Like Tree2Likes
Old 10-09-2005, 07:38 PM   #1576
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Ok...I am going to list just the changes from the stock manual setup.
Front:
Assoc. 60wt. oil
3 hole piston
Assoc. Purple spring (30lb)
1.5 mm droop above ride height
Toe-1 deg out
4.5mm ride height
Rear:
Assoc. 40 wt oil
2 hole piston
Assoc. Copper spring
2 mm droop above ride height
5mm ride height
Everything else is set to the manual...diffs relatively loose, but no slipping.
I ran Plaid Parma foams cut to 59mm in front and I ran Purple Parma foams in rear cut to 59mm
Gearing on a medium flowing track with a Chameleon 2 was 104/32-33
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-09-2005, 08:15 PM   #1577
Just added some pics of my car in the for sale forum.
dway100 is offline   Reply With Quote
Old 10-09-2005, 09:50 PM   #1578
MobileIT's Avatar
Originally Posted by NickRosie
Okay, maybe I sould explain my situation a little better! I recently (2 weeks ago) bought and built a TA05. I've added TRF shocks, TA05 front and rear damper stays and a stabilizer kit. Apart from these, my car is set up according to the manual!
My issue- I'm due to compete in my second race meeting (Tamiya Cup) after my first was dismal to say the least. Didn't finish either of my 2 qualifiers and came second last in the main race.
The track has two large straights which I'd like to capitalize on. At the end of both straights are two sharp corners and the rest of the track is made up of fast, long corners.
I plan to race superstock with either a Tamiya TZ or RZ motor. If anyone has a similar type car and setup to mine, I would REALLY appreciate any advise in terms of general setup, shock setup, stabilizers or anything else! I am desparate to compete properly!
There are a number of setups described within the last 10 - 15 pages of this discussion. Read those and you will know a lot of what is known about this car so far. You have not really said much about the track (not even if it is carpet or asphalt), nor have you said what happened that stopped you from finishing in your 2 qualifiers.
A basic question: Do you know the difference between a car that is "loose" and a car that is "tight"?
MobileIT is offline   Reply With Quote
Old 10-10-2005, 05:21 AM   #1579
sorry about that! I didn't finish my 2 qualifiers cos of an old battery dumping and my car oversteering intensely due to a diff that was too tight. (I found this out a week later from guys at the track.) The track is asphalt.
Do I know the difference between a loose and tight car? No, I'm new to RC car racing.
NickRosie is offline   Reply With Quote
Old 10-10-2005, 08:13 AM   #1580
Thai3g_Eclipse's Avatar
If anyone's interested, my TA-05 is for sale. It's assembled and ran once but in immaculate condition.
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 10-10-2005, 08:57 AM   #1581
MobileIT's Avatar
Well that sounds like a good start. I also forgot to ask what body you are using, which is a major question. If you are racing Tamiya series then you have to use a Tamiya body. Some of the others may have an opinion about them. I do not race Tamiya series at all, so I ignore Tamiya bodies. If you can find one, try for a "high downforce" body, particularly in the rear of the car. I bought the Mercedes because it was closer to a normal Touring Car, which is what I will be running.
On "Tech RC" I have found that we are using the NASCAR language. So "loose" means "oversteer" and "tight" means "understeer" and is the same as "push". Thank Tom Cruise for that because before "Days of Thunder" nobody outside of stock car racing used the terms that way, but if you try to read this board, those are the terms you will run into the most.
My first general piece of advice it is to change the front end setup. The ball ends on the steering uprights are on the "back" holes. But the "front" holes should cause the front to "push" the farther the wheels are turned, which is "progressive" and better in most cases than simply adding "toe-out" (which is just pointing the wheels further apart). You might have to add "toe-out" also, but do this after you try changing the holes. Also, when you do this, you will have to "back off" (reduce) the steering on your transmitter because the front holes increase the steering effect. This is a very large adjustment and you might not like the result, that is why I recommend trying it early. Personally, I am still trying to use the setup in the manual, but I am not really taking racing as seriously as most everyone else here -- "I'm just here turning laps (and hopefully not hitting stuff :-)".
