Old 11-28-2012, 08:48 PM   #1
Smile Red light on my Orca VX and VTC Pro ESC
Hi,
Need help i have tried everywhere to find out about this, i have on both my Orca ESC VX and VTC Pro a redlight that comes on and stays on when i turn my radio on it does not seem to affect the ESC as it runs well but im worried that it could be something more dodgy. Its the same with both my radios i have a Ko Pro Po EX-10 Eurus and a Sanwa MT1 im thinking its maybe something to do with my settings in the radio as before when i used to pull the throttle it used to light up blue, any help with this or anything any of you guys can come up with to help will be much appreciated...
scottyf01 is offline   Reply With Quote
Old 11-28-2012, 09:15 PM   #2
On the VTC, a red led indicate some timing is applied, either timing or turbo timing. Led will become green without it (0 timing, 0 turbo).
Same on the VX but a more solid one, pretty noticeable with the clear case.
On the VX, Led will be red with some timing added (either one) and blue without it.
My guess is you add some with the program card (or by updated it to V3).
Just plug the setup box, remove every bit of timing and you will have your blue led back (blinky mode).
mojo tom is offline   Reply With Quote
Old 11-28-2012, 11:03 PM   #3
Mojo tom
Yes got the blue light now on my VX it flashes all the time and more so under throttle and same with the VTC but green is this good? just want to make sure i dont burn my money, hey thanks for your reply appreciate your time.
Scott
Old 11-29-2012, 06:08 AM   #4
Yep it is good.
This is just the blinky mode indicator, add timing or turbo and it will be red and solid (no blinking).
No issue here, as indicated in the manual.
