Like Tree2Likes
Old 02-05-2006, 05:33 PM   #2881
quantum's Avatar
Originally Posted by StadiumChris
So what I need is..
2 - Bridged A mounts
2 - regular A mounts
correct?
I also notice toe-in in the rear, I'm assuming the hub is toed-in?
thanks...
yes the rear hubs are 2 degrees. it is marked right on the hub (just under the inside bearing.
as for the suspension blocks, if you refer to the instruction manual, at the bottom left of pg 6 it details the kit and option parts.
quantum is offline   Reply With Quote
Old 02-05-2006, 05:39 PM   #2882
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jam-ehz
The silver kit springs are Yellows, what you get from the On-Road Tuned set.
Above the whites, are charcoal grey (Super Hard) and Maroon (Ultra Hard). Not sure if they have a copper..
actually.. the silver KIT springs a "tad" stiffer than the yellow (tested by 2004 GT1 National Champ - Ling Kang Tong). the silver kit springs have a full coil, while the yellow ones are ground down so they sit flat.
any of the blocks can also be flipped upside down to be used as a "bridge" block. just need the 3mm spacers.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-05-2006, 05:48 PM   #2883
rayman's Avatar
Yup, I notice the silver are stiffer. It was bouncy for the track so I switched to yellows. Now I placed a swaybar in front from an mo3 chassis(it fits so why not ). Hopefully it will remove body roll and wont understeer too much.
rayman is offline   Reply With Quote
Old 02-05-2006, 06:18 PM   #2884
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by Juan Aveytia
I have a 3racing 3 mill chassis for sale for the ta05. Only $60.00 shipped. It retailes for around $110.00. Comes with blue tamiya color standoffs. keyed aluminum motor mount, If you go to 3racing.com.hk you can see the chassis. I drove it on carpet, for only one practice day. I decided to unload all of my rc stuff. I've got a brand new 415MS, which was only run at the reedy race last year for sale also. The only problem I had with the 3racing chassis was when I was building it. The top deck when tightend down, put pressure on the spur gear bearings. I had to dremell part of the graphite, so it would unbind the bearing. I went a hair to far, now there's a little play. But, works perfect. I also have a never opened, with the plastic still around the box TB02 for sale. Make an offer.
for future 3racing chassis owner, it actually rub against the spur gear holder slightly, you just need to file down a bit on the inner part of the top deck that faces the spur gear holder.
dodo is offline   Reply With Quote
Old 02-05-2006, 06:50 PM   #2885
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Ahh, I knew there was something different.. couldn't put my finger on it.. but yeah, the ends are indeed shaved.. heh..
I just did the "place them end-to-end and squeeze" test.. heheh.. they seemed to compress the same to me
With the blocks, I only have X blocks, which happen to come with the spacers.. do the A-D blocks come with them too?
I'm thinking the new 1E block will, seeming to be marketed as a TA05 hop-up, but is there a real need for an E block?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 02-05-2006, 06:54 PM   #2886
Trader Rating: 114 (100%+)
Thanks for the info.. but I am looking right at page 6 of my manual and it does not show anything about a kit nor option parts.. it is a step to start installing the suspension arms and one plastic block, but it has no other details... possibly I have an older manual???
Chris Furman is offline   Reply With Quote
Old 02-05-2006, 07:10 PM   #2887
*mini*racer*'s Avatar
Hi all, just started club racing my TA05 2 weeks ago and I love the balance of this car. very easy to drive. Im a newbee to the TA05 so do not no what parts are interchange with other Tamiya cars.
will this part work with a TA05,Tamiya (#53866) TRF415MS/EVO IV Pro Module Rear Suspension Set.
Thanks all.
*mini*racer* is offline   Reply With Quote
Old 02-05-2006, 09:02 PM   #2888
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Thanks all.
Should work.
tamiyarcracer is offline   Reply With Quote
Old 02-06-2006, 07:40 AM   #2889
Send a message via AIM to GroffBall
Thanks all.
Hey man... I wouldn't get that if I was you. Stick with the old style suspension till you can run at least one run without hitting anything and then pick up the lightweight suspension conversion. Nobody around here runs the Pro Module rear so that means no help.... By the way its Matt I pitted next to you the other week.
GroffBall is offline   Reply With Quote
Old 02-06-2006, 07:46 AM   #2890
RCGaryK's Avatar
fOK guys, looking for some setup advice here. Ran yesterday on carpet with A's. Mid-to exit of the corner the rear end would square up really hard to the point of wanting to wash out on exit. I'm using the Aluminum hubs that come with the 415 worlds update kit and the ballstud is closest to the chassis. I'm thinking about moving to the middle hole in the hub and possibly adding some anti-squat to the rear end. Sound like the right move?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-06-2006, 07:55 AM   #2891
Moving the stud out sounds like the right move, but not the anti squat, that will give it more high speed steering.
Old 02-06-2006, 07:58 AM   #2892
RCGaryK's Avatar
Well, to be honest, It's pushing and it's loose. I think part of it is just the fact that you cannot get enough mechanical steering throw out of the car too, but it was pushy at low speed
HorizonHobby.Com
Old 02-06-2006, 08:06 AM   #2893
This car has more steering than any car I've ever driven, steering wise it beats my 415 hands down. Sounds like you just need to increase the cars roll by either softening the suspension or playing with roll centers.
You wouldn't happen to be running the spool would you?
Old 02-06-2006, 08:11 AM   #2894
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I have been watching this thread and developed an interest in this car. Is there already a cf chassis conversion out for this car and if so how much? Also, what adjustment or strengthening goodies are recommended? I would be using this car for concrete and some carpet.
Thanks for yall's time
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 02-06-2006, 08:22 AM   #2895
RCGaryK's Avatar
Nope, double one-way. From my experience Carpet+rubber tires=spool= evil bad
HorizonHobby.Com
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
