Old 01-17-2013, 03:00 AM   #16
NDZ
Smile
Originally Posted by rokosam View Post
Are you planning to use 3S lipos?
Yep
NDZ is offline   Reply With Quote
Old 01-17-2013, 04:52 AM   #17
I am thinking in using a hobbywing 120A ver 3. for 3S lipos and a 6.5T brushless motor but have to know the right ratio for it (using 90T 48p spur), have to know the right pinion.
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 01-17-2013, 11:05 AM   #18
Large 29 mm turnbuckles rods arrived today!!! Now I can graduate rear camber between 2 and 3 degrees without problems!!!
Old 01-17-2013, 01:03 PM   #19
NDZ
Hey that looks good. 2 degrees should be sufficient right? Which track is your home track Rokosam?
What pinion are u planning on using?
Old 01-17-2013, 01:08 PM   #20
My local track is in Spain, in Barcelona city (Catalonia).
About camber, nitro cars usually begin with 2.5 degrees rear, it depends of the traction, type of track...
This car uses nitro parts but is ligther so i thing a rear camber between 2 and 2.5 is the right one to begin.
My first idea was to use a 4.5T+turbo with a 140A Teampowers XS Pro v1.2 ESC with 90/19 ratio 48p.
But I think it will work better with a 3S lipo 11.1V capable ESC (maybe my 120A Speedpassion GT2) with 3S lipo and 8.5T-7.5T motor without turbo , but donīt know the right ratio for this config.
I have never used 11.1V 3S lipos before.
Old 01-17-2013, 02:15 PM   #21
NDZ
Me neither. I think measuring roll out would be best to figure out the best ratio. For 5.5 turns I would start at 30-35 mm roll out. Internal ratio of the car is 1.95 to 1. At gearchart.com you can get your roll out with different pinion/spur sizes and tire diameters.
I'm installing the spektrum telemetry set to measure motortemps to make sure everything stay's ok. From there you can experiment with boost I guess.
Old 01-17-2013, 02:16 PM   #22
NDZ
My track is MACH in Heemstede Netherlands btw
Old 01-17-2013, 02:29 PM   #23
Do you think 7.5T+ 3S lipo 11.1V is fast enough?
My SP GT2 Pro works with 3S lipos and = or >7.5T brushless
I am the guy with more virtual VRC PRO laps at MACH Heemstede!!! ever
15957 laps at MACH at this moment.. and more!!!
Old 01-17-2013, 02:42 PM   #24
NDZ
Ha ha lol. And more to come I guess.
I think 7.5 would be a good start. Maybe use boost when temps stay low enough. Last year a club member achieved 112 km/h with a boosted 6.5 touring car on 2S. So 7.5 is ok I guess. You have more drag with a Lola body though but that is why we go to 3S instead of 2S
Say hi to Messi for me
Old 01-21-2013, 11:42 AM   #25
NDZ
Just ordered the missing VDS parts today. Aperently I bought the 200 mm version instead of the 220 version.
Now all to do is wait . . . . .
Old 01-21-2013, 04:56 PM   #26
At the end I have decided to use 11.1V 3S lipos with this electronics:
Leopard 120A SC8 for 2S-3S-4S Lipo
Leopard Brushless 3900 kv/9T 4 pole 3650 motor
4,2V*3S= 12,6V 12,6V*3900=49140 rpm with 3S lipo
4,2V*4S=16,8V 16,8V*3900=65520 rpm with 4S lipo
Old 01-22-2013, 11:40 AM   #27
NDZ
I think 3S is more then sufficient. Allmost 50k rpm would do the trick. There is an equivalent combo from Castle with a 1410 Neu motor (3800 kv, 4 pole). Very curious how this goes. Let's hope for some nice weather.
Old 01-31-2013, 07:06 AM   #28
Last experiment:
Semi 200 mm config: (Chassis at 220mm but with GRP-Gandini electric 190 foam tires!!!)
Uploaded with ImageShack.us
4.5T Team Powers
SpeedPassion GT2Pro HW 2.1 120A (last MOD930 SOFT)
6200 Team Powers Lipo
Edam 200 Lola bodyshell
Old 02-19-2013, 06:25 AM   #29
Lipo 3S has arrived!!!
Old 02-20-2013, 05:50 AM   #30
Zippy 5000 mAH 11.1V 3S Lipo
Upgraded SP GT2.0 to HW2.1 and 930MOD firmware (3S capable)
9.5T Nosram brushless motor
90/18 ratio
