Like Tree2Likes
Old 10-15-2005, 02:18 PM   #1651
Exclamation
I thought that initially but the grinding has become almost too loud to be a bearing. It sounds almost like a stripped gear but it definately is not one.
NickRosie is offline   Reply With Quote
Old 10-15-2005, 03:03 PM   #1652
Does it make the noie with AND without the motor in, you running dogbones on any of the exles?
DA_cookie_monst is offline   Reply With Quote
Old 10-15-2005, 03:19 PM   #1653
jeffreylin's Avatar
R/C Tech Charter Subscriber
Just check your bearings. I've done this myself--took the car apart not believeing it's the bearing only to find out it was and wasted a couple of hours of my life.
jeffreylin is offline   Reply With Quote
Old 10-15-2005, 05:35 PM   #1654
maxepower's Avatar
Cool
I seem to have fixed my steering issues but as usual, as one problem is eliminated, another arises- My TA05 has the maddest grinding sound when I put finger to throttle. I've checked both front and rear pulleys, spur gear pully, diffs, most bearings and I've even opened the motor but haven't been able to find any stones or anything unusual for that matter! I have no idea why the car is making such a noise! (I'll even be replacing the SliGhTLy damaged spur to try rectify the issue tomorrow but I can almost guarantee this will not help!)
Please tell me someone in this forum has had a similar issue and is able to help!
Even the tinyist of debree will cause a noise. Look very closely and you will find something I GARONTEE IT! or your money back!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-15-2005, 05:37 PM   #1655
Exclamation
Thanks, Jeffreylin I'll check the bearings. No, I'm not running dogbones on the axels. I just checked and it does seem to only make the noise with the motor in. what do you suspect the problem may be cookie_monst?
Old 10-15-2005, 05:41 PM   #1656
maxepower's Avatar
Exclamation AHHHHHHHH! "Gilroy"
Originally Posted by johntrickle1
Thanks for the replies on suspension blocks...I read the article in the R/C Driver magazine and yes they will fit onto the TA05.
Anyone else with any Carpet Ozite setups w/ rubber or foam tires and monster stock motors?
Most of us are heading indoors for the Season, either at Hobby World(Gilroy, CA) or to Stockton RC Raceway.
Isn't the ROAR divisional race coming up in Gilroy? The track is awesome, I'd like to run a race there but don't you have to pay a membership fee to do a ROAR race? The Tamiya Champs were going up there to practice for the Japan race.
Not sure when?
Old 10-15-2005, 06:03 PM   #1657
Aparatchik's Avatar
I believe that race is next week... maybe I'll go down to check it out. Never been to a race!!
Aparatchik is offline   Reply With Quote
Old 10-15-2005, 06:44 PM   #1658
Regional Moderator
Darkseid's Avatar
Originally Posted by Key500
Have anyone had any problems with the battery shortening against the aluminum in the middle by the spur gear...
I can see that if you use large battery bars, it does get pretty close to the alloy motor mount. Thing is though, that only one battery bar is within' reach of the mount. Which means that even if by some off chance that bar did make contact, it wouldn't do anything. You would have to have a bridge between at least two bars before any shorting could occur.
Thats kinda a long winded way of say you have nothing to worry about!
TLR 22...Tamiya F104...
Old 10-15-2005, 09:03 PM   #1659
Ghostfit's Avatar
Had the same problem, ...changed the spur gear, sound disappeared.
.....5 packs later, sound reappeared, close inspection revealed a tiny grain of sand had lodged in the valley of the spur (almost need a microscope to see it)
dug it out, ......some how, it seems the motor mount / chassis will amplify the sound of a less then perfect gear mesh.
Ghostfit is offline   Reply With Quote
Old 10-15-2005, 09:25 PM   #1660
JimmyMac's Avatar
Someone asked for a foam tire carpet setup for Monster Stocks. I posted mine a few pages back.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-15-2005, 11:55 PM   #1661
Dongskie's Avatar
Trader Rating: 44 (100%+)
Originally Posted by izzyracer
What! Do you want Barry Baker to be Kidnap?
Hahahahaha!!
They won't kidnap him... nobody knows him here except the RC community...
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 10-15-2005, 11:58 PM   #1662
Dongskie's Avatar
Originally Posted by eeyan
Geetoo... need hookup! I'll be visiting you guys soon... woo hoo!
On behalf of Geetoo..... just let me know... our number is posted at our signature space...
See you soon!!!
Bajer 1/5th
Old 10-16-2005, 12:31 AM   #1663
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
here is mine.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 10-16-2005, 02:36 AM   #1664
rayman's Avatar
You think we kidnap just anybody?
Arnold Schwarzenegger goes to boracay and nothing has happened to him....yet.
Maybe if it was Bill Gates or Donald Trump.
rayman is offline   Reply With Quote
Old 10-16-2005, 04:17 AM   #1665
If that is the case, check the spur and the pinion first for any signs of damage, also, put the pinion onto the motor and spin the motor (anti-clockwise as you look at the pinion) and see if you get the ticking noise then, if you do, thats your brushes.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
