Like Tree2Likes
Old 02-06-2006, 04:36 PM   #2911
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Around the 3rd week of Feb.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 02-06-2006, 05:22 PM   #2912
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RCGaryK
Well, to be honest, It's pushing and it's loose. I think part of it is just the fact that you cannot get enough mechanical steering throw out of the car too, but it was pushy at low speed
Hey Gary,
I'm no carpet racer but it sounds like you just don't have any traction at all. You can try what the guys here have mentioned but also try to get your car to weight transfer more (more body roll). That means softer shocks all around and/or more droop front and back. Washing out on power means you need more front droop- lets the weight rotate to the back when you get on throttle. Pushing off power means you don't have enough droop in back- the weight isn't shifting to the front tires.
Hard to tell without knowing your set up though... what are you running anyway?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-06-2006, 05:30 PM   #2913
MikeR's Avatar
Originally Posted by OSherman
Anyone know when the Graphite Chassis (and other plastic parts) will be available??
-O
Got you covered
Old 02-06-2006, 05:59 PM   #2914
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by MikeR
Got you covered
mid feb for the parts... late march for the tub.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-06-2006, 06:33 PM   #2915
POOKYT's Avatar
Originally Posted by Turbonium
sup Billy? i have one here.. if you get a chance to get up here, i can show it to ya. i did buy the Xenon chassis, but havent installed yet... actually, i put it on, then reassembled with the tub for TCS use in April...
April is right my man!!!! I think we could get the 05 around the track and run in GT1 over here. I would love to bang the guys around in a carbon chassis car. Lutz and Dynoman would CRY!!!!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 02-06-2006, 09:56 PM   #2916
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Hello people:
I`m looking for a rebuild kit for shock`s, # 53571 What I need is the plastic parts. Mainly the cap eyelets and the thumb screw adjusters. Any ideas?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-06-2006, 10:15 PM   #2917
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Brant
no joke!!! i did run mine in the saturday club race with 19T.. not bad, considering i had just barely gotten the car in time to assemble before we left!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-06-2006, 10:20 PM   #2918
POOKYT's Avatar
Don't you think we can do it? Carbon chassis and good shocks? With running it Sat at this years club race I bet we can tune them in like Butter!!! The X-Ray cars have always run good at our track with the flex in their chassis. I'm really thinking Front and center one-ways with carbon towers and chassis plus the good shocks could be the ticket! I dunno.........maybe I'm full of crap too!! LOL
Brant
Old 02-07-2006, 09:02 AM   #2919
RCGaryK's Avatar
Hey Gary,
I don’t think it’s a droop issue…tried from 2mm over ride height to 4mm over ride height and everything in between and it still did the same thing. I had softened the chassis up and it rolled more, lost more corner speed and added .3-.5 seconds to each lap. Here’s roughly what I’m running with the LW arms
Front:
60wt oil-3 hole pistons
Blue spring
Red bar
Top of shock mounted 1 hole in from all the way out on graphite tower
Bottom of shock mounted in middle of the 3 hole side of arms
4-deg front uprights
Rear ackerman position
Front one-way
1XB front block, 1XD rear block
no kickup
1mm shim in front of arms, arms shimmed forward
Rear:
40WT oil- 3 hole pistons
Yellow springs
Red bar
Top of shock 2 holes in from all the way out in tower
Bottom of shock middle hole
Aluminum 0-deg rear hub carriers
1XC front block, 1XA rear block for 1 deg rear toe total
1.5mm shim in front of arm, arms shimmed forward
Tamiya A’s w/Tamiya Black inserts
0-offset rims
5mm hubs
Red and blue wheel shims
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-07-2006, 09:06 AM   #2920
it sounds like you have gone to far standing your shocks up. I personaly run the two hole pistons all round with 50wt front and 40wt rear, red sway bars all round. although I may go up to the next roll bar as it pitches TO far in a corner.
One thing I did find, with the control tyre we use, on stock 24mm rims, the tyres moved o much which made for some 'interesting' handling. After going to inch-up 26mm rims to stretch and flatten the tyre, and run hard inserts, it is dialed.
