Old 11-23-2012, 01:13 PM   #1
Trader Rating: 26 (100%+)
Default Xray T3 Spur/Pinion for 17.5 blinky
New to RC and wondering what would be a good Spur/Pinion setup for 17.5 blinky for a 50'x50' indoor carpet track. I currently have the 84T 48pitch spur gear. Wondering if 64pitch is a better way to go or the pro's/con's of each. Thanks for your input!
TCicon is offline   Reply With Quote
Old 11-23-2012, 01:26 PM   #2
B00t13g's Avatar
64p 96 tooth.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 11-23-2012, 01:36 PM   #3
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I ran 96 spur and usually had a 44-49on it getting me a 4.2-3.8 fdr
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-23-2012, 01:39 PM   #4
locked's Avatar
48pitch is less likely to strip. It's good for Mod and boosted classes, but much more difficult to get down to the sort of FDRs required for blinky spec racing.
64pitch is a little smoother and allows for finer adjustments to gear ratios. It can strip a bit easier in a more flexible car or with faster motors.
I use a 102tooth 64p "Core RC" spur with usually around a 50 tooth CRC pinion for 17.5 blinky on tracks of similar size to yours. d3.5 motor in an xray t4, but I ran the same gear in a t3'12 prior to this. I have also used 100/52 on a larger track.
Between 3.3 and 4.5 FDR is the approximate range for 17.5 blinky. 4.0 should be a good place to start.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-23-2012, 04:28 PM   #5
Skiddins's Avatar
If you want to run 17.5 blinky, you'll need to gear taller anyway, an 84t spur won't do it.
I've always run 48dp as I don't like trying to mesh 64dp.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-23-2012, 04:41 PM   #6
locked's Avatar
I also prefer 48p, Skiddins. I always use 48p in Mod and boosted, but I just have never found a small enough spur and a large enough pinion to run 48p in 17.5 blinky. Plenty of 64p choices to get down to low FDRs though.
Dave Locke
Old 11-23-2012, 05:07 PM   #7
Chaz955i's Avatar
This
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 11-23-2012, 05:23 PM   #8
AdrianM's Avatar
I run a 92 with a 48 or 49 for a 3.8-3.6 fdr. This is with a Rectech a 12.5mm hi torque rotor.
Adrian Martinez
Old 12-05-2012, 09:05 PM   #9
snuvet75's Avatar
Trader Rating: 16 (94%+)
48P vs 64P:
64P is way better in a way that you can up or down the FDR a lot easier. Reason? The finer teeth on 64P spur allow relatively small changes in size of the spur among different T's. I have tones of 48P spurs and pinions. Once I tried to make FDR 3.8 with 48P 78T spur for my x-ray. X-ray's DTR is 1.9 so the pinion comes down to 39. When I put that in, it would not fit there unless the spur and pinion clench each other so tight. The same exact opposite is true when you try anything above 7.0 with 48P. They don't meet each other. Of course I could've tried smaller spur and pinion for 3.8 but it's simply hard to get hold of smaller spur in each size. Better get 64P in the first place. Some people even say 64P is smoother but from my experience it doesn't make big difference. 48P is louder.
But I still use 48P for FDR between 5 and 6. It'd be a waste not to use 10 48P pinions I have.
snuvet75 is offline   Reply With Quote
Old 12-30-2012, 02:30 AM   #10
Sorry guys I am new to all this so Im not familiar with all the lingo lol
Anyways I got a T4 just currently in the middle of the build ,..... I have not bought a Pinion gear for it yet .....However what is a good general gearing for 17.5 class ?
Do I use the stock spur with the kit?
Basically would like to know plain and simple what I should start with for my T4 running a 17.5 blinky class ?
Thanks in advance .
yunowill is offline   Reply With Quote
Old 12-30-2012, 06:45 AM   #11
Bigz84's Avatar
Trader Rating: 20 (100%+)
Default gearing
Thanks in advance .
you will want to start around a Final Drive Ratio of 4.0, which is close to a:
92 tooth spur, 44 tooth pinion, 64 pitch, which is 3.97 ratio
or
96 tooth spur, 46 tooth pinion, again 3.97
i personally run a 92 spur, and depending on what track i am at, 47-50 pinion
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : RCAmerica : Hudy : Xray : Diggity Designs : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 12-31-2012, 01:42 AM   #12
Sweet I am going to try that out .... I will most likely go with the 96T spur as thats what most are using in this thread ..... If a final drive of 4.0 is a good starting range I will go with what you have said and see what I can do from there ..... I guess my 84T spur that came with the kit is no good for this application ?
or
Northwest FOR SALE! Mal Northwest Racers 13217 Today 05:07 PM
Carpet On-Road in NYC-New Rochelle, NY Donny Lia Northeast Racing Forum 3427 12-07-2017 07:06 AM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
