Like Tree2Likes
Old 01-05-2006, 12:14 PM   #2446
Juan Valdez's Avatar
Originally Posted by kufman
This weekend shane will not be there so we have a chance of better than the top 3 Just have to beat out the rest of the Tamiya croud, if they show up, and Sobiski. If you want me too I can go out there on friday and see if you car is there. that way we can build it before Sat practice.
That'd be cool. Maybe I'll call the track Friday and ask Ray or Jerry if the stuff's there. I don't really have an esc for it though, as I don't want to tear the GTX out of the JRX-S. I was planning to run the Losi this weekend anyway as I have some ideas to try. I'll figure something out. Oh yeah, need a body too...
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 01-05-2006, 12:16 PM   #2447
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I also run a RW, 104T 64P.. really thin, but mounts just fine, and is really quiet and solid. I really just grab whatever I can that's available, some others use 90/96T spurs from their 1/12 cars.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 01-05-2006, 12:18 PM   #2448
maxepower's Avatar
Talking RE: Diff adjustment
Originally Posted by Teehomo
Hi all.
New to R/C and have finished building my TA05. I am still running very standard setup as I need to learn how to drive the car first. However, I have a question regarding diff tightness. I intend on running on asphalt at the Sydney SMA track (if any are familiar with it) using rubber Sorex 36R on medium inserts. Motor is a Tamiya Sports Tuned (black can).
My first impression of the car is that it is very responsive although under power the turning circle is much larger than when coasting, ie it seem to be understeering when driven through a corner. From reading through this thread the general consensus is to have the front diff tight and the rear diff loose to counteract understeer. My question is what constitutes tight and what is loose? Can anyone give me some guidance as to a starting point for diff tightness?
I've atached a photo of the Ferrari bodyshell - since it was my first I used the window stickers and now wish I had painted them in smoke. Ah well, I'm still happy with the look.
I'd like to help you answer your question if nobody else has. You can have a friend help out for the first time to make it easier for you. Have somebody hold the spur gear so it does not move. Then start with the front, hold the left tire with one hand and try to rotate the right tire. The harder it is to rotate that tire the tighter the diff is. Now do the same thing but with the rear tires lock the spur so it doesn't move then hold one tire and try to rotate the opposite tire, the tension generally should be equal from front to rear but some racers like it a little looser in the rear for more stability in driving, in other words not allowing the rear of the car to swing around too quickly in corners. So, in affect a tighter diff in the front will seem to take away some steering. Somebody suggested to buy a XXX main set-up book. It is very valuabe to guide you on how to dial or tune you car and help you understand what the cause and affect of the adjustments you make. This is a great book for anyone getting started in RC cars whether it's Sedans or offroad!
It really comes down to transfer of weight and traction from the front to rear when you adjust for understeer or oversteer. This is also referred to as a car that pushes or is loose in or out of corners. I hope I have been of some assistance in your quest for the perfect set-up!!!!
Good luck! Don't forget to "Have Fun"!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-05-2006, 12:25 PM   #2449
I am looking for a blank set up sheet for the TA 05 for our track... I know it's out there somewhere.
Any links?
thanks much
Silver is offline   Reply With Quote
Old 01-05-2006, 12:47 PM   #2450
Jam-ehz's Avatar
Here's one..
http://tamiya.com/japan/products/58358essota05/ta05.pdf
Old 01-05-2006, 02:26 PM   #2451
thank you! much appreciated
Old 01-05-2006, 03:39 PM   #2452
Regional Moderator
Darkseid's Avatar
Originally Posted by DA_cookie_monst
Dark, I am currently running an RW spur, narrow, white and a 78 tooth 48dp version, see attached image (excuse the quality, couldn't be bothered getting the camera out)
Well thats cool. I had heard several times here on this thread that they just wouldn't fit. Did you have to do any modding or was it a straight fit?
If it was a straight fit then I would love to go back to running RW gears.
TLR 22...Tamiya F104...
Old 01-05-2006, 03:57 PM   #2453
Went on, straight fir, same one I used to use on the RC Lab, it has the ubiquitous universal fitting on the TA05.
DA_cookie_monst is offline   Reply With Quote
Old 01-05-2006, 05:20 PM   #2454
Regional Moderator
Darkseid's Avatar
Cool! I know my local track carries RW, so I'll check the wall when I go racing this weekend and see if they have a size I can use.
Old 01-06-2006, 12:29 AM   #2455
f2000racer's Avatar
What pitch does the TA05 use? doesn't seem to be a 48 and definitely not a 64 pitch?
Thanks,
Tamiya F103RM
Tamiya Mini
Tamiya TA05
f2000racer is offline   Reply With Quote
Old 01-06-2006, 12:47 AM   #2456
dodo's Avatar
Send a message via Yahoo to dodo
Thanks,
it's tamiya AV pitch
dodo is offline   Reply With Quote
Old 01-06-2006, 05:28 AM   #2457
bender's Avatar
Actually it's 0.6 module pitch, which is metric gearing, as opposed to the imperial 32, 48, 64 pitch.
The Avante was the first tamiya car to use this 0.6 module pitch, hence the "AV" tag on their pinions
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 01-06-2006, 08:27 AM   #2458
Jam-ehz's Avatar
It comes with a 75 tooth .6 spur gear, and a 105T .4 spur is available as a hop-up from Tamiya
Thankfully they're not proprietary like the TB-02's spurs, and any spur you can find will work (within size limits), like regular 48 or 64 pitch.
What broke the camel's back for me to switch were the soft aluminum AV pinions they give you, and the limited gearing of the 75T spur. The fact I had 1/12th 64p stuff also helped.
Old 01-06-2006, 03:05 PM   #2459
f2000racer's Avatar
Thanks for all the info.
This is quite a "history" lesson
It's good the TCS rules allows the use of other makes for the spur and pinion.
Tamiya F103RM
Tamiya Mini
Tamiya TA05
Old 01-06-2006, 10:40 PM   #2460
quantum's Avatar
Default nomenclature
actually "0.6 module" refers to the way the tooth size is calculated, its essentially "48 pitch", except tamiya's gears are metric. so, technically, you could say that regular 48 pitch gears are "imperial 0.6 module".
you'll find that tamiya's 48 pitch gears do not mesh perfectly with regular 48 pitch gears (close, but not exact).
on a similar note, their new chassis is called the 415MS Refine 2, OTHERWISE known as the 415MSX, but it would be misleading to be called the msx refine 2.
quantum is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
