Like Tree2Likes
Old 02-08-2006, 10:07 PM   #2956
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by cheehtae
spring questions:
I usually run foam tires never rubber, but this coming TCS I'll be running rubber tires, what would be the height difference if your going to put in the shorty springs?(currently I'm using the longer versions and switching from foam to rubber made a 3mm. height increase)
What else should I do to keep the height lower?(I tried putting in 2 O rings inside the shocks)
Thanks in advance.
If you want to use standard springs from your current selection you could try the 1mm drop down collars for the shock bottoms. For asphalt you don't want to drop down too much anyways- not as much as carpet I mean. You could use the new springs of coarse since they seem about 3mm shorter but there isn't much tuning selection compared to other regular springs.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-08-2006, 10:34 PM   #2957
Slotmachine's Avatar
Send a message via MSN to Slotmachine
The new package of all white springs is the same as the tuned hard spring set. The whites are a special set done for Japan only until now. At least that is the way I hear it............
I`m using the standard on road yellows and I run 6mm rear height and 5.5mm in the front with no problems on asphalt.
Paul.................
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-08-2006, 10:56 PM   #2958
sup
sup's Avatar
tnx slotmachine for the info on screws.
sup is offline   Reply With Quote
Old 02-08-2006, 11:11 PM   #2959
f2000racer's Avatar
Sorry guys, just a bit off topic, but it's for my TA05.
I was in the market for 64p spur and I was told that the standard ratio calculation found in the manual can't be used to calculate when using 64p gearing.
Can anyone enlighten me on this
Thanks!
Roy
Tamiya F103RM
Tamiya Mini
Tamiya TA05
f2000racer is offline   Reply With Quote
Old 02-08-2006, 11:26 PM   #2960
maxepower's Avatar
Thanks!
Roy
Spur divided by pinion times the variable 2.25 = final gear ratio!
The variable should never change!
I hope that is what you wanted to know!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-08-2006, 11:26 PM   #2961
Thanks!
Roy
The internal ratio is always 2.25 to 1 no matter what spur gear you use. Click on the link in my Signature that says gear chart and print one out for your car............
Old 02-08-2006, 11:28 PM   #2962
I see you beat me to it Max, its hard to keep up typing with 1 hand...
Old 02-08-2006, 11:30 PM   #2963
Cheap Titanium Turnbuckles
Old 02-09-2006, 12:02 AM   #2964
f2000racer's Avatar
So it's the same calculation then.
Any spur/pinion combo for stock and 19T?
Thanks man.
Tamiya F103RM
Tamiya Mini
Tamiya TA05
Old 02-09-2006, 12:49 AM   #2965
maxepower's Avatar
Talking SPUR-PINION COMBO!
Thanks man.
I think the biggest 64 pitch spur that will fit is 104 teeth!
Other than that, NO PROBLEM!!
Old 02-09-2006, 12:52 AM   #2966
linger's Avatar
Originally Posted by zipp
after some careful observation, i actually think that the silver kit springs are even stiffer than the blues!
comparison between silver, yellow and blue springs:
coil diameter: 1.4mm
coils: yellow - just short of 7
blue - 6.3 approx.
silver - 6
moreover, the silver springs are slightly narrower in terms of spring width, averaging 15.8mm compared to 16mm of the yellow and blue. and we all know a narrower spring=less coils=stiffer
disclaimer: this is just my observation!! tamiya may have used a different metal in the kit springs for all i know!
The kit silver spring has the same coil count and same diameter as the Tamiya White spring (not yellow). The only difference is the ground ends on the Tamiya white. The lack of ground ends makes the silver spring a hair stiffer than white. I prefer not to use the silver springs since the non-gound ends tend to get caught up on the lower spring perch slot - as you turn the spring, it moves up/down - which is not ideal. The actual measurements are:
Purple 22.72
Gray 20.91
White Short 17.54
Silver 16.13
Blue Short 15.69
White 15.27
Blue 14.08
Yellow Short 13.99
Yellow 13.33
Red Short 12.35
Red 11.86
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 02-09-2006, 12:53 AM   #2967
The biggest i have tried is a 106 and that was just barely inside the chassis. The 105 is probably the safest bet. Tamiya makes a 105 for the TA05 which at 0.4 module size is slightly smaller than a 106 only.
Cheers
viper1 is offline   Reply With Quote
Old 02-09-2006, 12:57 AM   #2968
linger's Avatar
Originally Posted by Difuser
Zipp what you don't have in the equation is the wire diameter. While the coil diameter and less coils all change properties, what really changes is the rate. The silver will be "less progressive" the spring rate will actually stiffen faster with the less coils even though both springs might have the same weight rating. Remember spring "rate" is load increase over a given distance. so a 10lb spring might equal 1" movement and the load increase is 10lb over that given 1". Simple explanation but you get the idea.
So how all that relates would be that initial tension on the silver might be lighter but as the car rolls the spring ramp would be quicker.
Hey Dan!
All the tamyia springs measure pretty friggin linear. The initial 0-0.2 lb worth of travel is non-linear due to the ground ends and the different coil pitch at the ends. But other than that, all the tamiya springs are completely linear when compressed up to half their original free length. They all follow the general F-Kx equation very well.
Old 02-09-2006, 02:24 AM   #2969
zipp's Avatar
Originally Posted by linger
Purple 22.72
Gray 20.91
White Short 17.54
Silver 16.13
Blue Short 15.69
White 15.27
Blue 14.08
Yellow Short 13.99
Yellow 13.33
Red Short 12.35
Red 11.86
WOW!! been lookin for that all the while! thanks linger, that's some good stuff.
so i see the silver springs are indeed quite stiff eh? hmmm... think i may have gotten the carpet spec ta05...
zipp is offline   Reply With Quote
Old 02-09-2006, 07:08 AM   #2970
cheehtae's Avatar
It's a rubber/carpet track
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
