Like Tree2Likes
Old 12-13-2005, 06:09 AM   #2251
Dongskie's Avatar
Trader Rating: 44 (100%+)
Originally Posted by buboy28
Dongskie, why are you selling your TA-05? anyway thank you very much for your set-up with my car although i'm not racing very good with the jogging path that i'm running the car with already got the white springs that you mentioned but i got the short one in the front and the long ones in the rear will be bringing the car at Speedzone this weekend so that you could try it out there thanks
Sure Buboy28... anytime...
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 12-13-2005, 07:43 AM   #2252
cheehtae's Avatar
Trader Rating: 15 (100%+)
I don't know if this has been answered before. DJ pro module is it worht it?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-13-2005, 08:06 AM   #2253
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Havent heard anything really positive about it since it came out. Ive been reading the 05 and the 415 threads and neither seem to rate it very well.
Took a few snap shoots of my two Tamiya racers. my TA05 with a few more hop ups and my 415.
05 hopups to date -
Front std 46mm CVDs
Rear LW 46mm CVDs
6mm Alloy hexes
Allo steering set
Hard Arms F and R
Carbon F and R suspension towers
Aramid belts F and R
TRF shocks
Titanium turnbuckles
Kimborough Mid servo saver
Sway Bar set
Alloy Rear uprights (2 Deg tot)
LW Steering servo mounts
Centre one way (not used)
Misc LW screws and alloy screws.
Protoform G6 body (awesome)
Ive replaced all the std steel screws which are up high and on the outer edge of the chassis with the lighweight ones. Therefore getting the COG as low and central as possible. Next hopup will be the Tech racing upper deck and 415 suspension blocks. With small adjustments to the upper links, this car is very easy to work with and very competitive, and i still havent found the 'perfect' setup yet.
Almost forgot to mention, pics were taken just after i reassembled the car with the new hopups, so yes i know +1 and -5 front camber wont work, neither will +7 degs toe out lol
Tamiya TA05 Touring Sedan-dsc02397.jpg   Tamiya TA05 Touring Sedan-dsc02398.jpg   Tamiya TA05 Touring Sedan-dsc02399.jpg   Tamiya TA05 Touring Sedan-dsc02402.jpg   Tamiya TA05 Touring Sedan-dsc02396.jpg
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 12-13-2005, 04:48 PM   #2254
rayman's Avatar
Should I be upgrading to a ta05 even if I'm just a basher?
I dont want another heavy weight kit. I still have the lw suspension from my other kit but I doubt that would be a significant weight change. I love the new supra body though and always like displaying tamiya kits at the shop.
rayman is offline   Reply With Quote
Old 12-13-2005, 07:31 PM   #2255
tantalus007's Avatar
Trader Rating: 17 (100%+)
rayman - you should really try driving a belt car for a change.
tantalus007 is offline   Reply With Quote
Old 12-13-2005, 09:55 PM   #2256
rayman's Avatar
I did. The firstest, mostest, fastest, bestest belt driven car. The tao3!!!!!!!!
Old 12-13-2005, 10:12 PM   #2257
Jack2's Avatar
I have heard a bit of feedback about the DJ Pro suspension, it has all been the same. From what I have heard people are improving on their personal best lap times but consistency drops. I have heard that it’s fast but inconsistent and is different from turn to turn. This is on the 415 tho, not the TA05.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 12-13-2005, 10:35 PM   #2258
Dongskie's Avatar
Go for it!! You drove my car and it came from you that you loved it..
Bajer 1/5th
Old 12-13-2005, 11:41 PM   #2259
westerdude42's Avatar
I say go for it too. I'm nobody's idea of a great driver, but the car is so consistent and predictable that it's impossible not to get better the more you drive it.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 12-14-2005, 07:42 AM   #2260
axle182's Avatar
i totally agree. The car reacts really well to chassis changes also. Mine handle like a pig when i was slack and didnt check the chassis. We also had a track change which was alot slower and tighter, and the car had WAY too little grip on the rear, so a few adjustments on the upper links, and it was sooooo smooth. Not bad for a car ive only had for two months With my new set of bling for it, we'll see what it can do
Aaron "AJ" Freind
Old 12-14-2005, 11:03 PM   #2261
Dongskie's Avatar
Ohh and if I may react to this... Yes my TA03R PRO still kicks a** here at my local track... I had a great time chasing HPI PRO4s, Cyclones and TA05s...
GO GET THAT TA-05 AS A CHRISTMAS PRESENT FOR YOURSELF... YOU WON'T REGRET IT!
Bajer 1/5th
Old 12-15-2005, 12:46 AM   #2262
jas
jas's Avatar
Has anyone got problem with thread stripping on the TA05?
The car use fine threaded screws through out, and I feel they are a lot more prone to stripe than the corse threaded screws. Once the car is built, I really don't like unscrewing anything for the fear of stripping it when putting things back in. Actually this is one of the reasons about "plastic cars" that make me want to pay more for the top level cars (even I still don't have the skills to match) because they have aluminum parts and I don't need to worry about stripping the plastic.
jas is offline   Reply With Quote
Old 12-15-2005, 01:59 AM   #2263
asw7576's Avatar
Use tamiya grease in the first place.
I suggest to clean and put ca glue inside the damaged thread holes. Use toothpick to spread the glue inside the thread (not too much please ). Leave it until completely dry. Use longer screws, grease it and try again.
Old 12-15-2005, 12:18 PM   #2264
Regional Moderator
Darkseid's Avatar
Are you saying you've had problems or that your worried about having problems?
-If you've already had problems, then I would say to use the CA trick that asw7576 suggested. You could also swap the screws in the damaged hole with a self tapping version. That will recut the threads and hold tightly.
-If your just worried about the problems, I would say don't worry. All you have to do is STOP screwing as soon as you see the screw is in and you feel resistance. Also, NO electric screw drivers while assembling. It may be easier, but its also risky and may lead to stripped screw heads and stripped holes.
And on a side note, higher priced kits aren't assured of being strip free. Aluminum parts can strip, screws can break off in them, and most high end kits still use platic or graphite composite steering knuckles. And as anyone who has raced knows, the screw holes in steering knuckles pretty much get 1 removal before the screws start backing out on their own.
I mean even motor screw holes aren't exempt from stripping concerns.
Basically ALL holes that take screws are vulnarable to stripping, whether those holes are on a $130 chassis or a $430 kit.
TLR 22...Tamiya F104...
Old 12-15-2005, 12:36 PM   #2265
ogreasurada's Avatar
That is so true.
ogreasurada is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
