Like Tree2Likes
Old 10-06-2005, 06:55 AM   #1531
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by KilRuf
Yeah, so far my fully hopped up TA05 is every bit as fast as my fully hopped up EvoIV. And it just drives sooo much more smoother! I will say it is heavier. But with my current setup and track rules... They now weigh the same. My EvoIV has a tad more acceleration. But my TA05 has a tad more corner speed. Give or take... it all comes out even on lap times.
well they say that SD cars has more speed than BD cars, anybody care to comment on it? Personally for me I like BD's they are much more quieter , I have had a couple ( pro4 & TC4) but sold them , one thing for sure BD's are alot smoother.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-06-2005, 07:09 AM   #1532
A belt drive will be capable of carrying far more power through a turn than a shaft drive, but, if power is scarse (stock motor) then a shaft will accelerate better. Once you start putting power in a shafty, under acceleration, the chassis wants to twist (remember, for every reaction, there is an equal and opposite reaction), so with a shaft drive, the car wants to twist with a belt drive, it makes the rear squat, putting more power and more stability through the chassis.
DA_cookie_monst is offline   Reply With Quote
Old 10-06-2005, 01:12 PM   #1533
Default TA-05 Setup
I have a question I went to Tamiya yesterday to buy some 415 suspension
mounts and here's what they recommended me to get
Tamiya TRF415 Aluminum suspension blocks D Bridge for front inner
part#51064
Tamiya TRF415 Aluminum suspension blocks A front outer
part#51065
and for the rear
Tamiya TRF415 Suspension Mount (XA) for inner
part#53808
Tamiya TRF415 Suspension Mount (XC)for outer
part#53810
And this for use with the stock arms..
Also can someone explain the difference in letters like XA, XC etc. thanks
And is mostly everyone running the 4mm clamp type wheel hub?
Key500 is offline   Reply With Quote
Old 10-06-2005, 01:34 PM   #1534
Hebiki's Avatar
Trader Rating: 26 (100%+)
part#51064
part#51065
and for the rear
part#53808
part#53810
there are several blocks for the 415/TA05..... from NARROWEST to WIDEST
XD XC XB XA 1X 1A 1B 1C 1D
1A and 1D bridge blocks
different combinations will yield different toe-in and toe-out settings. with 3mm spacers any of the non-bridge blocks above can be flipped upside down and used as bridge blocks for the belts to pass underneath.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-06-2005, 01:40 PM   #1535
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Here are a couple better pics...retro fit a P-DUB bumper. Pardon the mix/mash screws...more blue comin!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-06-2005, 03:04 PM   #1536
Will the P-DUB bumper for the 415 fit the TA05 without modification?
dway100 is offline   Reply With Quote
Old 10-06-2005, 04:54 PM   #1537
Exclamation PLEASE HELP A ROOKIE OUT!
Okay, maybe I sould explain my situation a little better! I recently (2 weeks ago) bought and built a TA05. I've added TRF shocks, TA05 front and rear damper stays and a stabilizer kit. Apart from these, my car is set up according to the manual!
My issue- I'm due to compete in my second race meeting (Tamiya Cup) after my first was dismal to say the least. Didn't finish either of my 2 qualifiers and came second last in the main race.
The track has two large straights which I'd like to capitalize on. At the end of both straights are two sharp corners and the rest of the track is made up of fast, long corners.
I plan to race superstock with either a Tamiya TZ or RZ motor. If anyone has a similar type car and setup to mine, I would REALLY appreciate any advise in terms of general setup, shock setup, stabilizers or anything else! I am desparate to compete properly!
NickRosie is offline   Reply With Quote
Old 10-06-2005, 09:47 PM   #1538
MobileIT's Avatar
. . . And this for use with the stock arms..
The closest wheel hub size to the kit original parts are 5mm. Depending on your setup, you might even be able to use 6mm. If you use the 4mm, you will probably have to cut away part of the ball cup on the front turnbuckles which will rub against the inside of your wheels.
You are probably better off using the 5mm parts.
MobileIT is offline   Reply With Quote
Old 10-06-2005, 10:21 PM   #1539
Regional Moderator
Darkseid's Avatar
My almost stock TA05...
With F430 body...
With Mazda 6 body...
Tamiya TA05 Touring Sedan-ta05_chassis.jpg   Tamiya TA05 Touring Sedan-ta05_f430.jpg   Tamiya TA05 Touring Sedan-ta05_mazda6.jpg
TLR 22...Tamiya F104...
Old 10-06-2005, 10:33 PM   #1540
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
are those Kyosho shocks i see on there? looks kinda like KX-Ones, i think!!!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-06-2005, 11:43 PM   #1541
Default TA-05 Setup
Thanks Mobile I already bought some 4mm but I guess I'll measure the original plastic one in the kit, because I notice with 4mm the wheel goes in really close and there's alot of thread left after I tighten the wheel down shown here is there some shims I can use to push the wheel out more or is
it just those Tamiya that fit like that...
Old 10-06-2005, 11:58 PM   #1542
maxepower's Avatar
Talking
I would put a 1mm spacer behind those wheels!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-07-2005, 01:39 AM   #1543
Regional Moderator
Darkseid's Avatar
Damn good eye you have there!!!
Yes, those are Kyosho shocks mounted up with the original 'floating piston' system still installed. I figured they'd worked well in the past, why not give them new life....and save about $60 on new alloy shocks in the process.
Old 10-07-2005, 03:30 AM   #1544
Hebiki's Avatar
Key500
your body mounts/posts should be on the other side of the shock tower. that way you can use any of the holes on the shock tower for your shocks.
Hebiki Design Works
Old 10-07-2005, 07:16 AM   #1545
Turbonium's Avatar
i have a car in the closet to match those shocks.... i ran it a couple times, but i used the TRF shocks, kinda opposite! my first KX i ran with the stock shocks, and found it a little bit strange.
Wes
Team Novak
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
