Old 11-30-2012, 09:07 AM   #16
gpr
@lazerGuy This looks real good even thought is about an extra $200. any more info on this car please,how does it compare to 1/10. Only thing i am missing is gearing for this set-up. thank you
gpr is offline   Reply With Quote
Old 11-30-2012, 09:48 AM   #17
The 1/8th GTP2E in the link I posted has gear diffs and shaft drive, there are no belts or ball diffs like you have in 1/10th cars.
I race this car with 2050kv motor on 4s & 5s.
With a 46t spur and 22t pinion and the 2200kv CC setup on 5s it should do 70mph all day long.
The car comes almost ready to run with almost no assembly on your part.
If you get this car run it right out of the box, I did not do that but had to change it back to stock every time I change anything on it.
The first year I raced this car I did not break any parts, the next year I broke an upper front arm, last year I broke a rear hub so I change to this PB rear setup,
http://www.ofnawarehouse.com/product...f7pamv28s9j0t5
That change really help keep the back of the car hooked up so thats all you should do if and when you feel you need/want to.
Lazer Guy is offline   Reply With Quote
Old 11-30-2012, 10:15 AM   #18
gpr
thank you for helping me, the tires that come with the kit hold 70mph? what online store do you shop from?
Old 11-30-2012, 10:38 AM   #19
http://www.brucknerhobbies.com/SweepTires.htm
This is the tires I use in 45 shore on cool tracks and 50 shore for hot tracks.
The stock tires are very hard to put together they are not belted.
They work OK to get you going but will not last very long.
Old 12-02-2012, 01:03 AM   #20
gpr
Will post pictures tomorrow. got everything but the batteries and i cant find where to buy bigger pinion and spur gears. What should i do to get traction at high speeds to prevent it from flying off, many guys have told me past 80mph they what to take off.
LRP SXX V2 issues...HELP PLEASE!! Wolf1007 Electric Off-Road 40 02-17-2011 08:06 AM
Venom pro charger problems, help please TrooShot Radio and Electronics 15 03-25-2010 02:55 PM
ESC + brushless on Pine Wood Derby Car Help Please wideopen Radio and Electronics 20 03-24-2009 12:36 PM
i cant solder, help please nitro stan Electric Off-Road 80 12-31-2008 07:00 PM
KO Propo Help please acutts Electric On-Road 14 07-30-2008 04:55 PM
