Like Tree2Likes
Old 12-09-2005, 12:04 AM   #2236
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
will associated tc3/4 shock kits fit onto a ta-05 chassis? thanks for any help. very interested in picking up the kit.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 12-09-2005, 12:14 AM   #2237
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Darkseid
This is what is listed at the back of the manual.
9335440 Chassis
and heres a link to it at Tamiya's site. http://www.tamiyausa.com/product/ite...uct-id=9335440
I found it using the above number, but they also list it as:
"RC Chassis 58345
item#9335440"
$11.00
Hope this helps.
Perfect! Thank you sir
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-09-2005, 07:59 AM   #2238
axle182's Avatar
Send a message via MSN to axle182
Originally Posted by quantum
from an almost barebones ta05, what are the best options to get it down as close to 1500grams as possible with the least amount of money? assume that trf shocks, universals, and personal transponder already installed, and must stay tcs legal...
ti or the alum screws?
alum turnbuckles?
liteweight rear universals?
carbon shock towers?
lw suspension?
your suggestions are appreciated
Ill take a stab at this -
CF front and rear Shock towers
Install a 9550 servo
Ti screws
Ti Turnbuckles (i hate alu ones)
The rest has consideration for what type of track you race on. Indoor carpet, u would want to stay with your std suspension, outdoor asphalt, go with LWS.
Not sure if its tcs legal to cut two small slots in the chassis so u can use tape instead of the battery strap?
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 12-09-2005, 08:47 AM   #2239
Default Got my 05!
Originally Posted by Dongskie
Mark how's your TA05??
Dongskie, got my TA05 tonight! Raybrig NSX.
Also got front/ rear carbon damper stays, the stabilizer set (f&r) and ball bearings for the steering arms to replace the bushings.
I'll use the TRF shocks from my TAO4R, and maybe the arms and hubs later on. (Btw, does anyone know if those arms and hubs from the 04 r-tuned chassis kit are the hard arms or the lightweight reversible ones? Thanks.)
Wait , why did I get those bearings? I already have those on the 04! Tsk.
I'm building it through the holidays and will start to run it in the first races of 2006.
Hope you can share with me your settings for Speezone.
See you at the track!
MFLORES is offline   Reply With Quote
Old 12-10-2005, 07:26 AM   #2240
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I believe they are just the hard standard arms, not the lightweight reversible ones.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 12-10-2005, 07:39 AM   #2241
how many parts if any from the TA04 work on the TA05?
the_wrench is offline   Reply With Quote
Old 12-10-2005, 10:08 AM   #2242
Default lost crescent ring
Started to build my 05 tonight. I frustratingly lost one of the crescent rings for the center shaft. It seems okay to run it without one on one end. Any suggestions or comments which may help?
I also tried using a small e-clip and it looks like it clears the mount. Is this a good idea? or should I just leave one end without a c-ring?
Thank you very much.
Old 12-10-2005, 10:20 AM   #2243
the suspension on the TA04 is the same as the TA05
washabi is offline   Reply With Quote
Old 12-12-2005, 03:43 AM   #2244
bump this up from the third page!!
DA_cookie_monst is offline   Reply With Quote
Old 12-12-2005, 04:27 AM   #2245
i have try a carbon chassi , but go back to the original plastic one.
( cs-27 on carpet ).
losi100 is offline   Reply With Quote
Old 12-12-2005, 06:45 AM   #2246
cheehtae's Avatar
what kind of carbon chassis did you have? and why did you go back to plastic?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-12-2005, 07:43 AM   #2247
Dongskie's Avatar
Trader Rating: 44 (100%+)
Hey be carefull while mounting that c-clip.... arghhh!! too late... it might fly-off.
Alrighty dude!! I'll help you with the set-up... Honestly? I like my 05 better than my 415...
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 12-12-2005, 10:06 AM   #2248
i have try a Xenon chassis , but i go back to my previous set up ( the original chassis with the tech racing upper deck....the upper deck from xenon and tech racing are the same ).The xenon chassis is a real nice parts , i think it's well made and efficient but the problem ( for me )is from the plastic bulkhead.
On the plastic chassis the lower parts from the bulkhead goes into hole, for good fit , for the carbon one the bulkheads sit on a flat surface and they are not so well maintened.
When i test flex on the plastic chassis, no probs , rigid but all go back in place easy
With carbon you hear plastic parts working when you test flex , and the chassis keep sometime some tweak..
Meaby with aluminium bulkhead it's better , but it's too expensive for the moment.
i have a better feeling with the original one .and i can see the differance with the lap time and how i drive against my friends car ( fk05 and tc4 factory)
Old 12-12-2005, 04:17 PM   #2249
Ballsie's Avatar
Hi Guys,
I am selling some TA05 spares and hopups.
Please see here - http://www.rctech.net/forum/showthre...67#post1995267
Cheers,
Alan
Ballsie is offline   Reply With Quote
Old 12-13-2005, 02:56 AM   #2250
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Dongskie, why are you selling your TA-05? anyway thank you very much for your set-up with my car although i'm not racing very good with the jogging path that i'm running the car with already got the white springs that you mentioned but i got the short one in the front and the long ones in the rear will be bringing the car at Speedzone this weekend so that you could try it out there thanks
buboy28 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
