Like Tree2Likes
Old 12-03-2005, 04:01 PM   #2161
hi
have you got a website for it because i want to buy one and do they ship to the UK
ashrc18TA05 is offline   Reply With Quote
Old 12-03-2005, 04:25 PM   #2162
Speedtech sells the conversion kit. Here is a link
http://www.speedtechrc.com/store/ebp...il.asp?id=5745
I am pretty sure that Steve ships overseas.
dway100 is offline   Reply With Quote
Old 12-03-2005, 04:46 PM   #2163
email james at www.fusionhobbies.co.uk, he is thinking about them as he is a tamiya specialist.
DA_cookie_monst is offline   Reply With Quote
Old 12-03-2005, 05:03 PM   #2164
I JUST WONT TO SAY THANKS TO ALL YOU GUYS WHO HAVE HELPED ME
CHEERS
Old 12-04-2005, 01:29 AM   #2165
Default Blue Turnbuckles what size
Can some tell me what size are those blue turnbuckles everyone
is using for the upper suspension arms that replace the 3 x 28 on TA-05?
Thanks;
Andre
Key500 is offline   Reply With Quote
Old 12-04-2005, 06:34 AM   #2166
cheehtae's Avatar
Trader Rating: 15 (100%+)
hey guys I need some advice with gearing , first of all got my xenon kit and to tell you the truth my car was'nt set up good compared to the plastic ones, why? well my set up is this, with the CF chassis:
FRONT:
maroon spring--super hard
yellow bars
double pink orange 2 stage jaco
shock mount top is on the first hole
shock mount bottom--inner hole
REAR:
white spring, then change it to blue
red bars then had to remove it
shock mount top---3rd hole
shock mount bootom--inner hole
double pink 2 stage jaco
problem:
1) too slow compared to other cars--that's why I think its a gearing problem
I'm running 98/27 64 pitch
2) with the rear stabilizer bars and white spring--it has some oversteering problem with a little bit of push coming out of a corner,oh and yes the rear was hopping
3) without the rear bars and with the blue springs , damn, alot of of oversteering and rear has no traction at all and yes it was still doing the hop.
did'nt get the chance to do anything anymore because I have to go home , the wife is waiting, setting up can wait but the wife can't
so guys any advice? BTW I was running a monster stock pro and change it to 19t, I still can't keep up with the other guys, nope I'm not hitting any walls, I just think my gearing is set up wrong.
let me give another scenario about my gearing.
Started with 98/22 good acceleratin low topend.
103/30--FLAT-poor acceleration,poor top end
100/30/29/28/27--same as above
so I went back to 98/27--its OK--but not as fast compared to the other cars.
THANKS
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-04-2005, 06:44 AM   #2167
Monster Stock Pro, indoors, carpet I am on 78-24 = 7.3:1 drive ratio and it is fast, this was on rubber, need to know tyre diameter and type of track (open, tight etc) and surface.
Old 12-04-2005, 06:54 AM   #2168
cheehtae's Avatar
tire diameter- 57-58
track is tight and bumpy( carpet)
LMK what else
Old 12-04-2005, 08:11 AM   #2169
I think you could be very much undergeared, my tire diameter is 66mm and I am geared quite a bit more than you, if you can calculate your MM/PR then you will see your roll-out is quite low, maybe your burning up the motor hence the lack of power?? Sometimes with stock, they need to be geared as they can be lazy.
as for the handling, I think you need to go back to a basic setup, use the same roll-bars all round, start with the medium and medium springs. It also sounds like your car is pitching on/off power hence off-power oversteer and on power understeer. Try going to the 2 hole pistons all round and a thickish oil, maybe 50wt all round to try and calm it down, then work from there. If you can get the car stable but just need to alter where the grip is in the corner, then you can change caster.
With the carbon conversion, it will make the car generate more grip, so if your rear isn't set quite right it will be more noticeable.
Old 12-04-2005, 08:35 AM   #2170
I'm sure by now just about everyone has heard of gearchart.com. So, go to that web site and you can calculate roll out and gearing on that site for free. Makes foam racing so much easier. Print out from like 60mm then 59.5, 59.0 and so on until you get to about 55.5 on tire sieze. You will have all roll out charts needed and no trying to calculate roll out at the track. Then just go to your local fast guy's and ask them their roll out and go to your chart and copy it. Easiest way to find the right gearing.
Juan Aveytia is offline   Reply With Quote
Old 12-04-2005, 08:43 AM   #2171
With the carbon conversion, it will make the car generate more grip, so if your rear isn't set quite right it will be more noticeable.[/QUOTE]
Usually a car that flex's more, will give more grip all the way around and make the car feel lazy. A stiffer chassis will usually give much less grip than a chassis that's flexable. So, if you switch to the graphite conversion your car should free up more in the turns.
Old 12-04-2005, 08:58 AM   #2172
OK, I will re-phrase, a stiff chassis will give more useable and predictable grip than a floppy chassis, especialy considering he is running foams on carpet.
As for the site, never used it as I never run foams.
Old 12-04-2005, 09:12 AM   #2173
As for the site, never used it as I never run foams.[/QUOTE]
That site is great for rubber tire gear charts. You should check it out.
Old 12-04-2005, 09:15 AM   #2174
Don't tend to change tyre diameter that much in rubber tyres, so never had the need and gear ratio charts, always made my own, but will keep it in mind if I ever go and try foam tyres, thanks.
Back to the guys problem, if you are getting over and under steer, then the car is being allowed to pitch to much with throttle input, so you need to increase the pack in the shocks to slow the movement down.
I always believe that if you are struggling, go back to the factory settings for shock positions and camber links and work from there.
Old 12-04-2005, 09:16 AM   #2175
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
From my experiences a stiffer chassis carries more corner speed and transitions faster. A more flexible chassis digs a lot more in the corners and is slightly slower in the transitions. I feel that there is definately such thing as too stiff. A car set up like a brick tends to be harder to drive, and harder to make consitent. It makes it too twitchy. I have my 05 setup with the standard chassis but with the TECH upper deck, and I feel that the car is 100% better than stock, and it was REALLY good stock. I don't see any need for the Xenon chassis for carpet. I have at least 30 packs through my car on foams/carpet and it lacks nowhere. Save the money and get the TECH upper deck...or if you have to have the bling then get the Xenon, but don't expect to automatically go 3 laps faster.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
