Like Tree2Likes
Old 01-16-2006, 10:49 AM   #2521
SpeedTech's Avatar
Originally Posted by Besercoe
just need the centre bulkhead and it will be complete.
cant wait to fee the finished product.
The Xenon Racing Center Bulkhead was not available yet to be included in the picture, but it should be here tomorrow, I'll post another pic
Right now I'm working on sealing the edges of the chassis and the other graphite components.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-16-2006, 10:53 AM   #2522
Hey Steve, what do you use to seal the graphite? Everyone says thin CA, but there must be something else out there.
Dodgersfan is offline   Reply With Quote
Old 01-16-2006, 11:00 AM   #2523
Trader Rating: 23 (100%+)
Steve Wang
Dont glue your fingers together again!
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-16-2006, 11:01 AM   #2524
Steve, is the stepped spacer that goes under the motor mount available seperately??
DA_cookie_monst is offline   Reply With Quote
Old 01-16-2006, 11:23 AM   #2525
Aluma's Avatar
there's always girly nail polish... pink should look nice
there's the "gel" superglue...but that leaves the white smoke effect :P
But I find thin CA to be the best! put one drop, let it roll as far as it can, then add another drop...all the while rotating the piece vertically of course and not touching the parts you've already CA'd. Since its thin, it'll dry really fast anyway.
Aluma is offline   Reply With Quote
Old 01-16-2006, 11:24 AM   #2526
If I use the outer hole on the stock rear uprights, how will that change the cars handling please??
Old 01-16-2006, 02:10 PM   #2527
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
It basically makes the rear springs stiffer, as they'll be more upright compared to the other hole positions. This may result in a slightly looser car when on-power, because less weight will be put on the rear tires for traction.
I find it's best to start with the outer hole with any spring, and if I need a softer setting but my next-softest spring option is too soft, then I will start going down notches instead to get something in between.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 01-16-2006, 02:31 PM   #2528
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Are you meaning the holes on the shock tower???
If found the hole position on the tower to be more about intial turn in grip. If you straighten up (go further out in the holes) your shocks, you loose initial grip on that end of the car. If u use the outer holes on the rear, you should fine you have less rear end traction as u enter the corner. I usually used the middle holes on the rear, and on the front, i adjust to give the right amount of turn in. I had my front shocks on the centre hole, and on turnin, some corners it was great, and other it seemed to have oversteer, so i went out one hole and the car worked awesome.
if you werent talking about the shock tower, then let me know lol
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 01-16-2006, 03:47 PM   #2529
rear uprights = hubs, sorry, been in the spray booth for a couple of hours.
I am happy I know what I get from moving the shocks in and out, just wanted to know about the camber link, making it longer should give less camber change, as I wanted a more progressive rear end.
Old 01-16-2006, 03:53 PM   #2530
SpeedTech's Avatar
I use CA (thin stuff) it goes on quick and dries quick. I usually don't do this until I have a full cup of coffee in me though And you can give it a tint of color by using sharpie (learned this from Dave Berger...old school Tamiya guys should know who he is )
Steve Wang
Old 01-16-2006, 03:53 PM   #2531
Jack2's Avatar
I use a thin CA, and after I have prepared the edges I apply the CA to a cotton Bud (Q-tip) and wipe that along the edges. It does a sweet job and it only goes were you wipe it so you don't end up with CA runs on the top or bottom of the carbon fibre. And you don't get the horrible stuff on you hands either !
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-16-2006, 03:54 PM   #2532
SpeedTech's Avatar
who me? Never!...although I have glue tires to my fingers...hahaha
Steve Wang
Old 01-16-2006, 03:56 PM   #2533
SpeedTech's Avatar
Not that I know of, but I'll check
Steve Wang
Old 01-16-2006, 04:07 PM   #2534
Jack2's Avatar
Moving the camber link to that position will raise the rear roll center. This normally makes the car a bit loose on entry and gives the rear more traction on exit. It depends on how the rest of the car is setup as to whether it will improve your cars handling or not.
Schumacher Mi4CX
Mugen MTX & MRX
Old 01-16-2006, 04:24 PM   #2535
Trader Rating: 112 (100%+)
Hello,
Does anyone have a good carpet setup for the TA05?
I need to see if I can get my car to run better.
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
