Like Tree2Likes
Old 11-24-2005, 12:01 AM   #2056
utieh's Avatar
Here you go!
utieh is offline   Reply With Quote
Old 11-24-2005, 01:35 AM   #2057
it seems like the Tn racing chassis is a better thought out design cos it did w/o the front and rear wing chassis stay,minus point is that the motor area is exposed. just my 2cents worth...what do you guys think?
However kudos for the effort to make the kit.
erric_13 is offline   Reply With Quote
Old 11-24-2005, 01:44 AM   #2058
dodo's Avatar
Send a message via Yahoo to dodo
is that Xenon? ok now i want those, but i like the TN upperdeck better. lovin' the blue stuffs on xenon, is the blue parts like motor mount and blue bulkhead cover, part of the conversion kit?
dodo is offline   Reply With Quote
Old 11-24-2005, 01:48 AM   #2059
dodo's Avatar
oh seems that it's actually from xenon website. i believe that those will be available in future. NICE!
Old 11-24-2005, 02:06 AM   #2060
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by utieh
Here you go!
DAMN I ALSO WANT IT, ONLY THING MISSING IS THE SQUARE BLUE ALUMINUM BATTERY STRAP
buboy28 is offline   Reply With Quote
Old 11-24-2005, 02:21 AM   #2061
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
hey, that looks awesome.
i have a problem with building the Diff for the 05. basically it seems like the long screw that goes through the diff is to short and does not quite reach the lock nut. im pretty sure ive built the rest fine as ive built Tamiya diffs alot and they are pretty much the same.
Just wondering if anyone has had this problem or has a solution to it.
Thanks Tom
mild seven is offline   Reply With Quote
Old 11-24-2005, 02:25 AM   #2062
dodo's Avatar
Thanks Tom
there's a post about similar problem encountered 1 or 2 pages back. yet to hear whether his problem is solved.
Old 11-24-2005, 07:01 AM   #2063
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by brettb76
I am running in 540 class at my local club and they have a gear ratio limit of 6.6:1. I'm using 48 pitch and running 68/23 (6.652) but guys using different cars are running at 6.6:1 and have that slight edge. I want to be able to match them and 88/30 gives me the exact ratio.
I don't want to buy the parts and then have them not fit. $$$.
I was running a 64p 103/30 combo and was using 27t motor, one thing I noticed is the car was really slow, so I went to 100/30-100/29--100/28 and still the car was slowso what I did was this---
98/30,98/29,98/28,98/27-- man the car was very responsive , I know my gear ratio is way off but it works for me. Of course I would like to have someadvice too.
tnx
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-24-2005, 07:09 AM   #2064
Mild Seven--check your instructions again for the diff assembly. You prolly have the spring on the worng side of the diff. Others at the track have had the same issue and usually that is the first place I look.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 11-24-2005, 07:14 AM   #2065
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
What motor mount is that? Din't know any blue ones were out.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 11-24-2005, 08:35 AM   #2066
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
my Xenon kit is built...but it does not included the gearboxes, motor mount or spur mount.
Who's product is that?
madjack is offline   Reply With Quote
Old 11-24-2005, 09:01 AM   #2067
madjack
Can you post some pics of your car for us?
dway100 is offline   Reply With Quote
Old 11-24-2005, 09:11 AM   #2068
fat500's Avatar
Trader Rating: 29 (100%+)
Default Question? what do you like better TB02 or TA05?
Is the ta05 a better handling chassis. I run a tbo2 trf and is it plenty fast as the tc4 at my track but i cannot get the tight corning . Tried every possible set up. Does the 05 feel more stable and handle any better.
Should i switch to the ta05? what do you think? Thanks? Thanks for the help.
fat500 is offline   Reply With Quote
Old 11-24-2005, 09:15 AM   #2069
RandomFellow's Avatar
Thanks Tom
Yeah, the screw is too short to engage the locknut when the spring is fully expanded. What I did was just take a pencil a push down on the locknut assembly as I pushed from the other side with the allen wrench. It went together quite easily that way.
RandomFellow is offline   Reply With Quote
Old 11-24-2005, 09:32 AM   #2070
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
What do u race on? Carpet? Asphalt? Rubber? Foams? We need more information. I run on carpet and with foams, and the car is very easy to setup. I learnt my setups off my TA04, and any changes to spring settings, toe, camber etc, is all reflected on the track. Cant comment on the TB02 as ive never driven one (dont like shaft cars ) but i run my TA05 and 415 whenever i race, and i can notice the same feedback from the car when making similar changes to both chassis. Im lovin the 05 Cant decide on which carbon decks to get.... any news if Tamiya is going to speed up their release of carbon decks for the 05 due to the release of the aftermarket ones? I always prefer to keep it TCS legal
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