DA_cookie_monst is offline   Reply With Quote
Old 02-07-2006, 11:35 AM   #2921
westerdude42's Avatar
Yea dude, I'm actually laid over all the way, running 40 weight all the way around with yellow springs and 3holes. I took off the bars completely.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 02-07-2006, 12:49 PM   #2922
maxepower's Avatar
Unhappy Handling issues!
Hi Gary,
I run mostly at the Tamiya track here in Aliso Viejo and run some club racing indoor asphalt. Been running Tamiya cars for the past 5 years and I don't claim to be an expert so take my suggestions with a grain of salt!
My TA05 works good in outdoors and indoors with low and high grip tracks.
The indoor being high and right now at the Tamiya track is low to medium traction.
Anyway, I've ran stock and 19 turn motors in my car and both work very well ,except the 19turn does make the car a little twitchy if you know what I mean.
All your settings look good and with the TA05 there are a lot of set-up that work, you obviously have a lot of hop ups and want to get the most out of your car. I too have the LW suspension and a lot of blue included with the LW.
All I can see that I might suggest is running a lot more toe-in. I'm running 3 to 3.5 degrees toe depending on track conditions, but never any less than that.
I think that would help a lot in the rear traction issue but not sure what the problem is in the front.
Another thing is Tamiya tires can be unpredictable, I've used A's,B's,B2's,B3's etc, etc. and the performance of the tires are not very consistant. I've tried thin superthin ,hard super hard soft medium etc, etc, on the inserts and they still aren't consistant from one set to the other. I know in TCS we have to use them and we have to find a reliable set up for them but this issue is a real headbanger. Unfortunately, I have no suggestions on this issue. Sorry! Still trying to find my own tire combo!
I'm sure you've already checked but I have to ask! The tweak on the car, I mean this by using a tweak station you know the one with the bars and the bubble. After setting ride height, camber, toe then set it up on the tweak station and see if there is something going on there.
I'm wondering if your chassis is permanently tweaked. After all it's only plastic and I know of a couple of guys who have already replaced their chassis and they did this after the handling started going bad on them and no changes were made to cause this. Then they said it was perfect, so this tells me that the chassis are going bad after time or just one too many hard hits!
This is a cheap fix, I believe it's only $7-$10 for a new chassis. So it will not break you!
I hope I've been of some help!
Good Luck and don't forget to HAVE FUN!
P.S. TRF RACER on page 423 in the 415 thread has some interesting suggestions on set up for carpet. Might want to read that, it will pertain to the TA05 also!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-07-2006, 01:02 PM   #2923
maxepower's Avatar
Tamiya tire issues!!!
Interesting suggestion, I might try this! Is this for carpet or asphalt?
Old 02-07-2006, 01:38 PM   #2924
RCGaryK's Avatar
Originally Posted by maxepower
Hi Gary,
I've run at TA for the Nats since 99 and have found that what has worked on carpet here does not translate to out there. I have finshed in the top 7 5 times in that time, including including 4 top 5 finishes. I would honestly never run that much toe in the back; If you need to run more than 2-2.5 degrees something's seriously wrong setup wise and you're scrubbing waaaaay too much speed on the straight away. The car is not tweaked and the droop settings are consistent from left to right. I also have to disagree with you in that I feel Tamiya Tires are very consistent from set to set, but then again I have an insert combo that has suited me well for some time. Again at a regional level on carpet I have made the A-main every time in every class I've run except once, and have yet (knock on wood) to miss the show in the GT classes and have multiple class TQ's and wins. I appreciate your feedback, but disagree with your conclusions.
HorizonHobby.Com
Old 02-07-2006, 03:30 PM   #2925
MikeR's Avatar
Front:
Blue spring
Red bar
Front one-way
no kickup
Rear:
Yellow springs
Red bar
0-offset rims
5mm hubs
I disagree.....
1XC front block, 1XA rear block for 1 deg rear toe total- You should be running atleast -2.5deg toe in. More toe= more cornerspeed. Everyone that is a mere mortal driver (that includes me!) must drive with atleast 2deg of toe with 2.5 being optimal. Cars just reacts much crisper, go where you tell it and allows you to jump on the throttle setting up straights. I guarantee the car is already scrubbing speed on the straight anyway because it is lacking the grip generated by the rear toe.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
