Like Tree2Likes
Old 11-07-2005, 07:40 PM   #1891
MYXTYPLYX's Avatar
Originally Posted by axle182
Just finished racing my 05 at the first leg of our West Canadian Indoor Champ Series. Ultra impressed with the car. I did find a few problems. The car handled superb, and was actually puting down times exactly the same as a fk05. Now, if we had any kind of tech at the race, i think the 05 would have pulled ahead, as my 05 was carrying ALOT more weight that the FK. It was setup for stock, 28mm jacos on ozite carpet, PF G6 body. I also included 2 fans for the motor, and the motor ran strong from the start to finish. Heres the setup -
Missed TQ by .02 of a second, and that wasnt a clean run. The car was perfect. Carried tremendous corner speed, was VERY stable under brakes, and through the sweepers. Also very good on change of direction. I got hacked on the first corner and realised straight away something was wrong. front toe was way out, and it only got worse. The left hand servo mount had broken. I was running a metal gear servo, metal servo horn, and no saver. Ill be on the look out for a alloy servo mount for the 05. Apart from this tiny peice, the car was FAST. Not bad for a plastic 05 against a top of the line FK05!
I didnt change anything from this setup except the front camber link height. I started at around 6mm, and dropped to 5mm for a little more steering. Also just re-adjusted ride height and droop after every second run, to allow for changes in tyre diametre.
Good job! Great to hear your performing well with the car.
We were also up against some big hitter cars as well(No names are mentioned to protect the innocent).
I've no dought that they will step it up soon and will get harder to stay in front, but this car practically drives itself, it's that easy to go fast.
Keep up the good work and the good advice. Love the race reports...
MYXTYPLYX is offline   Reply With Quote
Old 11-07-2005, 07:44 PM   #1892
MYXTYPLYX's Avatar
Originally Posted by stikman
you forgot to add that you two also have the fastest motor out there!
What are you doin on this tread???
You don't drive an 05? I think we have a spy in our midst.
Well yeah, those Putnam motors we killers.
We'll have to gear it right next time.
Old 11-07-2005, 07:50 PM   #1893
Veteq's Avatar
Hey guys
Next week i will be in Stock with you guys. I am finished my car. Carbon fiber will rule again
Alfred
Team Associated - Reedy Motors - Team Much More
Slapmaster Tools - Apollo Hobbies - Hi Performance Distribution
Overgeared B.O.D - [email protected]
www.AEforums.co.uk
Veteq is offline   Reply With Quote
Old 11-07-2005, 07:52 PM   #1894
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Well that makes sense...just thought if you were running foams that yellows would be WAY soft.
Has anyone run foams on carpet with the swaybars? Should you go softer on the spring to compensate?
Originally Posted by MYXTYPLYX
I was the other TA-05 with RCSPEEDO out there this weekend.
We were on rubber tire and 2 different types as well as diff compounds I might add.
Our race setup might sound a little odd to some of you but we test and compare our lap times with each other as well as closely look at each other's cars to see how the setup is performing.
The yellow springs all around helps with not relying on the tires only for traction while keeping the car's trancision quick thru the corners. Both fast and slow corners.
The hard blue swaybars and the high roll center keeps the car flat thru the corners allowing the suspension to do it's job.
We also lessened the droop to approx. 1mm front, 1.5mm rear.
This allows the car to corner tighter while maintaining a higher corner speed.
This car has great balance and is all about corners. Try to start rolling the throttle on thru the corners earlier while holding your tight lines. The car can hold it and reward you with faster lap times.
Next week we test with 19T rubber. We'll keep you posted...
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 11-07-2005, 11:04 PM   #1895
MYXTYPLYX's Avatar
Originally Posted by Veteq
Hey guys
Alfred
You are also not welcome here. Mr MSX driver...
Bring it! Dan has one for sale remember? Then you'll be welcome back, lol.
Old 11-07-2005, 11:06 PM   #1896
MYXTYPLYX's Avatar
Stiffer for foams is good but don't go over board. It will get the car too spriggy and keep th e suspention from doing it's job properly.
Balance is key.
Old 11-07-2005, 11:06 PM   #1897
rcspeedo's Avatar
Hey!, almost everybody was running a putnam, but you forgot one thing.....
we were running a TA05! put a fast motor in a fast car and what do you get!?
rcspeedo is offline   Reply With Quote
Old 11-07-2005, 11:14 PM   #1898
rcspeedo's Avatar
I would welcome him if he uses plastic shocks and steel screws!
But I doubt he will do that, he needs all the advantage he can get!
Old 11-07-2005, 11:16 PM   #1899
Veteq's Avatar
Give me a part number for the shocks or lend me a set.
I think it would look weird on a MSX. But it is lighter than my aluminum shocks
www.AEforums.co.uk
Old 11-07-2005, 11:21 PM   #1900
rcspeedo's Avatar
And the steel screws?!???
Old 11-07-2005, 11:22 PM   #1901
Veteq's Avatar
i will add some lead weight on my car
www.AEforums.co.uk
Old 11-07-2005, 11:25 PM   #1902
rcspeedo's Avatar
It's a deal! if you let me and Myx put the lead weights!
Old 11-07-2005, 11:32 PM   #1903
Veteq's Avatar
do you really need to do that you guys are undefeated in two races.
www.AEforums.co.uk
Old 11-07-2005, 11:36 PM   #1904
rcspeedo's Avatar
Nah! Just messing with ya
On a serious note... you should grab on Dan's offer before somebody I know does
Old 11-07-2005, 11:37 PM   #1905
Veteq's Avatar
I wanna see it myx said he was going to get me a picture
www.AEforums.co.uk
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
