Like Tree2Likes
Old 11-08-2005, 06:27 PM   #1921
Ghostfit's Avatar
Originally Posted by zax
TA05 use the stock arm or lightweight arm is better?
Depends pretty much on what you want.
Stock Arms = Very much stronger, Suspension pin less likely to bend when you whack the walls but they are also heavier.
LW reversible arms = Lighter and thus car has a little faster responses to input but suspension pin are very likely to bend at the slightest clip with the wall.
My advise is to choose your arms according to your driving skills (or Wallet size)
Originally Posted by F1mechanic
Some time ago somebody posted a picture of a TA05 with this item:
Tamiya "DJ" Pro-Module Rear Suspension System
Does anybody know if it works well on the TA05?
It look great, but that guarantees nothing .
Alwin.
I think most who has the DJ arms would be putting it on their shelfs queens, they're too expensive to be races on a regular basis unless you're got endless $$$
Ghostfit is offline   Reply With Quote
Old 11-08-2005, 08:16 PM   #1922
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
when using the lightweight sus set, take note of the rear hub's 950 bearings, as these bearings dont take knocks as well compare to stock 1150 bearings.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-09-2005, 07:05 PM   #1923
Regional Moderator
Darkseid's Avatar
What would be the effect of lengthening the wheel base on the car?
Its been a while since I thought about messing with wheelbase, so I need a refresher course.
TLR 22...Tamiya F104...
Old 11-09-2005, 07:54 PM   #1924
Making the wheelbase longer will make the car more stable but you won't get as much steering.
trf_racer is offline   Reply With Quote
Old 11-09-2005, 07:58 PM   #1925
That's for sure. That's why sometimes I don't like the LW suspesnion but I still use it. Also, those 950 bearings wear out quickly. BTW, I haven't broken anything on the LW suspension since I put it on my TB-02 in August. No, I am not a pro driver. Sometimes I hit the rails.
Old 11-09-2005, 08:01 PM   #1926
MYXTYPLYX's Avatar
Wheel base is all about how you distribute static weight.
The static weight depending on the end of the car you tune will effect your car's turning ability.
ex: Adding more static weight to the rear by moving your wheelbase forward will make the car looser.
Hope this helps...
MYXTYPLYX is offline   Reply With Quote
Old 11-09-2005, 08:02 PM   #1927
Regional Moderator
Darkseid's Avatar
Thats what I thought...
...and thats the effect I was looking for. I might try that this weekend.
Old 11-09-2005, 09:24 PM   #1928
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Originally Posted by Hebiki
whats up chris! can i join in too? i have a TA05 also! too bad im in socal
someone take a video and post it in here.
Hey Bro...hee..hee... yes...tons of actions here with the TA05.
Big players just don't know what hit them in the head...doooh!!!!.
I yet to get one....though.
Another car to add to my collections.
Yeah...sure do...will try and take a video clip.
Maybe one day...we'll come by Socal for a boot...
CHRIS LIM
OVERGEARED RACING
chrisman is offline   Reply With Quote
Old 11-09-2005, 10:13 PM   #1929
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
guys, will the DJ pro suspension kit work with the TA-05 thanks
buboy28 is offline   Reply With Quote
Old 11-10-2005, 01:45 AM   #1930
Hebiki's Avatar
Trader Rating: 26 (100%+)
it fits.. if thats what your asking. not sure how well it'll work exactly. anyone have a spare set. ill try it out on mine!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-10-2005, 09:49 AM   #1931
Steven Key's Avatar
Does anyone have a good set-up for rubber tire carpet?
The carpet is Ozite.
Tires are 27 Take-Offs.
I'm willing to spend the money on Hop-ups.
Thanks in advance for the help.
Steven Key is offline   Reply With Quote
Old 11-10-2005, 09:56 AM   #1932
45wt front, 40 wt rear, 2 hole pistons on TRF dampers.
Shocks in kit positions on the front, kit lower on rear, one hole further out than kit on the rear tower. Yellow springs all round.
Red Roll Bars
1' camber all round
0' toe on front
5mm ride height on the front
5.5mm ride height on the rear
small amount of droop on the front slightly more on the rear (increase if back end drifts).
G6 Protoform shell.
If you can, mount the tyres on Inch-Up rims with firm inserts.
DA_cookie_monst is offline   Reply With Quote
Old 11-10-2005, 11:27 AM   #1933
Steven Key's Avatar
Good info
How about rear toe in?
Are you running the kit standard 1 degree or have you changed it?
Old 11-10-2005, 12:00 PM   #1934
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Actually, the kit standard TA05 should have 2-degree rear uprights, and that's all you'll really need in most cases..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 11-10-2005, 12:21 PM   #1935
I run all kit parts except for CVD's, RW 48dp spur and TRF shocks and roll bars.
I couldn't see the need to drop or increase the rear toe of this car, only thing I would do (on a stiffer chassis) is move across to allow hinge pin hangers.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
