Like Tree2Likes
Old 12-15-2005, 05:05 PM   #2266
rayman's Avatar
Originally Posted by Dongskie
Ohh and if I may react to this... Yes my TA03R PRO still kicks a** here at my local track... I had a great time chasing HPI PRO4s, Cyclones and TA05s...
GO GET THAT TA-05 AS A CHRISTMAS PRESENT FOR YOURSELF... YOU WON'T REGRET IT!
Yeah I think I'll be getting one soon even if my Christmas present for myself is a 19" lcd flat panel. I'll be dead broke this december.
Getting rid of your 415 so soon? I saw it posted on rc stuff already.
rayman is offline   Reply With Quote
Old 12-15-2005, 10:30 PM   #2267
jas
jas's Avatar
Ok. Thanks for all the replies!
jas is offline   Reply With Quote
Old 12-15-2005, 11:26 PM   #2268
Dongskie's Avatar
Trader Rating: 44 (100%+)
Thumbs up
Great!! You're getting there now.. I'm sure you'll like the TA-05..
Yeah I'm selling it.. planning on getting a new TA05... should'nt have sold my old TA05.. I like the handling of the 05 better....
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 12-16-2005, 11:18 PM   #2269
maxepower's Avatar
Talking TA05 issues!
Well,
I'm going to try and get my 05 dialed at the Tamiya track once again. Been trying several combos. It was a lot better with the stock set-up, then I changed to the lightweight arms and lost the set-up. Way too free in the back end in and out of the corners more out than in but I think I have it figured out. We shall see tomorrow. Any TAOB guys going tomorrow?
ANYBODY......ANYBODY...............ANYBODY........ ............?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-17-2005, 12:54 AM   #2270
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that Xenon Racing has released the aluminum upper bulkhead pieces for the TA05, and we should be receiving that in about 1 week or so
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-17-2005, 09:13 AM   #2271
Regional Moderator
Darkseid's Avatar
Originally Posted by maxepower
Well,
I'm going to try and get my 05 dialed at the Tamiya track...
Must be nice!
TLR 22...Tamiya F104...
Old 12-18-2005, 06:05 PM   #2272
quantum's Avatar
Originally Posted by axle182
Ill take a stab at this -
CF front and rear Shock towers
Install a 9550 servo
Ti screws
Ti Turnbuckles (i hate alu ones)
The rest has consideration for what type of track you race on. Indoor carpet, u would want to stay with your std suspension, outdoor asphalt, go with LWS.
Not sure if its tcs legal to cut two small slots in the chassis so u can use tape instead of the battery strap?
thanks for the suggestions!
anyone else? suggestions for the most cost effective way to reduce weight on the TA05??
quantum is offline   Reply With Quote
Old 12-18-2005, 10:24 PM   #2273
cheehtae's Avatar
Trader Rating: 15 (100%+)
quick questions with suspension blocks. need to know if this combo will work using the ff: with a swing shaft of 46mm.
rear--0 or 2 degree hub
B(front)+B(rear)
front
1x(front)+1XD rear
TNX
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-18-2005, 10:27 PM   #2274
Hebiki's Avatar
Trader Rating: 26 (100%+)
B(front)+B(rear)
front
1x(front)+1XD rear
TNX
B - B in the rear will give you 0 inboard toe in. if you have 0 deg rear hubs, then 0 deg rear toe. and -2 deg rear hubs, will give you -2 deg rear toe in.
front. X-XD will give you 2.5deg of inboard TOE OUT for the front.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-18-2005, 10:36 PM   #2275
cheehtae's Avatar
I thought that for the rear hub---B+B with a 2 degree hub will give you a +2 toe so if its -2 i'm on the right track, but will the rear set of wheels be wider than the front wheels? will this be OK or will it affect the cars handling?
also will the evoIV susp. mount work with the 415/TA05's?
Old 12-19-2005, 07:15 PM   #2276
rtherbe's Avatar
Ran a few packs through the stock built TA05 handled spectacular,poped in a 19turn ran a few more packs through.. I am loving this car... Ordered and installed swaybar kit medium in front, and soft in rear, ran car on same course(parking lot) now rear end seems to hop a bit when I brake, before cornering. Anyone know which way I should go with this? Could the soft rear bar actually make this much difference? or is it the medium on the front causing a transfer of traction????
rtherbe is offline   Reply With Quote
Old 12-19-2005, 11:56 PM   #2277
f2000racer's Avatar
Default sway bars
I haven't started building my TA-05 as all hop-op parts is not complete yet. But as I was looking at the arms, there seem to be no provisions for me to install the sway bars. Am I right or I'm missing something??
Tamiya F103RM
Tamiya Mini
Tamiya TA05
f2000racer is offline   Reply With Quote
Old 12-19-2005, 11:58 PM   #2278
f2000racer's Avatar
Where do I find these info about B-B B+B???
Is there another setup book about this??
Thanks.
Tamiya F103RM
Tamiya Mini
Tamiya TA05
Old 12-20-2005, 12:15 AM   #2279
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Thanks.
my Mercs bodied TA05's manual didn't mention anything about the suspension blocks either, but i downloaded a copy of the F430's kit manual from the Tamiya website, there's a small section inside this manual which explains the various suspension block settings.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 12-20-2005, 12:34 AM   #2280
dodo's Avatar
Send a message via Yahoo to dodo
if you buy the stabilizer set for TA05, you'll get the necessary pieces to install the swaybars.
dodo is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
