Like Tree2Likes
Old 01-30-2006, 08:37 AM   #2746
m i g v e a's Avatar
Originally Posted by sup
miguel, our lhs does not have the short white springs in stock right now. is your car setup the stock one? did you experience understeer at the 2nd to the last corner before the straight? just wondering, coz mine had heavy understeer at speedzone. but, when i installed the swaybars (swaybar setup of dong), it was replaced with little oversteer. maybe its my tires as i am using cs37s and med inserts.. will try sorex 36s when it wears out. see you at the tracks!
Sup, generally, use sorex 40s during the day and 36s at night with medium inserts. As for the springs, i guess the blue ones all around will work fine. Have you checked your droop settings? it might help to check if they are consistent from left to right, front and rear. That said, I experienced the same thing at first, but then it turned out to be just a case of going too fast too early! thus running outside the racing line.. See you bro!
Westerdude, will do. I will let you know when I try it out!
m i g v e a is offline   Reply With Quote
Old 01-30-2006, 10:47 AM   #2747
Regional Moderator
Darkseid's Avatar
Originally Posted by POOKYT
LOL So, I did all I knew to do and cut( in Darkseid tradition)
Brant
Yeah, but isn't it sad that this $130 car requires less cutting than my $370 Losi did....
Darkseid--What is the number for the 6mm hex's? Or doyou mean the aluminum ones? Thanks guys
Brant
Yeah, I was talking about the aluminum ones. But if your son is just running silver can novice, simply cutting the wheels is probably an easier/lighter/cheaper option. But, if you do decide to go with them, the part# is 53569
TLR 22...Tamiya F104...
Old 01-30-2006, 11:46 AM   #2748
BigRon's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to BigRon
I see that TCS rules allow the TRF415 suspension blocks. Other that being aluminum, what's the plus side?
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 01-30-2006, 11:48 AM   #2749
RCGaryK's Avatar
You can use them to change the inboard toe and front arm sweep. Additionally you can narrow or widen the car's track too.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-30-2006, 12:02 PM   #2750
maxepower's Avatar
Talking RE:415 blocks!!
Narrowing the rear seems to really help increase the turning speed especially in the rear of the car grips the track. Not sure, but to me it would seem that it would have the opposite affect! The race track proves me wrong! Narrowing the rear increases traction in and out of the turn, just not sure why?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-30-2006, 01:59 PM   #2751
POOKYT's Avatar
Very true!
Thank you sir!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 01-30-2006, 02:06 PM   #2752
Narrow width means smaller turning radius. Making in wider will make the car more stable but the turning is not as sharp.
trf_racer is offline   Reply With Quote
Old 01-30-2006, 02:11 PM   #2753
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Excuse my ignorance, but where is Dongskie's TA05 setup posted? I can't seem to find it with this search engine..
Or, was it just a shared known setup for you at the track? What surface/dimensions is Speedzone?
Thanks,
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 01-30-2006, 03:58 PM   #2754
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Years ago the oval guys went to what they call the super speedway cars, (narrower). They found out that the narrower cars were faster in the corners and had more grip.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-30-2006, 05:58 PM   #2755
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Any word on the Pre-order? (Carbon chassis etc?)
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-30-2006, 06:21 PM   #2756
Looks like another new part coming...
RC TA05 Carbon Center Plate
Item #53904 (COMING SOON)
Old 01-30-2006, 06:45 PM   #2757
And Aluminum Side Brace 53905
Old 01-30-2006, 07:31 PM   #2758
sup
sup's Avatar
Thanks,
hi jam-ehz. the three of us (mflores, migvea and i) race/practice at speedzone (1st pic). the track uses smooth asphalt treated with sugar water (i think). the new track is jp raceway (2nd pic). huge one with a 158ft x 76ft dimension. word of mouth is that the speedzone track is 5meters shorter than jp. oh, jp track is indoor.
as far as i know, dong uses stock setup with white springs all around, 55 or 50 wt oil, yellow swaybars rear and red in front. thats all i know.. maybe dong could post his when he gets to visit this thread.
Tamiya TA05 Touring Sedan-speedzone.jpg   Tamiya TA05 Touring Sedan-jp_raceway.jpg
sup is offline   Reply With Quote
Old 01-30-2006, 08:05 PM   #2759
With the exception of using hex screws and foam tires, I plan on assembling my TA05 completely stock, then performing upgrades one at a time.
I understand that most people don't use and wouldn't use the stock dampers, but I'd like to know what you guys would suggest for shock oil in them considering I will use them for at least one race day at my local track. I'll be running with foams on Ozite at a 80x40 track that's primarily technical.
I currently run 60wt in the front and 40wt in the rear of my TC3 with FT shocks, but I assume that the plastic dampers would need a thicker oil due to lower tolerances.
Thanks for any help!
Batfish is offline   Reply With Quote
Old 01-30-2006, 08:09 PM   #2760
POOKYT's Avatar
My son and I ran 60wt in the stock shocks this past weekend. With the stock springs the dampening was still light. With a change in springs the 60 may have been even better. Hope this helps.
Brant
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
