Tamiya TA05 Touring Sedan >
Like Tree77Likes
Old 10-25-2005, 07:30 PM
  #1771
Core Creations's Avatar
Trader Rating: 110 (100%+)
Is it available overseas yet?
Core Creations is offline
Old 10-25-2005, 07:31 PM
  #1772
quantum's Avatar
yeah, and did fred say when it would be available here?
quantum is offline
Old 10-25-2005, 07:43 PM
  #1773
maxepower's Avatar
Cool RE: New light weight chassis
Tenatively speaking, he said maybe by the end of the year?
maxepower is offline
Old 10-25-2005, 07:54 PM
  #1774
Any shop online? Part #
Old 10-25-2005, 08:13 PM
  #1775
johntrickle1's Avatar
Default Plastic Toe Blocks
The stock suspension blocks are 41mm wide measured from hole to hole (outside edges).
Is this how we are supposed to measure the suspension blocks?
thanks.
johntrickle1 is offline
Old 10-25-2005, 09:09 PM
  #1776
Aparatchik's Avatar
I like the look of that chassis! Anyone know how much weight it saves?
Aparatchik is offline
Old 10-25-2005, 09:41 PM
  #1777
over gear's Avatar
Trader Rating: 18 (100%+)
anyone know where I can download the TA05 assemble manual?
over gear is offline
Old 10-25-2005, 10:49 PM
  #1778
MYXTYPLYX's Avatar
Originally Posted by maxepower
I was there also and I noticed Tamiya North America still doesn't have the new tub chassis. Fred told me that it is not only lighter with all the added holes but it is made out of graphite and plastic instead of fiberglass and plastic which is what the original tub is made out of and that I didn't know, so this is what the TA04-R chassis was made out of graphite and plastic! Right? If you get this chassis you better be real careful not to short out your batteries against this chassis if not major glitches will occur! I had problems with that on the 04 because of the tight fit using side packs. The 04 tub was designed for stick packs where as the 05 is designed for the side by side battery config.!!!!!!
Just my 2cents!
That is 1 fine looking chassis. Ta-05R looks to be well on it's way.
MYXTYPLYX is offline
Old 10-26-2005, 02:30 AM
  #1779
Hebiki's Avatar
Trader Rating: 26 (100%+)
30grams over the original stiffer also.
Hebiki is offline
Old 10-26-2005, 03:01 AM
  #1780
Is the new chassis available in japan at the moment? Or when is it going to be released?
Seatbelt is offline
Old 10-26-2005, 03:10 AM
  #1781
I want one of them chassis, can someone let me know where??
DA_cookie_monst is offline
Old 10-26-2005, 07:05 AM
  #1782
axle182's Avatar
Well im happier than a pig in sh^t lol. 05 arrived last night, and finished installing everything ready for practice tonight. Will keep u posted on how it handles. Ive seen a few setups on here, but figured id try it with an 04 setup i liked and work from there. Ill be swapping out the upper screws with either titanium or aluminium blue Love the car so far, and yes its quiet!
Attached Thumbnails Tamiya TA05 Touring Sedan-dsc01919.jpg   Tamiya TA05 Touring Sedan-dsc01921.jpg   Tamiya TA05 Touring Sedan-dsc01922.jpg
axle182 is offline
Old 10-26-2005, 07:09 AM
  #1783
Regional Moderator
Darkseid's Avatar
axle182: Very nice and clean layout you have there with the brushless. I've seen some brushless setups that look like someone dumped a bowl of colorful spaghetti on the car.
I had started to wonder whether it was even possible to get a clean wire set up with those systems in. Good to see it is.
Darkseid is offline
Old 10-26-2005, 07:41 AM
  #1784
Well, this is a first, must be good, my GP3700 cells fit in my TA05 far better than my GP3300 cells
Old 10-26-2005, 08:49 AM
  #1785
axle182's Avatar
Its definately not the cleanest wiring out there. I wish that novak would put plugs on both ends of the sensor wiring, and include different length wires in the package. im a bit worried it will thermal as the esc has wires all around the heatsink.
axle182 is offline
