need help understanding rollot using gearchart.com
1/12 scale and 1/10th scale pan cars which is 1.1 internanl drive ratio.
What is the idel direction to go if I understand correctly the closer you get to 1.1 the speed you build and the more you move away from the less speed you have. Iam I correct? So for example if I have a spur gear of 88 and a pinion of 33 and tire at say 52 I should be at 2.67 and if I go up in pinion should bring me closer to 1.1 correct.just looking for some help to understand more about gearing thanks for any help
