Like Tree2Likes
Old 10-23-2005, 12:12 PM   #1741
JoeyE
The part only comes in that tree. Its made out of plastic
Its the S Parts tree
9115157
JC
tiggersz is offline   Reply With Quote
Old 10-23-2005, 07:04 PM   #1742
JimmyMac's Avatar
Hebiki, you have PM....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-23-2005, 08:06 PM   #1743
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Originally Posted by JoeyE
Need help. Is this part plastic or metal? How can I buy this piece? I have th epart number but cannot find it to buy it.
Actually, you will be able to buy it soon.. in Tamiya's next wave of TA05 upgrades..
Part #53874 Center Pulley Bushing - TA05 High Precision
Install this precision-cut polyacetal part on spur gear holder center shaft to reduce vibration, wear and slackness of spur gear and drive belt.
Not very expensive either, only $3.60, they say.. heh..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-23-2005, 08:52 PM   #1744
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Once again...does anyone know where the stock or precision diff jounts are in stock in the US?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-23-2005, 09:01 PM   #1745
Try emailing doug at seattleindoorraceway.com replace at with the correct symbol. I think we have them on the peg at the shop, if so he usually can ship them out same day.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-23-2005, 09:24 PM   #1746
MYXTYPLYX's Avatar
Originally Posted by Aparatchik
Yep, was set up according to manual, with kit tires, TRF shocks & yellow springs all around. Surface was dirty asphalt, them kids don't keep their schoolyard too clean!
I'll be running it again today, on a different surface, and will have different springs with me to try out. Figured I'd go to blues in the rear as a start.
The kit tires will do it! Those things have no traction.
Couple that with the dirty parking lot equals no traction.
Keep the set-up and try different tires.
What's the new surface?
Good luck.
MYXTYPLYX is offline   Reply With Quote
Old 10-23-2005, 10:06 PM   #1747
Trader Rating: 27 (100%+)
Originally Posted by tiggersz
JoeyE
9115157
JC
Thanks again JC!
JoeyE is offline   Reply With Quote
Old 10-23-2005, 10:23 PM   #1748
the countdown to cf chassis begins......................just wish that it will not be too expensive....together with the front and rear bulk head...its going to hurt
erric_13 is offline   Reply With Quote
Old 10-23-2005, 10:54 PM   #1749
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
It's my understanding that Tamiya USA is not going to bring in the stock outdrives. so You shouldn't be able to find them in the US. That is also why they are bringing out the bushing as a hop-up, cause it is on the stock outdrive tree.
tamiyarcracer is offline   Reply With Quote
Old 10-24-2005, 04:23 AM   #1750
So what have you guys decided as the most beneficial hopups to the car?
Seatbelt is offline   Reply With Quote
Old 10-24-2005, 04:37 AM   #1751
johntrickle1's Avatar
Default Setup Sheet for TA05
Where can I find a blank setup sheet for this car?
Thanks.
johntrickle1 is offline   Reply With Quote
Old 10-24-2005, 05:59 AM   #1752
Jam-ehz's Avatar
There's a couple flying around.. the LW suspension, and the regular suspension.. just look up "setup sheet" within this forum and you'll find one..
Old 10-24-2005, 12:17 PM   #1753
Aparatchik's Avatar
I found out as much!! Ran the car yesterday on a clean asphalt surface with some borrowed CS22/27's, and was getting a lot more bite. Wear pattern on the tires indicated that the setup was pretty good on the whole. Still dealing with some snap oversteer when coming off the throttle, though.
I'm also learning that I need a LOT of practice, and that the the TA05 is extremely sturdy!!
Good luck.
Aparatchik is offline   Reply With Quote
Old 10-24-2005, 03:28 PM   #1754
Does the ta05 just use the ta05/tb02 LW suspension?
Old 10-24-2005, 04:47 PM   #1755
Jam-ehz's Avatar
Yup, everything except the universals, you'll need 48mm instead of the 42mm ones they give you in the kit.
Hopefully they'll just go and make a TA05 LW kit with the right universals included...
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
