Like Tree2Likes
Old 01-23-2006, 10:40 AM   #2656
just woundering if any one has had any problems with the steering on the ta05 because every time i turn right it turns nice a sharp and i can throw it into the corner nice, but when it turns to the left the steering is poor and the car goes real widei have tried to file the servo saver down becasue it was rubbing against the tub but i still have the same problem.
any help
servo iam using is a standard ballraced futaba servo
cheers ash
ashrc18TA05 is offline   Reply With Quote
Old 01-23-2006, 11:23 AM   #2657
Aluma's Avatar
Is it me or does it seem a little silly to spend more than what a 415MSX costs on upgrading a TA05?
Aluma is offline   Reply With Quote
Old 01-23-2006, 11:39 AM   #2658
Depends on your point of veiw, if you are after a cheap TC then no, if you find the handling balance of the TA05 better than the 415MSX then if you can justify it, then yes,
DA_cookie_monst is offline   Reply With Quote
Old 01-23-2006, 12:08 PM   #2659
Will the lightweight reversible suspension fit and work on the ta05?
alien too is offline   Reply With Quote
Old 01-23-2006, 12:45 PM   #2660
You can't buy a 415MSX for $150 and upgrade it later.
Batfish is offline   Reply With Quote
Old 01-23-2006, 01:12 PM   #2661
Skitee's Avatar
Aluma : If you're looking at it from a cost effective value for money point of view then yes it is a little....no quite silly but for some guys it's about having a kickass ride which also looks the part. I fall into the latter of the two and my TA05, including pretty much every Tamiya hop available for the TA05 and the electronics has cost me just about double what I paid for my 415MSX.
Alien : The TA04/TB02 Lightweight suspension and the TRF415 Lightweight suspension will work, if you can find it it would be better to go for the 415 lightweight suspension because it comes with 46mm swingshafts for the universals. I went for the TA04/TBOS lightweight suspension and replaced the 42mm swingshafts with 48mm shafts.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-23-2006, 01:14 PM   #2662
cheehtae's Avatar
Trader Rating: 15 (100%+)
or you can buy just the lightweight arms just dunno if this wll work.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-23-2006, 01:24 PM   #2663
Skitee's Avatar
Cheehtae : I'm not sure if it will work, maybe somebody else can confirm but I don't think the rear uprights which come in the kit will fit on the lightweight arms
Old 01-23-2006, 01:27 PM   #2664
cheehtae's Avatar
You said it< anybody can confirm? it's much cheaper if you would just buy the arm and the carrier still.
Old 01-23-2006, 01:31 PM   #2665
Skitee's Avatar
point taken Cheehtae, the only other parts needed to do the conversion would be the 950 bearings and then it should still work out cheaper than buying the lightweight suspension set
Old 01-23-2006, 02:12 PM   #2666
Aluma's Avatar
umm, why would you want to? the 415msx is the best tamiya has right now. It doesnt NEED hopups. I started with a tl01 and hopped it up and frankly couldn't compete. Then I went to the TB01 and hopped it up and still couldnt compete. Then to the TBevo2 and started catching up a bit... I've had my evo3 since it came out and usually place 1st or 2nd or 3rd but I think its time to upgrade to tamiya's finest again, but I have my doubts about belt drive in the bumpy, rocky, dusty track we have.
Old 01-23-2006, 02:37 PM   #2667
The point was that someone may not have the $400+ for the 415MSX at one time. The TA05 seems to be a great entry-level TC that can hold it's own in club racing. That's a very good deal for $150, and can apparently be made very competitive for about $200 more, which doesn't need to be spent at the time of initial purchase.
I'm getting a TA05 for club racing on an Ozite carpet track and will be racing against Xrays regularly. Having dual ball diffs is a good start, rather than a one-way or spool. I'll see how it holds up for the price. From what I'm reading here it should do just fine.
If I feel the need to upgrade parts, there's plenty of CF, graphite, and aluminum around for selective upgrades. I like that option
Old 01-23-2006, 03:04 PM   #2668
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Suspension Upgrades
hey guys..
if you are going to upgrade to the lightweight suspension. you will need to change the following:
front:
- castor block
- steering knuckle
- bearings
- axles
rear:
- rear hub
- axle
- bearings
the old suspension uses 5x11 bearings. the lwt. susp. uses 5x9
and no. you cannot use the lwt. susp. arms with the original suspension rear hub. it will not fit.
hope that helps.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-23-2006, 03:46 PM   #2669
raptor 700's Avatar
Default ta05
Does the dj pro module suspion make a differance? If it does make a differance, what is does it do? And is it worth the money.
raptor 700 is offline   Reply With Quote
Old 01-23-2006, 03:49 PM   #2670
cheehtae's Avatar
Originally Posted by Hebiki
hey guys..
front:
- castor block
- steering knuckle
- bearings
- axles
rear:
- rear hub
- axle
- bearings
hope that helps.
Thanks again Hebiki
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
