Tamiya TA05 Touring Sedan
#2476
Originally Posted by ttso
Xenon motor mount
SRP 3980yen, released in JP
Steve Wang
#2477
Originally Posted by bender
Sorry, but just because the teeth are close to the same size, does not make one "the metric version of the other" and vice versa.
That's like saying an M3 screw is the metric version of a 4/40 screw
no, i wasn't trying to say that because they are close in size, that one is the metric version of the other.
but, one IS the metric version of the other.
i was simply trying to say that "48 pitch" and "0.6 module" are the same thing. (simplified from when someone from robinson explained it to me, basically). the reason the tamiya pinions don't mesh perfectly with regular gears is because they're metric.
is that clearer?
#2478
Regional Moderator
Originally Posted by ultegrasti
any1 else have issues w/dogbones or universals poppin out.
the universals and high precision diff joints (no rings-yet) havent help. only the left front, nothin else. goin to tear it all down this wk and try to get to the root of prob.
thx
-ult
thx
-ult
I've been so impressed with the dogbones on this car that I have totally nixed all plans to replace them with universals.
#2481
Outdrive for spools!
I picked up a spool for my TA05 at Tamiya and the outdrives appear to be a black oxide coated steel material. I made one test run and got a large amount of chatter when turning the front wheels. This was never a problem with the ball diff. So after looking at my 415 spool I noticed that the shafts are in line with each other and the shafts were 90 degrees from each other on my TA05, so rotated the shafts so they are the same and the chatter almost went completely away, still some chatter at full throw so I had an idea, switched the delrin outdrives from my 415 with the steel on the TA05 and now no chatter and very smooth even at full turn. Has anybody tried the 05 spools and had this problem? I believe Tamiya will come out with replacement steel outdrives for the 05 and will work with the 415 and visa versa!
What can I say, I'm a fool for a spool!!!!!
#2482
body mounting?
Will the TA05 allow mounting of standard sedan bodies usuing "standard / TC3 or TC 4" Mounting holes?
Jon
Jon
#2483
well i'm gonna try those retainer rings from the HP diff joints now b/c only this left front hops out. gonna try a thicker eraser head in there as well. hopefully it will keep it in there. it doesnt have any lateral movement when u go lock to lock, but somethin is happenin out there racing (no linx are not poppin off) thats shootin it out such that it lands up the outdrive cup itself.
argh (btw i'm on universals in front)
-ult
-ult
#2486
the 46mm option universals, HP joints, diff
(believe i mentioned that, but no prob)
-ult
-ult
#2488
i wonder why your HP diff joints don't come with the retaining rings? I bought the HP diff joints and they come with the rings.
#2489
thx
-ult
thx
-ult
Yes, I'm having the same problem. Tonight I stuffed some foam into the outdrives and it never happened again for the rest of practice. I did notice that the red foams just completely shredded away as if the diff screw was not in all the way. You would think that the dogbone was too long but the problem is that the dogbone is slipping out of the axle.
#2490
RE:outdrive chatter!
-ult
-ult
See if that helps!
Good luck and don't forget.............HAVE FUN!
