Like Tree2Likes
Old 02-07-2006, 03:41 PM   #2926
RCGaryK's Avatar
2-2.5, ok, but not 3-3.5. That's excessive was all I was saying.
I always ran my 04 with .5-1 degrees of rear toe. But that car also had more weight towards the rear of the car too.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-07-2006, 03:47 PM   #2927
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Im currently running 1 deg on my 05 and 1.5 on my 415, foams on carpet. back end is predictable, but not stuck, which is needed as we have a tight track. on an open track, im guessing id be needing more.
Just ordered a stack of toe blocks from the 415. ill start to make some changes to see what effects there is on foams.
Also someone mentioned that skinnier suspension (using the x blocks etc) makes the car quicker in turns? this true? Im still using a-a's on the 05 and out to b-c-d on the 415. should i switch to the x blocks?
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 02-07-2006, 03:48 PM   #2928
MikeR's Avatar
Trader Rating: 15 (100%+)
Just so I feel better about not being able to run 1deg toe myself I checked out set up sheets for these top drivers carpet/foam set ups;
Mike Dumas= 2deg (won Novak)
Jilles Groskamp= 3deg (DHI set up)
Martin Hudy= 3deg
MikeBlackstock= 2deg
I would put Marc R's but he doesn't write down his set-ups
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-07-2006, 03:55 PM   #2929
RCGaryK's Avatar
Martin Hudy= 3deg
Dumas- Mod Foam
Groskamp- Mod Rubber
Hudy- Mod Foam
Blackstock- Mod/19T Foam
I'm talking about gt3/2 too which makes a difference too...
HorizonHobby.Com
Old 02-07-2006, 03:56 PM   #2930
westerdude42's Avatar
You should consult the R/C touring car bible. That's right the XXXmain Touring Car setup guide. It's a great piece of reference materiel and will give you the tweaks in the order you should try them.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 02-07-2006, 03:59 PM   #2931
MikeR's Avatar
Originally Posted by RCGaryK
Dumas- Mod Foam
Hudy- Mod Foam
But these guys are Dumas, Groskamp and Blackstock
Even my Mabuchi powered Nats winning 04 had 2.5deg toe on that wide open high bite Tamiya track.
I understand your theory and about 4 years ago I subscribed to the same camp- but I learned the hard way
Old 02-07-2006, 04:05 PM   #2932
maxepower's Avatar
Cool "With a grain of Salt"
Sorry if you think my conclusions are wrong, I'm just trying to help you in your quest for the perfect set-up.
The TA04 is a completely different animal and should be left at that!
My set-up on the 05 was based on the (MS) set-up that Tamiya's factory drivers used and this has been a good base set-up for me with minor adjustments for fine tuning the car. Like I said this isn't the best set-up for all applications but it works for me and several other racers out here!
It's not a matter of who's set-up is wrong or right, it's about sharing ideas on this forum because we all have the same thing in common.
I'm looking forward to TCS and hope to see you there in the Finals!
I say, let our cars do the talking and lets see who has the best set-up!
CHEERS!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-07-2006, 04:08 PM   #2933
Hebiki's Avatar
Trader Rating: 26 (100%+)
give a man a fish..and he eats for a day. teach him how to fish, and he eats for a lifetime.
MikeR: please explain (the theory behind) why more rear toe will give you more corner speed? (not trying to be a smart ass, i just want to learn how to fish here )
thanks dude.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-07-2006, 04:11 PM   #2934
axle182's Avatar
Martin Hudy= 3deg
As Gary said these were from mod drivers, and on much larger tracks than im currently running on. our track is very tight which is why i like the car to rotate quickly, and running stock motors. im still learning how to get it to rotate quickly, but so far 1 deg on the rear is the best thing ive changed. Small adjustments in roll centres (top links) is the only other thing ive changed.
too make matters worse, our track is also very bumpy, so im still messing with shock setups. My s/h 415 came with 4 TRF shock sets so ive set myself up with 4 different combinations of oils and shock springs.
Aaron "AJ" Freind
Old 02-07-2006, 04:24 PM   #2935
maxepower's Avatar
Talking I think your going to need a bigger pole!!!!!! Quote: The movie "JAWS"
thanks dude.
Chris,
The first thing you need to do is buy a good pole! That brand "X" ray your using now wouldn't catch a sardine!!!!
Old 02-07-2006, 04:49 PM   #2936
Hebiki's Avatar
Originally Posted by maxepower
Chris,
believe it or not max.. im coming back home.. just looking for an MSX now.
Hebiki Design Works
Old 02-07-2006, 04:51 PM   #2937
Kevin CBR's Avatar
Mike R - I think you need to come up to La Mirada this Sunday and give us a "toe" clinic.
Hebiki - I think Mike's set-up's only work on Tamiya cars. Not some "X" brand like you have now.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 02-07-2006, 07:55 PM   #2938
MikeR's Avatar
Smile
thanks dude.
With everything it is relative- and I can talk about slip angles and friction but I base my theory on a tight heat race while too many base it on
practicing hot laps. My theory is simple really- the less time you are in the corner the faster your corner speed. If you run enough rear toe that you can dive in strong and punch the throttle sooner coming out because of STABILITY the less time you are techinically in the corner. I mean come on- how many times have we passed cars in the corner because they geeked it? Lots! Why? Because their car isn't stable enough in the corner. And why do we pass cars on the straight? Because the more hooked up car coming out of the corner sets up the straights and hits max rpm sooner than the car that had to 'tip toe' through the corner.
btw-I run with 2.5deg of rear toe for stability and .5deg of front toe out if I need more initial steering with a 19turn.
Yo Kev- yes I'll be at La Mirada this week
Old 02-07-2006, 08:12 PM   #2939
MikeR's Avatar
Originally Posted by axle182
As Gary said these were from mod drivers.
You can lead a horse to water but you can't make it drink
Alexander Lopez= 2deg stock&19
Peter Robinson= 2deg stock&19
Don't make me find the jeff Cuffs set up!
Old 02-07-2006, 09:03 PM   #2940
zipp's Avatar
actually.. the silver KIT springs a "tad" stiffer than the yellow (tested by 2004 GT1 National Champ - Ling Kang Tong). the silver kit springs have a full coil, while the yellow ones are ground down so they sit flat.
after some careful observation, i actually think that the silver kit springs are even stiffer than the blues!
comparison between silver, yellow and blue springs:
coil diameter: 1.4mm
coils: yellow - just short of 7
blue - 6.3 approx.
silver - 6
moreover, the silver springs are slightly narrower in terms of spring width, averaging 15.8mm compared to 16mm of the yellow and blue. and we all know a narrower spring=less coils=stiffer
disclaimer: this is just my observation!! tamiya may have used a different metal in the kit springs for all i know!
zipp is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
