Trinity Tru Lathe Setup Problems
#16
Oh yikes..I might have been spinning this thing the wrong way. Ok let me try that now. I am getting so much help here this is awesome! Thanks all of you!
#17
Originally posted by PitCrew
Yea, I am a machinist too. Did the 4 year apprenticeship.
Where at? I'm just out of tech school( NOOB, I know ) in Topeka KS. I was top 3 in the class though.
#18
Originally posted by tminus3
Thanks all of you!
Thanks all of you!
Not a problem, I hate when I have things I can't figure out.
#19
Ok, now that someone else is having a problem....
My lathe cuts the comm in a coned fashion. I think that this comes from the two set screws underneath the nob that sets the depth. I tried fixing it by tightening, and loosening to find the right amount but it was either too loose (upper part and bit would vibrate) or too tight and I had a hard time getting the bit to slide on the screw.
Any suggestions would be helpful
#20
mtc3od - The cone cutting is from the blocks not being aligned properly.
#21
how do you make sure that they are aligned properly?
#22
Depends how much cone its making.
If its not too much (i get this sometimes) its probably from making a "finish" pass back across the comm. Otherwise you'll have to have somebody indicate a shaft to the guide ways.
I did my apprenticeship for Hansen Machine Corp, which later became Primus International. I am pretty sure they have a shop in KS.
#23
ok guys, I just did a bunch of cuts with different parameters and basically the best cut I got was with the following settings:
- motor spinning away from me (sounds wrong but its kinda working)
- motor running at 4.0 volts (a stock motors at 4.0 volts is FAST)
- single directional cut
the best I could do is 6.2 Amps @ 2 volts...is this any good..or should I be able to get better?
#24
are you using the V blocks or the bearings? i found that the bearings on my trinity lathe really hurt the finish, i switched to v blocks and it cuts good
how many amps the motor pulls really depends on the motor itsself. i have stock motors that pull anywhere from 5 to 10 amps at 2 volts and i havent really noticed that amps relates to it being fast on the track, its all how u gear it
#25
I'm using the V Blocks.
#26
#28
No door locks.
airplane parts.
I'm Not machining anymore right now.
airplane parts.
