Like Tree2Likes
Old 12-28-2005, 09:17 AM   #2386
Only blue aluminum is available at this time.
#53869
trf_racer is offline   Reply With Quote
Old 12-28-2005, 09:36 AM   #2387
SpeedTech's Avatar
Originally Posted by quantum
the kit outdrives are a bit weaker so they may not hold up as well at the ends (but will prob work ok). anyone have a photo of the 42mm bones with the precision outdrives? those have a retainer ring
I think with the 42mm bones, it might look okay at ride height, but the bones might slide out a bit further towards the outter edge of the oudrives when the suspension compress.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-28-2005, 09:39 AM   #2388
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that we got some new TA05 hop-ups in stock (limited in quantity for now, more coming soon):
Tamiya Aluminum Damper Retainer (1mm down type)
Tamiya TA05 Front Direct coupling (spool)
Xenon Racing TA05 Alum. upper bulkhead
Also, most of the spare parts should be back in stock as well
Steve Wang
Old 12-28-2005, 10:51 PM   #2389
kufman's Avatar
Is anyone else having trouble getting to the SpeedTech site, or is it just me?
Now I have seen the pic you posted on here and on RCZone of your thrust bearing. I have no idea how you did that. I've never had that kind of trouble. Even when running on carpet/foams. Did you build the diff according to the instructions? Tons of grease in the thrust bearing? Or no grease? Too tight of a diff?
I built the diff exactely according to the instructions wiht lots of grease. I think it was just bad materials in the assembly. I was only running a stock motor with rubber tires. The diffs were just tight enough not to slip. I rigged up a temporary unit using Team Associated parts for now.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 12-28-2005, 11:39 PM   #2390
SpeedTech's Avatar
I just got on a browsed around, everything seems to be in order
Steve Wang
Old 12-29-2005, 06:42 AM   #2391
ttso's Avatar
Kawada's CF chassis kit has price now...
LINK: http://www.kawadamodel.co.jp/moro_info/ta05/index.html
14,800yen w/o tax
ttso is offline   Reply With Quote
Old 12-29-2005, 07:06 AM   #2392
Regional Moderator
Darkseid's Avatar
Originally Posted by CIVIC91
Looks like I have lots to order for February!!
It looks like we both will!
TLR 22...Tamiya F104...
Old 12-29-2005, 11:04 AM   #2393
ttso's Avatar
Default Carbon reinforced tub chassis coming...
A few more info about coming TA05 parts
http://tamiya.com/japan/news/news0602/news1.htm#opparts
TA05 carbon lightweight lowerdeck
Item No.53893
February 18th
4,500 Yen w/o tax
TA05 carbon strengthening A part (bulkhead)
Item No.53894
February 18th
1,200 Yen w/o tax
TA05 carbon strengthening K part (brace)
Item No.53895
February 18th
650 Yen w/o tax
TA05 suspension mount (1e)
Item No.53896
February 25th
800 Yen w/o tax
TA05 aramide drive belt (blue)
Item No.53897
February 25th
700 Yen w/o tax
Lightweight reversible suspension set
Item No.53899
February 18th
7,800 Yen w/o tax
Guess I will wait for carbon reinforced tub chassis other than go for CF chassis...
Photo from Pro-S-Futaba (http://www.pro-s-futaba.co.jp/hsphoto/hs05-2.htm)
Old 12-29-2005, 03:38 PM   #2394
Does Tamiya make a wider front bumper and foam for the car?
br241 is offline   Reply With Quote
Old 12-29-2005, 06:18 PM   #2395
dodo's Avatar
Send a message via Yahoo to dodo
anyone here tried the CF battery holder plate? i found that it's designed for stick pack only and for side by side packs you need to modify it because it sits lower.
dodo is offline   Reply With Quote
Old 12-29-2005, 06:20 PM   #2396
westerdude42's Avatar
Just re-shim the battery holder posts to get it lower.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 12-29-2005, 06:25 PM   #2397
dodo's Avatar
hmm, even without the shims it still sits higher... sorry just realized maybe i put it in the wrong words...
without the shim, the plate will sit on top of the battery nicely. but the hole for the clip is in a higher position, not directly on top of the plate... got a few mm gap. so it can't lock the battery down. well i can always put some spacers on top of the plate but i just find this pretty annoying...
Old 12-29-2005, 07:27 PM   #2398
I dremmelled abut 4mm off the top of the batt post mounting rib. This lowers the batt post, and you can then snugly hold your cells in place.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-29-2005, 07:29 PM   #2399
dodo's Avatar
that's what I did too
it just confused me why tamiya didn't release something for side by side pack while they have the space to put the battery that way...
Old 12-29-2005, 08:16 PM   #2400
f2000racer's Avatar
Default another why.....
Why is Tamiya not releasing a carbon graphite (fibre) chassis set for the TA05 when you see other manufacturers releasing them????? Got to be TCS legal here
Item No.53893
February 18th
4,500 Yen w/o tax
Item No.53894
February 18th
1,200 Yen w/o tax
Item No.53895
February 18th
650 Yen w/o tax
Item No.53896
February 25th
800 Yen w/o tax
Item No.53897
February 25th
700 Yen w/o tax
Item No.53899
February 18th
7,800 Yen w/o tax
Tamiya F103RM
Tamiya Mini
Tamiya TA05
f2000racer is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
