Like Tree2Likes
Old 10-19-2005, 07:43 PM   #1711
jas
jas's Avatar
Does anyone if the shock mounting ball studs that come with the TRF "Special Blue" set are better than the original ball studs (gun metal color) of the TA05?
Just wondering if I should change them.
Thanks in advance!
jas is offline   Reply With Quote
Old 10-19-2005, 08:47 PM   #1712
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
the blue ones are aluminum. I dont think the stock ones are.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 10-19-2005, 10:53 PM   #1713
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks in advance!
gun metal is steel. the TRF Blue are aluminum. hold 8 in each hand and you'll feel the weight difference
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-19-2005, 11:05 PM   #1714
JimmyMac's Avatar
Are you talking about the "brass" ones that come in the kit? Just use the stock TA05 ones...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-19-2005, 11:32 PM   #1715
MYXTYPLYX's Avatar
Originally Posted by Aparatchik
Just finished building the car last night and installed the VFS-1. I've only taken a test run around the house, but I don't really think I've noticed it being quieter than other cars I've had. What should I expect as far as quietness/noise?
Also, what should I expect as far as free spin? Will the drivetrain free up over time, or should I be worried that things are binding?
I did the same at home and did not think about the quiteness untill I hit the track. Then it took me by surprise.
I would not worry about the drivetrain unless you have made any major errors.
Mine is built with stock bearings that I did not clean.
I used 1 notch for both front and rear. This helps free up the drivetrain. The belts will loosen after a couple of days of running at which time you can move up to 2 notches. Don't worry the belts won't skip in stock.
MYXTYPLYX is offline   Reply With Quote
Old 10-19-2005, 11:36 PM   #1716
MYXTYPLYX's Avatar
Originally Posted by CIVIC91
Any pics of the outdrive mod?
Sorry for the late response, I just got my camera back.
Here are some pics...
Tamiya TA05 Touring Sedan-176-7651_img.jpg   Tamiya TA05 Touring Sedan-176-7660_img.jpg   Tamiya TA05 Touring Sedan-176-7662_img.jpg
Old 10-19-2005, 11:39 PM   #1717
MYXTYPLYX's Avatar
Here's more...
Note the plastic shocks will stay on this car.
Tamiya TA05 Touring Sedan-176-7650_img.jpg   Tamiya TA05 Touring Sedan-176-7657_img.jpg
Old 10-19-2005, 11:42 PM   #1718
MYXTYPLYX's Avatar
Originally Posted by Steven Key
KilRuf
"Good idea"
Do you know what the toe would be with the 1A & 1B. I'm trying to get about 2 1/2 degrees of rear toe. I currently have the 1 degree rear hubs and a one way in the front. It is a stock motor running on rubber tires car.
Try staying with the 1 to 1.5 toe on the rear as it will free up the rear for a good rotation. With more you will just stall the rear and run slower.
Old 10-19-2005, 11:43 PM   #1719
MYXTYPLYX's Avatar
Originally Posted by tim fry
If using the standard shocks what is the best springs to use as there seems to be a couple of options?
Tim
Check out the pics...
Old 10-20-2005, 08:54 AM   #1720
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by KilRuf
Well I tend to ignore what the blocks toe should be. The setup I gave you with the blocks gives me 1degree toe in on my Integy setup station. But the chart says it's suppose to be 1.5degree toe in. I prefer that or less for Stock class with a spool. So if you are looking for 2.5 rear toe, then the chart says you need a 1B rear block with a 1XC block (if you are using 0degree rear hubs). You said you have 1degree rear hubs... so then you can stick the my setup of a 1XC/1X block. The chart says this will give you 1.5dgree rear toe plus your 1 degree rear block to equal 2.5degree rear toe. Oh, and you get a basic chart when you purchase the 1X# blocks. Hope this helps...
So can you purchase a set of the "X"blocks or does it come in individual package, currently I'm running a 0 degree on my rear and the stock block, and in my integy set-up the reading was 1 degree and I would like it to stay that way, so is it really in a 1 degree setting considering that I'm uing my stock blocks, sorry this block are confusing never ha any experience with this.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-20-2005, 08:56 AM   #1721
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Trying to figure this block thing out.
So the stock car comes with 2 degree rear hubs, and 0 degree inboard toe, right?
So if I want 1.5 per side, I want the X block in the front of the rear arms, and the XC in the rear of the rear arms?
Adn if I want 1.0 per side , I want the X up front and the XB out rear right?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-20-2005, 08:54 PM   #1722
MobileIT's Avatar
Default Steering Slop
I was just reading the TRF415 Forum. Since most of us know that the 415 has pretty much the same suspension options as the TA-05, I expect many of us are reading both these (or the TB-02, Evo III or a couple of other Forums for cars that use these suspensions). If not, I think you might want to take a look at what Martin Crisp has been saying recently. See page 360, message number 10797.
http://www.rctech.net/forum/showthre...page=360&pp=30
MobileIT is offline   Reply With Quote
Old 10-21-2005, 03:03 AM   #1723
I was under the impression that the 2 degree rear uprights meant that the rear had 2 degrees Toe-In. With equal blocks my rear wheels point inward.
Alwin.
F1mechanic is offline   Reply With Quote
Old 10-21-2005, 01:53 PM   #1724
Does anyone have the front carriers in stock?
Old 10-22-2005, 06:19 AM   #1725
which pinion i should use for stock indoor tight track? I use 0.4 spur 105T.
trf_skyline is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
