Tamiya TA05 Touring Sedan
#2731
Originally Posted by MFLORES
Sup,
I tried the Satoshi set-up at Speedzone last Saturday. It doesn't work at that track.
The Dongski set-up still works best for Speedzone.
Save you the trouble.
Of course.... different place, different setup....
Why you wanna use Satoshi setup ?
#2732
Sup,
thanks slotmachine for the link.
#2734
MFLORES / SUP : Yeah you should listen to Dongskie. he knows his shiz when it comes to speedzone and Tamiya !! i currently have white springs at the back and blue in front. It ran great last night. Dongskie and I had the track all to ourselves!
#2735
here are pics of my 05!
pretty much bone stock....
- NOvak GT7
- Futaba 9451
- 23t katana motor
- Trf shocks
- alum hubs
- ....still waiting for lhs to stock other hop ups.
pic of the chassis
with ESSO ULTRAFLO SUPRA body...
with RIDE ACCORD body ....
- NOvak GT7
- Futaba 9451
- 23t katana motor
- Trf shocks
- alum hubs
pic of the chassis
#2736
Is that the new Tamiya Supra? How does it handle?
#2737
westerdude, yes it is. Haven't tried it out on the track yet... but it definitely looks GOOD!!!!
#2738
#2739
Has anybody run this car on carpet with foams? If so, how did you deal with the wheel width on the front around the camber ball stud? Thanks
Brant
Brant
#2741
When you try it, if you remember, please PM me and let me know. It looks like a nice choice for a TCS body.
#2742
Regional Moderator
Brant
Brant
Taking off material is easy. The ball cup plastic is soft. So a gental touch with a sharp X-acto knife is all that is needed. Try to shoot for a 45 degree angle, without cutting all the way through the ball cup.
Then you should have no clearance problems.
#2743
Originally Posted by Darkseid
Most people run the 6mm hex hubs to space the wheels out to maximum legal width. That takes care of most of the problem. In addition I took a little material off the front ball cups just to make sure that any 'non true' wheels I might mount up, wouldn't rub the ball cup.
Brant
#2744
Brant
Brant
#2745
Originally Posted by cheehtae
I ussually cut the side of the front wheels, 3-4 mm. will not affect handling. just make sure when you cut it use a fresh xacto blade and that the wheel when mounted to the truer is turning AWAY from you. BE CAREFUL, but i's really easy. JUST BE SAFE>>>>>
Darkseid--What is the number for the 6mm hex's? Or doyou mean the aluminum ones? Thanks guys
Brant
