Old 11-25-2012, 06:16 PM   #1
GTRdrifter's Avatar
Questions?? Complete rebuild
So i wrecked my car hard earlier and broke a few parts that i have to replace now. Since this happened and i wont be driving for a while i decided to do a complete rebuild and cleaning. As im tearing it apart i noticed i have a few stripped out allen screws(the head where you put the allen is stripped) . Does anybody out there have any tips or tricks to get these stubborn @#[email protected]#@$ out Any help would be much appreciated
Chassis:EXceed Madspeed
Motor:Stock 22T 540 brushed
Electronics:Stock servo/ESC
Tires:HPI T-drift 26mm
Body:HPI 1/10 Gen 2 Mitsubishi Eclipse
GTRdrifter is offline   Reply With Quote
Old 11-25-2012, 06:40 PM   #2
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
a screw puler would probably work. i take a dremel with a worn down cut off disc and cut a flat head size groove in them.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 11-25-2012, 06:48 PM   #3
GTRdrifter's Avatar
I have neither of those tools lol....any other ideas??
Old 11-25-2012, 06:57 PM   #4
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
What he said! Get a Dremel!
Josh-n-ya is offline   Reply With Quote
Old 11-26-2012, 12:51 AM   #5
jmellipse's Avatar
Alu or steel ? You might be able to get a oversized allen in there. Be sure to use good quality allen wrenches and not the angled ones supplied with the kit.
jmellipse is offline   Reply With Quote
Old 11-26-2012, 01:18 AM   #6
djiewie's Avatar
drill the head with the same size drill untill the head comes off. Then you can remove the stud because it doesn`t have pressure.
Hope this helps you if other things/methods fail. succes.
by the way, i always do a rebuild after a race weekend. On average its approx 20 rebuilds a raceseason.
with a transmission rebuild after training.
djiewie is offline   Reply With Quote
Old 11-26-2012, 02:34 AM   #7
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Solder your allen driver to the screw and back it out. Or buy a screw puller or notch the screw with a Dremel and back it out with a flat blade driver
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 11-26-2012, 10:10 AM   #8
GTRdrifter's Avatar
Thank you to everyone for all the advice and ideas
Old 11-26-2012, 11:06 AM   #9
GTRdrifter's Avatar
So i broke 2 tie rods on the left side front wheel, i have 5 stripped hex bolts, I'm pretty sure i ruined my servo and i snapped a pivot block under the front diff. I was drifting in my front yard and a kid down the street came down with his short course truck. I tried to dodge him so he wouldn't monster truck me and i ran full speed into a ford escape's wheel. So now to order all the replacement parts is gonna be around $50. Should i fork out the extra $50 and go all aluminum? I think so....
Old 11-27-2012, 10:10 AM   #10
GTRdrifter's Avatar
So i finally got the car apart completely. I had to use a saw to cut the hex heads because i dont have a dremel. It took awhile but its apart. Now its time to clean and access all the damage....fun stuff...
Old 11-27-2012, 03:31 PM   #11
blis's Avatar
http://buy1.snapon.com/catalog/item....ia&dir=catalog
These are great, work around the perimeter of screw until you release it.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Kyosho MP9 TKI roller or complete slowslash4x4 R/C Items: For Sale/Trade 15 03-18-2011 08:17 AM
whats my stuff worth complete cars rc8driver Nitro Off-Road 17 10-21-2010 01:23 AM
i want to rebuild my losi 8ight 2.0 segui305 Nitro Off-Road 18 08-05-2010 10:10 AM
