Like Tree2Likes
Old 12-06-2005, 07:32 PM   #2206
maxepower's Avatar
Wink Insider information?
I heard from a reliable source on the inside that Tamiya has a 4mm lower chassis in the works and may include a front diff. Maybe some kind of a conversion kit for carpet. This if for the 415. But for the 05 this same insider mentioned some kind of hop-up to help stiffen the chassis. Not sure if it will be an upper deck, he seemed to suggest possibly a torque bar or bars or mid-deck type design like the 415.He wasn't real clear on that issue,but all of this he said is likey coming sometime next year!
P.S. Try and keep this info confidential!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 12-06-2005, 08:42 PM   #2207
quantum's Avatar
Default wait for weight?
to all the ta05 owners, what does your ta05 weigh, and with what options are you using?
and how much weight does the lightweight suspension alone shave off?
quantum is offline   Reply With Quote
Old 12-07-2005, 12:20 AM   #2208
bender's Avatar
More Ta05 chassis options....
Though I think these guys know a little more about developing the TA05 platform than other after-market manufacturers
Tamiya TA05 Touring Sedan-ph_ta05_1.jpg   Tamiya TA05 Touring Sedan-ph_ta05_2.jpg
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 12-07-2005, 12:45 AM   #2209
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note of some of the new Square R/C pieces for the TA05:
Square R/C TA05 Rear Graphite Brace Graphite front brace is coming next month.
Square R/C TA05 Graphite Battery Strap
Square R/C TA05 Graphite Motor Mount cover (top)
Square R/C TA05 Aluminum Servo Mount (1 pair)
Pictures attached
Steve Wang
Tamiya TA05 Touring Sedan-sta7.jpg   Tamiya TA05 Touring Sedan-sta11r.jpg   Tamiya TA05 Touring Sedan-sta24.jpg   Tamiya TA05 Touring Sedan-sta34c.jpg
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-07-2005, 08:54 AM   #2210
Regional Moderator
Darkseid's Avatar
Originally Posted by axle182
I wish Tamiya would speed up the release of some of these parts we NEED.
But thats just it, how can they be sure what we "need". There have been just as many people happy with the stock chassis as there have been people calling for a stiffer set up. 50/50 at best. I would certainly "like to have" the carbon chassis(just because I like the look of it ), but I wouldn't call it "NEED". At least not for me.
And remember, at the same time some may "NEED" the upperdeck/stiffer chassis, other people don't care about that and instead insist that they "NEED" a one-way, center one-way, arimid belts, alloy shocks, etc... and Tamiya have delivered those quickly.
"NEED" to me would be things that were too weak or broke easily right from the box. And to Tamiya's credit, there doesn't seem to be any part that would qualify for that. And thats saying something considering I have seen(and owned) $300+ kits that have one or two weak links that leave the car sitting on your shelf for weeks on end while you wait for replacements or upgrades that you truely "NEED".
TLR 22...Tamiya F104...
Old 12-07-2005, 09:02 AM   #2211
Regional Moderator
Darkseid's Avatar
that motor mount cover is simply a work of art. Seeing the parts that are coming out for this car makes me want to own two of them. One for TCS(and 19t racing at club races) and one only for club races (and mod or...yuk...stock )
Originally Posted by SpeedTech
Hi Guys,
Pictures attached
Steve Wang
Old 12-07-2005, 10:02 AM   #2212
1shnot's Avatar
hey bender which company is that from?????
1shnot is offline   Reply With Quote
Old 12-07-2005, 10:23 AM   #2213
Aparatchik's Avatar
Hey Steve,
Will you be bringing in the 3Racing hop ups for the TA05 too? Any prices on them yet?
Hi Guys,
Aparatchik is offline   Reply With Quote
Old 12-07-2005, 10:39 AM   #2214
TFR
TFR's Avatar
Kawada Model.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 12-07-2005, 11:15 AM   #2215
1shnot's Avatar
do they have a web site? kawada....... and is it for sale yet?
Old 12-07-2005, 11:30 AM   #2216
Aparatchik's Avatar
Kawada's Site
Old 12-07-2005, 11:37 AM   #2217
1shnot's Avatar
man... you guys rock!!!!!!!!!!!!!!
Old 12-07-2005, 03:45 PM   #2218
Rod M's Avatar
I have a small issue with my TA05,
I am running the TRF shocks and Tamiya white short springs,
if I put in the normal springs the ride height cannot be made any lower than 7mm
are there any short springs harder than the white one's available ?
thanks
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 12-07-2005, 03:53 PM   #2219
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
I had the SAME problem.... never solved it tho... i just run smaller foam tyres now. I was running outer holes on arms etc.... i dont know what was wrong?
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 12-07-2005, 04:08 PM   #2220
Note that there are 2 versions of the lower spring perch, the Alloy ones are quite flat, and you shouldnt have any issues with ride height, while the kit TA05 perches are quite raised, and thus you wont be able to get the ride height down.
If it is still too high with the TRF perches, you could try some associated style perches, which allow the spring to actually sit lower again than the std ones.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
