need help with id
I picked this up very cheap,but I don't know what it is. It's got pillow ball suspension front and rear. http://i1149.photobucket.com/albums/...r/IMAG0442.jpg. http://i1149.photobucket.com/albums/...r/IMAG0443.jpg. http://i1149.photobucket.com/albums/...r/IMAG0444.jpg. http://i1149.photobucket.com/albums/...r/IMAG0445.jpg.
Trinity T-spec.
Probably are-labelled asian brand though. |
Was it worth $11? And is it worth anything.
I would say it was well worth the 11$, yes.
that looks like a PERFECT street car. parts availability?
Kyosho V1R......
Greetings....I've broken several V1R [actually Trinity ReflexNT] arms which are compatable with the the Trinity T-Spec arms (upper/lower). Stock T-Spec arms aren't as durable as those nitro arms. The steering knuckles are also compatable as well as the rear up-rights(of the T-Spec). Try Nitro House for spare arms. Goodluck.
what is the max turn motor i can use 27 or 21?
As fast as your esc will handle.
Well I've read to max turn motor is 27 then I seen 21 I just don't want to destroy the diffs because of a bigger motor.
