Like Tree2Likes
Old 11-24-2005, 12:49 PM   #2071
fat500's Avatar
Trader Rating: 29 (100%+)
Default set up is....
take off cs27 on all fours, 65wt ft and rear . no sways. just can't get the turn in.
fat500 is offline   Reply With Quote
Old 11-24-2005, 12:57 PM   #2072
fat500's Avatar
take off cs27 on all fours, 65wt ft and rear . no sways. just can't get the turn in. very well prepared permanent track ....very smooth ashphalt.
Old 11-24-2005, 01:19 PM   #2073
I would drop the weight of the shock oil and then add sway bars for stability, thats what I did on carpet.
DA_cookie_monst is offline   Reply With Quote
Old 11-24-2005, 01:22 PM   #2074
TRF415boy's Avatar
What shocks are you using ? TRF or plastic ? It makes a whole lot of difference if you're using 65W with 3 holes in the TRF or the plastic shocks. If TRF, I'd say try 55W with 3 holes. Otherwise i'd say get TRF ones, lol.
Other ideas : softer springs on front, bit of toe out, more rear droop, using C2 left C1 right instead of the opposite (front knuckles) so as to lower the front RC (make sure you re-set droop by measuring the axle's height if you do that, and you'll have to redo ride height), sway bar on rear, more angled/shorter rear upper links...
TRF415boy is offline   Reply With Quote
Old 11-24-2005, 02:17 PM   #2075
What tire inserts are you using? Try softer ones. Also, take out the front stabilizer bar.
trf_racer is offline   Reply With Quote
Old 11-24-2005, 02:37 PM   #2076
Originally Posted by brettb76
I want to use some 64 pitch gears in my car. I cannot purchase them locally so I will need to buy them from overseas on the internet.
I want to have a final ration of 6.6:1.
Will a 88 tooth spur and 30 tooth pinion fit in a TA05.
Alternatively
Will a 132 tooth spur and 45 tooth pinion fit in a TA05.
I am running in 540 class at my local club and they have a gear ratio limit of 6.6:1. I'm using 48 pitch and running 68/23 (6.652) but guys using different cars are running at 6.6:1 and have that slight edge. I want to be able to match them and 88/30 gives me the exact ratio.
I don't want to buy the parts and then have them not fit. $$$.
Because the gears are smaller than the 48 pitch gears I'm using, I'm not sure if the motor can be moved over far enough for the smaller gears to mesh.
I'm hoping someone has a TA05 and already has these gears. If you could test it for me would be great.
brettb76 is offline   Reply With Quote
Old 11-24-2005, 02:59 PM   #2077
1shnot's Avatar
has anyone tried switching over to ti-screws and swing over to graphite shock towers front and rear.... saving weight? and if so how much?
Just trying to figure out if it's worth it..
thanx alot
1shnot is offline   Reply With Quote
Old 11-24-2005, 03:48 PM   #2078
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally Posted by dway100
madjack
Can you post some pics of your car for us?
too....full.....must.....sleep.....
I'll make an effort to some pictures later after the turkey coma subsides
madjack is offline   Reply With Quote
Old 11-24-2005, 04:29 PM   #2079
the titanium srews makes it easier to wrench on and changing to cf shock towers adds eye candy and reduces flex. Overall weight savings negligible cos the car stills weigh a tonne....i recon around 30+ grams
erric_13 is offline   Reply With Quote
Old 11-24-2005, 04:36 PM   #2080
TRF415boy's Avatar
Default C1/C2 explanation
Since i've received a PM from someone who didn't know there was a difference between the steering knuckles on the standard suspension, I took a picture.
Here are two C2 knuckles, you can read it on the far end of the lever. You can clearly see that on the right hand one, the bearing sits lower than the other one (the knuckles are roughly placed symmetrically, if anything the right one is a bit higher on that picture).
What does this means ? Well it means if you break one and take any off your bag and end up having the same on both sides of your car, your car will be tweaked and you're unlikely to find out why. It also means that you can play with the roll centre. Using C1 on the left will set a high distance between the wheel axle and the wishbone axle. As a consequence, the roll centre will be high, making the car easy to drive. This is the standard setting on all of the tamiya cars.
Using C2 on the left will diminish the distance between the wheel axle and the wishbone axle, hence lowering the roll centre. the car will be more agressive, but less responsive too. It also changes slightly the bump steer so if you ever try this, you might want to remove 2mm of shims under the ball joint of the steering plate. You will also need to re-set the droop.
My advice is to measure your droop before flipping the knuckles over, by measuring the distance between the top of the wheel axle and the ground, with the chassis lying flat on a setup board (no wheels of course). Once you've done that, you can flip them and re-set the droop to get the same axle's height. You could also measure the ride height before flipping the knuckles, and after. The difference is the wheel axle's height difference. Then just change the droop of that amount (less precise method though but it don't require a caliper).
Hope this helps you all, sorry for the long post for those who knew it.
Old 11-24-2005, 04:41 PM   #2081
TRF415boy's Avatar
thanx alot
The plastic towers are 12g for both, and for two C/F ones you're looking at 10g so nothing worth bothering weight wise. However as it's been stated, they'll offer a much higher rigidity and so, better response to any change in damping/springs setup.
Old 11-24-2005, 05:19 PM   #2082
1shnot's Avatar
nice.... i'll try that thanx!!!!!!!!!
Old 11-24-2005, 05:52 PM   #2083
dyaz21's Avatar
Hurry up... I want to see it... NOW! (this is eeyan btw... )
dyaz21 is offline   Reply With Quote
Old 11-24-2005, 05:56 PM   #2084
Ghostfit's Avatar
Is the ta05 a better handling chassis. I run a tbo2 trf and is it plenty fast as the tc4 at my track but i cannot get the tight corning . Tried every possible set up. Does the 05 feel more stable and handle any better.
Should i switch to the ta05? what do you think? Thanks? Thanks for the help.
They're both very good chassis, depends pretty much on your personal preference ....shaft or belt !
From your description, I think 65W is a little too slow, try 30w or 40w (with 2 hole piston)
A few reasons why you can't turn tightly:
1) Tyres dun have enough grip.
2) Chassis setup way out.
* Camber/Caster.
* Front toe in or out/Rear toe in.
* Droop settings.
* Ride Height.
3) Shocks setting.
* Static damping (Oil/Piston combination)
* Spring stiffness.
* Shocks mounting position.
4) Drivetrain/Driving style mismatch
* Single or Double one-ways (Smooth throttle with hardly any brakes)
* Front Diff or Spool (Hard charging and heavy braking at almost apex of turn)
....theres more but I doubt anyone wanna read that !
Ghostfit is offline   Reply With Quote
Old 11-25-2005, 12:29 PM   #2085
madjack's Avatar
alright...alright, here you go
Tamiya TA05 Touring Sedan-img_2959.jpg   Tamiya TA05 Touring Sedan-img_2961.jpg   Tamiya TA05 Touring Sedan-img_2962.jpg   Tamiya TA05 Touring Sedan-img_2964.jpg
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
