Tamiya TA05 Touring Sedan
#1502
My guess is that because it running on wood, so really low grip, he's using the white rear springs to get good on-power steering.
I've done it myself on my 415 before, running indoor on wood. Used soft springs on the front, hard on the rear, with dual 1-ways.... car was so fast and easy to drive! Given the TA05 is similar in layout/balance to the 415, I wouldn't be suprised to find that it works the same with this car.
the setup is here http://www.thard.co.uk/rc/TRF415/set...CC-STDarms.jpg
Regards
Ed
Regards
Ed
#1503
I'm also using a soft front, hard rear suspension config on my TA05 for indoor asphalt to get better on throttle steering. It works quite well for my driving style.
#1504
Well I just finished putting the TA05 together...I gotta say it was NOT as easy as the 04! Of course I may be biased because Ive had the 04 for so long. The belt pulley/diff holders were a PAIN IN THE ARSE!! The car seems ready to go...just breaking in the drivetrain now.
If anyone has any ideas as to the sizes of Spurs you have used please post. I put in an Associated 83 and it is too large...so there ya go on that one. The car comes with a tamiya size 70t spur and a 22 I believe for a final drive of 7.16...so Im looking for a mid 6 final drive.
The turnbuckle ball ends are pretty loose too...I recommend switching to RPM/losi all around...I plan on doing this soon, as I can see popping a few ball ends.
besides these small gripes, pretty straightforward build. Somebody was asking about the TA05 vs an Evolution IV...Id say out of the box I would go evolution IV...if somebody is really that interested in an 05...hit me up...sounds like a no brainer trade!
Looking forward to the Graphite conversion/spool and the aluminum diff housings...should lighten/speed er up a bit...kinda heavy!
#1505
64pitch 104T spur is no problem.
#1506
Awesome, I have one of those...had not tried it yet
#1507
dway100 put his evoIV MS up for sale. maybe he wants to trade?
#1508
Regards
Ed
Regards
Ed
jimmy's set up is for asphalt
TFR...did you run your car yet? inquiring minds want to know
- Chris
#1510
Originally Posted by DA_cookie_monst
any one can copy one for me and send it to nekmiyevo2.yahoo.com or just post it
thanks
#1511
I wish Tamiya would just let go their goofy "off pitch" and just package in a kimbrough or the like...or even better...make 48 or 64pp like everyone else uses!
#1512
Hi nekmiyevo2,
check your inbox. I've sent you an email !
cheers
cheers
#1513
Yes, it's for asphalt. Sorry for the "Wood" confusion. Wood is short for our tracks name... Rosewood, NC. The other track is in Durham, NC (2003 Roar Onroad Nats track).
Yes, they are Tamiya springs. Before this I was using AE Green Front and AE Gold Rear (stole them off my EvoIV). But I decided to build up a new set of shocks dedicated to the TA05. So I went with the Tamiya springs instead. I opted for Tamiya Red Front and Tamiya White Rear instead of the AE Green/White.
Anyway's I know it's been uhh what's the word... kind like... It's the rule not to run softer springs up front in Touring. Either Same rate or Stiffer. But I said screw standards and I'll go with what works on the track. And this is the setup I came up with so far. Before this I was running HPI Silvers all around.
Oh, as for the Spool. It's a front diff tightened down all the way. Just take out the diff balls. Toss sand paper on top of the diff rings. Replace the diff bearings with bushings. Replace the thrust bearing with a 2mm shim and washer. And you are set. Only problem is if you tap something just right or get hacked hard... you'll loosen up the diff screw instantly giving you 2wd mode for the rest of the race... Only way around this is to tighten everything down and superglue it all together forming a dedicated spool. This is with the Optional High Precision Diff Joint kit of course. And the wear on them is great. Even when I ran an 8x2 with them. Car had horrible off power push (different setup than above). But that's a different story.
Gear ratio can vary here on the same layout. I've also ran 7.1 ratio as well. Just depends how strong your motor is and how good your batteries are.
Hmmm I might try that ratio again this weekend....
#1514
the way i see it, the ta05 is really targeted for those who race in the TCS gt2/3 classes where the tub chassis is mandatory. its a bare bones chassis kit. so i don't get all this talk comparing the ta05 to the evo iv or 415, or even the graphite dual deck upgrade... even with a fully optioned ta05, its not the same as the purpose built performance machines (we all know people who can get similar lap timeswith either, but lets face it, a ta04 had less adjustability than the 414 did, and the ta05 will have less adjustability than the 415). i mean if you want a double deck high performance racing chassis, the evo iv or 415 would cost MUCH less out of the box by the time you bought all the upgrade options for it anyway... so, am i missing something?
the fun of hopping up a car? watching the performance gains?
#1515
