Tamiya TA05 Touring Sedan
#153
Originally posted by eeyan
YEHAY!!! Thanks for the info...
So you will be" OUR OFFICIAL" TAOB CAR CRITIC to determine if this chassis is as good as or better than the TA04!! Just like the magazines!!
#154
#158
#160
That did not take long
Along with the release of the TA05 a long list of optional and spare parts are being released as well, these parts include:
49360 TA05 Titanium Screw Set
Tamiya is offering this Titanium Screw Set for sale at the same time as the TA05 chassis so that users may install titanium screws when first building TA05.
53833 TA05 Front One-Way Unit
Considered indispensable for 1/10 electric R/C cars, this unit for the TA05 chassis features large capacity one-way bearing. Advanced design improves cornering speed and power transmission during acceleration.
53841 TA05 Center One-Way Set
This set provides an aluminum one-way pulley and spur holder for use with TA05 drive system. Parts may be replaced easily when broken or worn out, greatly reducing running costs. Compatible Chassis: TA05, TRF415 (excluding MS)
Set includes:
- OWC spur gear holder x 1
- Center one-way pulley x 1
- Crescent ring x 2
- TRF415 9x0.5mm plastic spacer x 2
- 4x10x0.5mm Washer (12300011-000R0) x 1
- 4x6x0.1mm Washer (adjustable) x 6
53842 TA05 Stabilizer Set (F & R)
3 kinds of front and rear stabilizer rods allow for wide variety of settings to suit different track conditions.
Set includes:
- TB Evolution IV front stabilizer rod (red, yellow, blue) x 1each
- TRF415 rear stabilizer rod (red, yellow, blue) x 1each
- 5mm adjuster (S) x 2
- RCC TA04-PRO stabilizer (steel) x 4
- Stabilizer ball connector x 3
- 2.6x10mm cap screw x 2
- 3x3 grub screw (W point, chromate) x 8
53843 TA05 Aramid Drive Belt
Low friction drive belt for the TA05 chassis features aramid fiber core. Aramid belt is softer and more flexible than kit-included belt, lessening rotation loss.
53844 TA05 Aluminum Transponder Stay
Aluminum transponder stay uses special snap pins to attach laterally to chassis.
Set includes:
- Aluminum transponder stay x 1
- Special snap pin x 2
- 3x12 octagonal button head screw x 1
53845 TA05 Front Carbon Damper Stay
3mm Thick carbon damper stay improves durability and operation efficiency. Perfect for use with reversible suspension system.
53846 TA05 Rear Carbon Damper Stay
53847 TA05 46mm Assembly Universal Shaft (2 Pcs.)
Packaging the popular assembly universal shaft with the perfect combination of parts for use with the TA05 chassis. Compatible Chassis: TA05, TRF415 (excluding MS). Must use F201 50mm long swing shaft to use with reversible suspension.
Set includes:
- 46mm Assembly universal swing shaft (steel) x 2
- Cross spider x 2
- Wheel axle x 2
- 2x9.8mm Needle roller pin x 2
- Hexagonal wrench (small) x 2
53848 TA05 Aluminum Racing Steering Set
Use of aluminum steering arm and linkage plate with press fit ball bearings improves durability, ensures stable running and realizes smooth and precise control and handling.
Set includes:
- Steering arm (L) x 1
- Steering arm (R) x 1
- 3x8 mm flat screw (black zinc) x 1
- Aluminum uni-crank post x 2
53849 TA05 High Precision Diff Joint
High precision machine cut polyacetal diff joint achieves smooth diff effect and improves overall road holding and road following performance.
Set includes:
- High precision diff joint A (short) w/ring x 1
- High precision diff joint B (long) w/ring x 1
53850 Titanium Coated Damper Shaft (2 pcs.)
53851 Titanium Coated 46mm Stainless Shaft (2 pcs.). Compatible Chassis: TRF415MS, TB Evolution IV
Spare parts:
51208 TA05 A Parts (Bulkhead)
51209 TA05 M Parts (Damper Stay)
51210 TA05 Drive Belt
51212 TA05 Ball Diff Pulley (36T)
51213 TA05 Center Pulley (16T)
51214 TA05 Center Shaft
51215 TA05 Spur Gear (70T)
51216 TA05 Drive Shaft (2 Pcs.)
Set includes:
- Crescent ring x 2
Set includes:
Set includes:
Set includes:
- Cross spider x 2
- Wheel axle x 2
Set includes:
Set includes:
Spare parts:
#162
the car looks sweet, i think i'll have that car for my dad. Then i'll just put his blue trf shocks on it.
#163
any bigger more clearer shots of this new Tamiya ride?
#165
