Like Tree2Likes
Old 02-12-2006, 11:28 PM   #3031
Xcal's Avatar
Send a message via ICQ to Xcal Send a message via AIM to Xcal Send a message via MSN to Xcal
Just wondering what is the difference between the stock, 64 and 48 pitch gears.
Thanks.
Xcal is offline   Reply With Quote
Old 02-13-2006, 05:40 AM   #3032
kufman's Avatar
They just have different size teeth. 64 pitch has the smallest teeth and most people will claim they are the most efficient. The stock gears are .6 module (kind of like metric 48 pitch) and only work with those pinions. 64 pitch is the most common for onroad (in the states atleast) and 48 is popular for offroad. I ran 48 pitch onroad for many years and still do in certain situations (outdoors).
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 02-13-2006, 06:50 AM   #3033
Regional Moderator
Darkseid's Avatar
Originally Posted by A-Ko
Usually tracks disappear from employee/owner burn-out, mis-managed tracks or too many tracks to support a small populous of racers. There is nothing wrong with buying online or searching out better deals.
Sure I try and give my LHS or track my business if they can come close to some of the best deals on products. I am not going to kiss my brains away supporting full list prices when I can get them 30% to 50% off elsewhere. For some guys money does not matter, for me I have to watch what I spend.
I did buy my latest car a month ago at my local track. My hopup parts I did buy mostly from Hong Kong or Japan with a few from my LHS. Everyone has an opinion or situation they work within. There are as well many other threads that re-hashed this same topic. This is not one of them.
Couldn't have said it better myself!
TLR 22...Tamiya F104...
Old 02-13-2006, 06:51 AM   #3034
Regional Moderator
Darkseid's Avatar
Originally Posted by erric_13
the novak brushless gtb fits the ta05 to a tee, with no freeplay in 1 area.
Got any pics?
Old 02-13-2006, 10:36 AM   #3035
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by Slotmachine
I bought a center 1 way , I used it for about 5 packs and now it is not working ( free spins) any one else had a problem with them? I`m kinda pissed off this thing was not cheap!
hi, i used it for about 3 months (obviously more than 5 packs), and it still spins nicely, you might want to check for any binds. especially if you are still using the plastic hex wheel hub, it might bind and scrubbing against your bearing when you overtighten the wheels.
dodo is offline   Reply With Quote
Old 02-13-2006, 10:48 AM   #3036
cheehtae's Avatar
Trader Rating: 15 (100%+)
will the new CO27 and KOS motor be legal to run in the TCS?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 02-13-2006, 11:03 AM   #3037
TaJoe5's Avatar
Send a message via AIM to TaJoe5
TA05 + GTB + 6.5 Brushless motor = streched belts after 2 runs
Joe
TaJoe5 is offline   Reply With Quote
Old 02-13-2006, 11:22 AM   #3038
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by Darkseid
Is there anyone out there that currently has a brushless system installed in their TA05?
I'm looking to see a picture of either a mounted up Novak GTB system or LRP Sphere/Neo setup.
Mainly, I want to be sure that the GTB or Sphere would even fit in the space provided for the esc in this car. I measured another racers GTB and it seems as though it would fit, but I'd like to be sure. The Sphere seems a little large though.
So again, if anyone has mounted up one of these systems in the TA05, post a pic for me.
Darkseid
Here you go - fits fine
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 02-13-2006, 04:33 PM   #3039
BigRon's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to BigRon
Default Ball Cups
Anybody having trouble with the front ball cups popping off quite easilly? I know the obvious solution to this would be to not hit anything but still to me its a little too easy to pop them off.
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 02-13-2006, 05:31 PM   #3040
POOKYT's Avatar
This goes for all ball cups.........If it pops off once then pop it back on...........If it pops off twice then replace it because it has stretched and will never be strong again. Good Luck!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 02-13-2006, 05:32 PM   #3041
Hey axle182...what kind of foams are those? and did you need to make any mods to run them? I just built a new TA05 and tried putting some foams on, the rears were OK but the fronts, even trimmed to 26mm, come very close to the cabmer link. Also, any tips for carpet running on foams ?
Thanks!
RCevolution is offline   Reply With Quote
Old 02-13-2006, 05:37 PM   #3042
Juan Valdez's Avatar
Hey guys. I've got a couple questions.
First, does anyone know how much aramid belts fee up the drive train of this car? Is it a significant amount?
And second, any one have any setups posted for the stock suspension on the TA05? I've seen one or two with the LW suspenstion, but not much with the stock stuff. If anyone has one to post, I'd appreciate it.
Thanks!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 02-13-2006, 05:49 PM   #3043
POOKYT's Avatar
Thanks!
I had the same experience. I posted in here a few weeks ago and the solution seems to be running the 6mm hex's. Hope this helps.
Brant
Old 02-13-2006, 06:13 PM   #3044
Brant
Will that widen the car up past 190mm? Looks like I gotta get me some o' them 6mm hexes
Thanks POOKYT
Old 02-13-2006, 06:21 PM   #3045
Regional Moderator
Darkseid's Avatar
Joe
ooookayyyyy.....
I'm sure that fits into my "does it fit" question some how, but I must have missed it.
Thanks for the information though...
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
