Like Tree2Likes
Old 01-26-2006, 07:48 PM   #2701
Regional Moderator
Darkseid's Avatar
I second that...
TLR 22...Tamiya F104...
Old 01-26-2006, 08:16 PM   #2702
m i g v e a's Avatar
Anyone have a link to the TA05 setting sheet? It may be blank or something to grab an idea off.... THAnks!!!
m i g v e a is offline   Reply With Quote
Old 01-27-2006, 04:01 AM   #2703
Dongskie's Avatar
Trader Rating: 44 (100%+)
Migvea/MFlores: Can you post a pic or pics of yoiur TA05?
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 01-27-2006, 06:23 AM   #2704
Tamiya USA...go to TRF page
rcmnx is offline   Reply With Quote
Old 01-27-2006, 06:27 AM   #2705
Post Diff joint
Is the diff-joint interchangable with trf 415, like ta04 with trf 414...
Means, I can use 51058 TRF415 diff joint instead of 53849 TA05 High Precision Diff joint ?
thx
Old 01-27-2006, 07:31 AM   #2706
No, the aluminum diff joint only work on TRF415.
trf_racer is offline   Reply With Quote
Old 01-27-2006, 10:39 AM   #2707
Ok thx
Old 01-27-2006, 10:47 AM   #2708
maxepower's Avatar
Talking TA05 set-up sheet
never mind!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-27-2006, 10:58 AM   #2709
Default TA-05 Setup Sheet
Has anyone checked out the Satoshi Maezumi version of the setup sheet on the TRF site? All of the settings are on the sheet in English and Japanese except the spring choices which are in Japanese only. Can anyone translate?
hudsong is offline   Reply With Quote
Old 01-27-2006, 11:16 AM   #2710
rvs
Default Diff pulley
Has anyone tried to change the diff pulley from 36T with 50877 TA04 Ball diff. pulley (32T) ?
I think the internal will be much lower (2.00) ... since the center is 16T bigger than TA04 (15T).
rvs is offline   Reply With Quote
Old 01-27-2006, 11:32 AM   #2711
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
What belt would you use???? If you find one that will fit, its a possibility. Unless your after a speed run, theres no benefit in the lower T pulley.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 01-27-2006, 05:36 PM   #2712
GCT69's Avatar
Just a quick question guys, spool on carpet will it work or Differential still better?
GCT69 is offline   Reply With Quote
Old 01-27-2006, 06:21 PM   #2713
Spool might be a bit quicker but it handles differently from diff and one-way because both left and right wheels are locked together.
Old 01-27-2006, 06:45 PM   #2714
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Tech racing makes a gear set that alters the drive ratio.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-27-2006, 11:07 PM   #2715
sup
sup's Avatar
can you share the link to us please? i would want to see it too. thanks in advance!
sup is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
