Old 04-03-2005, 03:29 PM   #1
Default opening a Futaba 3PK
I want to open up my Futaba 3PK (why? that's another question). I managed to find all the screws (also behind the handle) but get stuck. I cannot get the display seperated from the 2 sides the form the rest of the transmitter.
does anybody have technical info how to open a 3PK?
Thnx,
Santosh
Santosh is offline   Reply With Quote
Old 04-03-2005, 04:20 PM   #2
Send a message via AIM to jumbo360
All it is is 6 screws i think 4 in back and 2 in front
jumbo360 is offline   Reply With Quote
Old 04-03-2005, 10:35 PM   #3
17driver's Avatar
R/C Tech Charter Subscriber
Why?
Midwest malitia member
17driver is offline   Reply With Quote
Old 04-04-2005, 06:18 AM   #4
lee82gx's Avatar
for the screen, there is a screw or two underneath the or rather along the antenna housing tube.
but is mightily difficult to actually remove the screen, you can just loosen it and let ir dangle. Important advice: BECAREFUL. Once, i knocked a micro capacitor off the PCB. Serious attention required.
lee82gx is offline   Reply With Quote
Old 04-04-2005, 11:51 AM   #5
Hey Santosh,
I want to buy a Futaba 3pk black.
Is it synthesized?
I have read that black version has a synthesized module.
Do you need another receiver?
How it works?
Capone_GR is offline   Reply With Quote
Old 04-04-2005, 11:56 AM   #6
rc-zombies's Avatar
you can buy the sythesized module seperately. but the receiver still needs xtals...
Old 04-04-2005, 12:02 PM   #7
Regional Moderator
Darkseid's Avatar
Default Re: opening a Futaba 3PK
Thnx,
Santosh
There are also some tabs (two on each side) that hold the screen in place. All you can do really is "work" it off once you've removed all the screws you mentioned.
Just be careful.
I had to open mine up once because the brand new attena I bought striped when I tighted it down. Now it can rotate, but I can't unscrew it to take it off. Once I got the radio open though, and saw how tight stuff was in there, I decided to just leave it.
So I hope whatever your trying to get to is worth the risk!
TLR 22...Tamiya F104...
Real R/C Opening day 4/7 David Alberico Kansas/Missouri Racing 9 05-16-2007 06:18 AM
Novak Job Opening Charlie Electric On-Road 11 06-17-2004 05:56 PM
Novak has an Opening! Charlie Electric On-Road 17 09-29-2003 11:21 AM