Old 10-10-2005, 09:20 AM   #1582
Tempted, good second car, PM me with specs.
DA_cookie_monst is offline   Reply With Quote
Old 10-10-2005, 11:22 AM   #1583
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Well, Ran the car this weekend. Got 3rd in Mod at the Mazda Cup2005. I had charger Issues so i wasnt getting a good full charge. I was qualified 2nd and DUMPED HARD in the Mains. I would have had at least 2nd Locked.
On Sunday at La Mirada, I got 3rd in Mabuchi CLass and 1st in 19 Turn. The car is just plain AWESOME! I finally added Universals and teh CF damperstays. I ended up using my Rhino Charger and guess what..i won!!!
Here is that i ran:
Alum shox 3 hole pistons 70 wt frnt/60wt rear
Blue Springs Fr/yellow rear
Red Fr/rr/ swaybars
center/front oneways
Lightweight outdrives in rear
Using a Protoform Mazda 6 Body
I tell you teh car is the most stable car i have ever driven!
Tires were TOP H10's.
My 2 cents
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 10-10-2005, 11:51 AM   #1584
topgluer's Avatar
Here is that i ran:
Red Fr/rr/ swaybars
My 2 cents
Hey Charlie , your Tire is TOP L10 for low traction track seem parking lot.
I got in your same 19T class 3rd , TA05 with TOP L20 tire
topgluer is offline   Reply With Quote
Old 10-10-2005, 12:06 PM   #1585
MobileIT's Avatar
Default Re. message 1581
Sorry, I used the wrong terminology. I meant to say to change the hole used in the "Front Uprights" (I said "arms" before which probably caused confusion). Oh well.
Also, I guess you will be looking into new batteries and possibly a new charger.
Old 10-10-2005, 02:36 PM   #1586
Steven Key's Avatar
Looking for a spec rubber tire carpet set up for a TA05.
Just got a new TA05 with the following hop ups:
TRF shocks
Front One Way
Center One Way
Lt. Weight Suspension
Carbon Fiber Shock Towers
Any set-up help would be appreshated.
Steven Key is offline   Reply With Quote
Old 10-10-2005, 02:47 PM   #1587
bender's Avatar
I am thinking of buying this car for my kids to race and I have a few questions.
1- What is the quality of the plastic components like? I am only familiar with older Tamiya cars and they had a lot of slop from new, and wore parts out quickly. Is this car the same or have they improved thier plastics?
2- What are the better front driveshafts, Tamiya or Cross?
3- The car comes with the older style suspension (not LW style), is this a disadvantage or is there only a little difference?
4- Do you have to cut any part of the servo case to get it to fit?
5- Has anyone raced it with the stock Mercedes body? Is the Merc body even legal?
cheers
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 10-10-2005, 05:13 PM   #1588
seth556's Avatar
Trader Rating: 42 (100%+)
1. As far as I have seen with people bashing their off road kits with the same type of plastic they should hold up very well, but all cars have their weeknesses.
2. I have no idea.
3. Not much difference.
4. No
5. Depends on where you race and even if they want you racing a certian type of body they will probaly let you race it once or twice.
seth556 is offline   Reply With Quote
Old 10-10-2005, 05:15 PM   #1589
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
actually, it does require part of one ear cut off the servo.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-11-2005, 09:27 AM   #1590
Smile Thanks
Thanks for the great advice MobileIT! I've changed the holes and I'll be testing the change at my local track tomorrow and yes, I understand understeer and oversteer now that you mentioned the difference in terminology!
I've been running with the std Merc body but recently bought a the Suburu Legacy body which apparantly handles unbelievably well. Haven't tested it yet.
I bought three 2400mAh packs (tamiya cup regulation) and a better charger. These seem to have made a world of difference in terms of run times and have given me more room to play with higher gearing without my packs dumping midway through races!
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
