
