Old 11-22-2012, 05:06 PM   #1
BigNick84's Avatar
Default TC3 VTA Setup ?
Iam just starting to get into the R/C thing , I bought a TC3 for the VTA class and have ran it a couple times and just cant seem to get a handle on it . I read the TC3 tuning guide and other stuff , So this here is kinda my final resort on trying to get the car setup for carpet thought what i was doing was going to right direction and now its worse lol its really squirly in the rear and just dont seem to go around corners smooth as the other cars are that iam racing with and pushs like a dump truck . would like a idea on what springs to run , caster camber , shocks . Any help on setup would be a great help thank you in advance !
BigNick84 is offline   Reply With Quote
Old 11-22-2012, 05:42 PM   #2
GP40X's Avatar
Check out the following threads
U.S Vintage Trans-Am Racing Part 2
U.S. Vintage Trans-Am Racing
Do searches in these threads for TC3
Also search some of the TC3 & TC4 threads on RC Tech for VTA setups and this should get you going in the right direction
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 11-22-2012, 05:44 PM   #3
jgraham37128's Avatar
Trader Rating: 24 (100%+)
Default Battman
Look for BATTMAN on this site (got to the VTA thread) he runs a tc3 in vta. He would be a big help. I think his avatar says darkside racing?
jgraham37128 is offline   Reply With Quote
Old 11-22-2012, 06:07 PM   #4
GP40X's Avatar
+1
Look for Myron BATTMAN Kinnard aka DARKSIDE. Knows all the secrets for making TC3/TC4s handle very well.
Bill
Team Qik
Xray T3 2012 USVTA
Old 11-22-2012, 06:24 PM   #5
Jerz616's Avatar
Trader Rating: 49 (100%+)
What kind of track? High or low grip. I would start with about 35wt oil front and 30wt in the rear with the AE blue springs in the front and green in the rear. This is what I ran on my old TC5 before I switched to xray. I would try 1.5* camber front 2.0* rear. Try laying your rear shocks all the way in. Typical caster is 4* caster blocks. If it still pushes then try going to 30wt oil in the front and add a little camber to the front.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-26-2012, 09:11 AM   #6
Trader Rating: 41 (100%+)
Also for VTA Run your roll center as low as possible
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-26-2012, 11:40 AM   #7
Suspended
On top of low roll Center, you'll need Rpm ball cups, Yokomo bladders in your shocks, dremel your battery slots, etc....
bertrandsv87 is offline   Reply With Quote
Old 11-26-2012, 11:15 PM   #8
BigNick84's Avatar
the info is great , so whats the deal with the Rpm ball cups , whats it effect ? thanks
Old 11-26-2012, 11:39 PM   #9
Suspended
The rpm ball cups tighten your suspension by eliminating the slop that AE ball cups are famous for. That also stops the darting in different directions when you're going down the straight on top of eliminating tweaks due to hard hits. Your Car will be more consistant, thereby dropping your laptimes dramatically...
Old 11-26-2012, 11:42 PM   #10
Suspended
The most important tip here is the Yokomo #YS-8DMH shock bladders in your AE shocks. Even more consistency....
Old 11-27-2012, 09:36 AM   #11
BigNick84's Avatar
so would that solve the issue with the tail always wanting to come around on me ? like it has no traction, we run on a high traction carpet and run tire compound also would think it wouldnt do that
Old 11-27-2012, 09:40 AM   #12
BigNick84's Avatar
and i see on some thing where they run the rear shock tower on the front whats the advantage of this?
Old 11-27-2012, 09:51 AM   #13
pejota's Avatar
can you post your current setup?
Hard to tell you where to go when we don't where you are....
pejota is offline   Reply With Quote
Old 11-27-2012, 10:06 AM   #14
Suspended
For the rear stepping out, you need to run One degree camber or less, with low roll Center, 5mm ride height, 1mm to 1.5mm droop, on AE silver springs with fully sauced Tires cleaned with Nitroclean.... If you're Off by a fraction in the Camber/droop settings it will spinout. You must also remember to shim all your Tires tightly enough so they won't wobble, and make sure they are glued properly.....
Old 11-27-2012, 10:34 AM   #15
Suspended
As far as running the rear shock tower up front, I have no clue what that does...
TC3 BMI chassis VTA setup/extras and more ovalracer1m R/C Items: For Sale/Trade 9 01-28-2011 09:47 PM
TC3 VTA setup / B4 Project up for grabs mhodgie R/C Items: For Sale/Trade 8 11-28-2010 10:09 PM
Onroad sale. TC5, TC3, VTA, GTB, 13.5, 21.5, chargers Takt R/C Items: For Sale/Trade 16 12-13-2009 02:13 PM
TC3 VTA Setup or Rubber Tire on Carpet mach51 Electric On-Road 9 04-10-2009 08:10 PM
